Hooker LS turbo manifold build
After buying and installing the cx racing ls thirdgen kit I realized the amount of tubing and 3" hotside were not ideal for an s480 that I planned to install... Switched to hooker LS manifolds and fabricated up the hotside, and used the cx racing coldside that comes with thier kit as the intercooler has a great core and it was all 3" piping.
Here are some pictures to give you guys an idea of how I did my kit, with the thirdgen there isnt a lot of room for the turbo to be up very high. I ended up using mostly a 3" 304 ss donut and hacked it up.... Flange is an open t6 from ebay with cnc transition.
VS racing 60mm wastegate and S480 96/88 1.32ar. Setup should be good for 800 tire and mid 4000 full spool. I also re did my fuel system, tucked the regulator up in the cowl and ran lines through the fender well... Not pictured but I did make a shield that covers the lines in the fender from rocks and debris.
The whole front end of the car is hacked up because I will be doing tubular shock towers and front bars when I start installing the cage... the rest of the radiator support will be cut out and the rad/intercooler will be all mounted to 1" and 1 5/8" tubes
Re: Hooker LS turbo manifold build
Wicked man!! How do those manifolds fit?? Does the cross over pipe fit good to? I'm kinda wanting to get the same thing for my 91. Are you doing a 5" DP or a 4"?
Car: 87 Iroc
Engine: Turbocharged 5.7 Pro-Fl-XT
Transmission: 700R4 for moment
Axle/Gears: 3.25 9 inch
How does downpipe clearance look if you wanted to exit to the stock location without cutting anything? And with the AC box in place. Any room by cyl #8?
You won’t have room to run the downpipe back down on the passengers side above the manifold. It’s a little too tight back there. Car is a 5.3, downpipe is 4”, I would have done 5” but the turbo came with the reducer flange, my exhaust is about 1.75’ long so doesn’t really matter
Thank you 89FormulaLS! I have been watching the forums closely waiting to see if any one has tried this manifold setup. And Finally at last someone has tried it!!! First off, YOUR BUILD ROCKS. I was going to run the stamdard truck intake but you've proven the tbss intake will work nicely I will likely be plumbing my fuel system very similarly to the way you posted in the other cx racing instal thread created by battmann. Much cheaper then getting a 4th gen tank and messing around with that. One thing I was wondering about is what crossover pipe you bought because Holley sells a few different ones. Or did you fab that one up yourself?
Car: 87 Iroc
Thanks for the info.. Does your exhaust turn out and dump behind the front tire? Always a challenge to run a downpipe on these cars.
I’m running their crossover, I have a turbo 400, they make one specific for the th400
Could you possibly get a picrure of how close it is to the tire. I want to use this similar setup as a daily driver and I'm wondering if it will heat up the tire. Also do you think theres any way that the pipe could be continued to run under the car?
no problem, Ill post up a few pictures tomorrow. Ive got skinnies on the front but have some stock wheels I need to put back on.
I'm interested to know about your throttle cable. The throttle cable is obviously aftermarket but how it attaches to the firewall looks like you used the stock mount. Did you use the stock mount and cabin sleeve along with the stock clip and then use an aftermarket braided cable setup?
That’s exactly what I did, it’s the lokar cable hawks sells. I was pretty pissed when I got it and realized it’s just a generic throttle cable.... not thirdgen ls swap specific
cage and front end halfway done, going to start rewiring everything now and installing a 4th gen dash. I need to build a tubular radiator/intercooler support with some mounts for the pop up headlights.... and front bumper attachment brackets..... fitted the hoop as possibly high as I could, can slip about 5 pieces of paper inbetween it and the ttops, at 6'1 I need all the room I can get
Car: '87 Pontiac Firebird Formula 350
Engine: 5.3L SBE LM7
Axle/Gears: 3.47:1 Stock axle
Any updates on this build? It looks to by almost exactly what I'm doing with my Formula350.
Yeah, any updates? I'm close to pulling the trigger on something similar...
Car: '86 IROC Z
Hey man. Older thread I know but….. what motor mounts did you use? Both on the engine and on the K member. My passenger side manifold is hitting the the factory mount on the K member. I have dirty dingo swap mounts on the engine. Looks like I need to raise the engine about an inch or change the factory mounts on the k member. Thanks.
86transamws6
04-21-2003 03:58 AM
RoadRocket L98
04-25-2001 06:22 PM
CamaroX84
04-06-2001 12:26 AM
hookin88formula
10-25-2000 10:49 AM
