Holley 850 hardcore series double pumper pig rich no matter what i do!
hey guys it’s been a while but I’ve been chasing my tail on my Camaro running rich. I’ve got a 383 stroker with A. Holley 850 double pumper hardcore series carb. Cam is .555 lift comp cam. I have done everything to try and lean this carb out. My cruise afr is 12.5. Lowering jet sizes doesn’t help either. The only thing that helps is leaning the idle mixture to 15 but if I do that the carb is too lean during acceleration and cuts out. It will also die in gear if I have it that lean at idle. My plugs look rich obviously but not black rich. Mostly a dark brown on the porcelean. Anyone have any ideas? Is the cam spitting out unburned fuel and giving me a false reading? Car has a ton of power and runs great. Am just concerned about fouling plugs and bore ware. I use aces IV so i guess I’m not super worried about bore ware and the fact it’s a once a week driver tops and once a month strip car. Any ideas or advice guys? I’ve been messing around with this for 8 months now. Should I just call it good since it runs so damn good? Seems like the more gas I throw at this engine the better it gets... confused. Help thanks!!!
Received 1,662 Likes
Re: Holley 850 hardcore series double pumper pig rich no matter what i do!
Cams do not "spit".
Have you tried the "Hooley Tuning" sticky at the top of this forum? I'll be happy to try to interpret the writer's intentions for you, to the limited extent I can.
Ok so blowing intake charge out of the exhaust... I say spit. Obviously I know cams do not spit.... tomato tomahhhto... cams will blow intake charge out of the exhaust which is what I think might be happening.
Why do you think this happens only to your car, and only with this carb on it?
It is not a good policy to make up stuff like that to try to explain something you don't understand. That's like blaming it on alien abduction or something: it doesn't pass the test of tailoring "explanation" to "facts". See my signature for a terrific mental technique to follow in situations like this.
That said, it IS possible for a carb's calibration to be SO FAR WRONG for what the motor wants, that the motor misfires or that there's raw fuel passing through it or whatever. The answer of course is to properly calibrate the carb, instead of blaming the cam. Which is to say, make the carb's fuel delivery curves - fuel vs air flow at higher speeds, extra fuel vs power demand at WOT, fuel vs vacuum at idle, etc. - match the engine's demands. One does this by "isolating" each system of the carb in turn, in the order in which they interact, and adjusting each of those systems to satisfy the engine's wants.
Note that this is VASTLY different from posting on the Internet about "what size jets should I put in my carb" and other such fundamentally wrong-headed questions. Every engine is different; every car is different, such that the same engine will react differently to the different loads each car presents it with (weight, gears, converter, etc.); and every carb is different. Plus, every driver/owner has different expectations, and every potential use of the car (daily driver, strip, oval track, etc.) puts different constraints on the carb's ideal settings.
Which is why YOU should tune YOUR carb on YOUR motor doing whatever YOU do with it to make it work like YOU want it to work. The Holley Tuning sticky kinda walks you through that.
The order of adjustment is:
Obviously if the carb is simply defective in some way, there is NO HOPE of ever calibrating it correctly. MAKE SURE it's in perfect working condition BEFORE trying to calibrate it. Those are 2 different things: fix a broken carb, vs calibrate a perfectly working but mismatched carb to match your engine. Put a "kit" in it before starting, with spray silicone lube on all the gaskets, so you can easily take it apart repeatedly. "New" is not the same things as "perfectly working"; so don't automatically assume that just because your carb happens to be new, if it is, that it's not defective.
Rebuild it, then go through the process, and let us know how that works out.
- Fuel level
- Main jets
- Power valve
- Idle system
- If any of 2 - 4 are WAY off, might have to go back through them all again, IN ORDER
- Secondaries
So I’m making things up by stating a large cam can be responsible for sending wrong 02 readings on an AFR due to Unburned gases leaving the exhaust?!? Dude don’t sit there high and mighty when I state something that can actually happen. Your screen name says it all about you? Give some actual advice without trying to put down others by making **** up you dumbass!You are the same type of idiot who sits at the track telling everyone how to tune cars and then you get in your shitty 4 banger civic and go home to your trailer. Anyone who isn’t a dumbass please respond. This guy
Lots of people have big cams and still get their car to run just fine. Although ".555 lift" hardly qualifies as "big".
Sorry I tried to help. Too bad you're immune to it. Good luck getting your car to run right. Maybe someday when you develop enough humility to LEARN something instead of inventing wild-a$$ hilarious "explanations", you'll make some progress.
Have a wonderful life.
Actually got a private message from someone who wasn’t as self absorbed as your dumbass. .555 is a big cam compared to stock. I would say something like huge cam if it were like a .626 etc. So thanks for confirming to me again that you are in fact a dumbass! The fact that you don’t understand larger cams can send unburned gases which provide a false reading on AFRs is comical to me. You talk a big game but don’t know basic ****. You are one of those guys who needs people to act like you are gods gift to engine building. When someone presents a problem you don’t understand you try to claim they made it up?!? What are you like 12 years old dude? Grow up man and learn some facts you puffed up crows ****. Go figure that was exactly what I had going on too! AFR was pig rich but it was due to a false reading because of the big cam. So if anyone else has this problem make sure to check your plugs and compare them to what your afr reading is. Oh btw have fun with your Honda Civic dude! I hope the wood stove keeps your trailer warm tonight it’s getting cold! I swear I run into idiots everywhere. His screen name says it all!! I guess he wanted a screen name to match his brain hahahaha! Idiot!
