Parting out 1991 Formula 350.
Car: 1992 Trans Am
As the title says, beginning to part out a 1991 Firebird Formula 350. Car has a 350 TPI, and I believe a 700r4.
Disc brake 3.23 posi rear end, but I may use it in my car.
Car has a short in the fuel pump circuit I am tracking down now, so I can start it and make a video of it running. Cranks over easily, with good oil pressure and compression.
Uniontown Ohio is where I am located.
Lmk if you are interested in anything, thanks.
Car: 1992 Trans Am
Re: Parting out 1991 Formula 350.
Forgot, 143k on the odometer. I will get some engine pics soon, nasty weather out at the moment.
Does this car have the throttle body cable linkage like the LT1s? I need the accelerator cable that will fit the LT1 throttle body
Does the throttle body cable from the accelerator has a barrel that hooks up to the throttle body linkage like the one in the picture left from yours.
I think he’s looking for a 89/92 f body tpi throttle cable like pictured above #4.
This might work with the aftermarket lt1 tb. Bolts use the wrap around cable design.
https://www.thirdgen.org/forums/tpi/...body-58mm.html
Car: 1992 Trans Am
Updates-
Taillights sold
Engine, transmission sold
Serpentine setup-sold
Doors-sold
Taillights sold
Doors-sold
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
Wing?
-- Joe
-- Joe
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
If the interior plastics are black, how much for the A pillar covers?
Car: 1990 Camaro IROCZ
Axle/Gears: 3.45
Looking for front brake dust shields, both side. Is TPI set up going with the motor?
Car: 1988 Formula 350
Engine: 5.7
Looking for the air cleaner assembly from base all the way to rubber to the throttle plates of TPI. Also possibly the charcoal canister with mounting bolts. Pics and price if you have them please. Oh and are the rear seat belt retractor covers in decent shape?
Thank you!
Thank you!
Car: 1992 Trans Am
I will check on the seatbelt retractors for you, but I am pretty sure they are good.
Axle/Gears: 3.45
Looking for the upper cooling fan mount, Camaro and Firebirds are the same i think.
thanks
thanks
Car: 1992 Trans Am
Yes it is still available, but I have not taken the dash apart yet.
Let me get it taken apart, and I will get you a price with shipping, and a pic.
Thanks!
Axle/Gears: 3.45
I was thinking that, was looking for a cheaper option then the Hawks repop at $100. Doing an LS fan conversation and did not want to hack mine up in case it did not work out.
but Thanks
but Thanks
Car: 1992 Trans Am
Most of the drivetrain is sold. Still some stuff left:
Dual cooling fan setup, complete with top/bottom, fans etc. 125.00 shipped, 100.00 local pickup.
Steering box- 75.00 local pickup
WS6 front/rear sway bars and springs. 100.00 local pickup, 150.00 shipped.
tpi-hearse
Exterior Parts for Sale
104
06-18-2008 11:39 AM