Indeed... uncalled for.
[QUOTE=sofakingdom;6188975]Indeed... uncalled for
oh now the baby is upset! Go bother someone’s else’s thread and get the hell of mine you rat bastard.
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
What is wrong with a honda civic. They are great cars
"It was a beautiful day....."
Hell yea my wifes friend changed the oil 2x in hers over 6 years when she asked me to change it for her literally nothing came out of the drain plug. I refilled it then changed again after 200 miles (came out black). That was 30k miles ago and the thing is still running strong just went to florida and back.
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
- Fuel level
- Main jets
- Power valve
- Idle system
- Secondaries
This is very informative, but where would the squirters and pump cams fall into this list of operations? This guy could have problems dumping too much pump shot and is covering, or causing his actual issue. It doesn't seem like he knows what to do at all. Just so you don't take it wrong, I am not criticizing, I am genuinely asking. I am not a carb guy at all, and I only mess with one vehicle with a carb
Pretty good chance the new carb would have to be tuned also.
If he is determined the cam is spitting (which I unsuccessfully googled so this youngster has no idea what that is) I would call Comp Cams tech and see what cam he needs to install. The cam lifts the valves. Carb and intake put the mixture into the cylinder, spark ignites it.
Anyway, its a beautiful day, and the Christmas season - so Merry Christmas everyone. Somebody start posting some pictures for us to view
Car: 88GTA
Engine: 5.7TPI
After his rant on Sofa, he needs to find another forum that knows all the answers. We obviously have nothing to bring to the party.
sorry guys sofa really got me upset. Man I’d love to punch that guy so hard in his ****in teeth. I wish I could just meet him somewhere and fight in a roped circle. Anyways. I doubt spitting cams will come up with much when you google it. Am I wrong to say that larger cams can recycle unburned gasses and spit them out the exhaust providing wrong 02 readings. Seems like a read about this a lot. Don’t know how it actually happens. Sofa probably doesn’t have this going on with his civic but for people who like to drive fast cars and waste more gas than you can shake a stick at.... ****ing sofa omg! This guy. Anyways. I was able to lean it out pretty good. 13.8-14.2 at cruise by going with a smaller PV and increasing my primary jet sizes to account for the loss fuel I was getting before. I think the power valve was going on to quickly and dumping gas in. I’ve run a 750 on this engine but the 850 was noticeable more powerful. My squirted sizes are 35s and I’ve played around with those as well. I think they work pretty well. Maybe I could get a dizzy with vacuum advance but vacuum advance saves too much fuel and this is America so I’d like to dump more into the ozone haha! I also drilled out the PV restriction a tad to dump more fuel because my top end was WOT was getting a little hairy. Car runs awesome now. I mean I’m all honesty it ran awesome pig rich but I was sick of buying plugs every month since they were made in Japan and I don’t like supporting those bastards. The cam is a comp cam something. .555 lift power band is 3-7000 I Mia posted before. 3.73 gears in the back on street tires so it chirps in reverse chicks dig that ya know. Well at least American chicks.
Car: 92 Firebird
Engine: 4.8 LR4
Lift does not make it a "large cam" really, it's more the duration and overlap. and .555" lift wouldn't even be that much lift, must less much over stock, .050" is not much more than stock, especially when cams are running over .600" in new cars that pass emissions. Post the duration on the cam so we know what you think is a "big cam"
If you're seriously looking for help/information then you will need to throttle back your insults and crass language. This forum is one of the most helpful and also the most friendly/clean forums on the internet, we plan to keep it that way.
Tuning carburetors is a long and tedious process. When you say the 850 gives you "more power" was that verifiable or just by the seat of your pants? 35 squirters are huge and likely what is contributing to your flooding issue.
This thread is your starting point, I highly suggest you give it a read and try what it suggests. It has helped countless Holley users on this forum. https://www.thirdgen.org/forums/carb...ey-tuning.html
I can't recall ever needing to alter it in a carb after it was set up right otherwise. Esp a Holley... their pump system is usually WAYYYYY overkill.
But in any case, if the pump needs work AT ALL, it would be at step 5½.
Usually, nowhere... the entire accelerator pump system is a "crutch" to tide the carb over during the short interval of time between when air starts flowing as the throttles are opened, and the time that the heavier, higher-inertia fuel begins to move. A "perfect" carb would have no need of it at all. Of course no such thing exists, so all carbs need a little bit of help in that regard; but once properly tuned, the need is minimal.
You still here???
I believe I was speaking to someone who was looking for information and trying to learn something, not someone who just wants to start arguments over stuff he doesn't know much about ... and the way his car runs, by his own account, backs that up.
Car: 1987 Z28 Camaro
Engine: 305 LG4 4bbl
Transmission: TH700R4
Kiwallo, cut the crap mate, theres no need for any of this angst.
Any moderators feel like nipping this sh**show in the bud before it deteriorates any further?
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
Enough is enough.
xpndbl3
09-06-2006 12:03 PM
Wayquick4u
Carburetors
03-28-2001 11:53 AM
