Camaro 2.8 Specific Fuel Injectors?
Old 01-22-2018, 08:30 AM
LiveIt!'s Avatar
Car: 1988 Camaro Sport Coupe
Engine: The All-Powerful 2.8l!! :P
Hey guys, I'm looking at buying re-manufactured fuel injectors for my 2.8 Sport Coupe, the 3.1's I've been running are starting to short at idle, esp. in morning or after long trips (with a voltage drop too! ) anyhow, I've heard about Fiero injectors being different than the ones that came in our 2.8 cars, and sellers are listing the same 2.8 injectors as compatible with Fieros, Camaros, Firebirds and even Cadillac Cimarrons equipped with the 2.8L 173Cu. In. V6 GAS OHV Naturally Aspirated engine. Is this right or do I need to be more careful in selecting injectors? I'm sure either way my fuel economy could use the help
Thanks in advance guys!!
Old 01-22-2018, 11:57 AM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Camaro 2.8 Specific Fuel Injectors?
https://www.southbayfuelinjectors.co...85-1992_1.html
Old 01-22-2018, 02:23 PM
LiveIt!'s Avatar
So across the 2.8 the 3.1 and the Fiero 2.8 the injectors are all 15 pounds? I thought the fbody 2.8 was 13 and the Fiero and 3.1 were 15? I have stock 1991 3.1 injectors in my car now and get the occasional running rich code. Just been a confusing subject for me haha
Old 01-22-2018, 02:26 PM
Engine: Lb9
Transmission: M20
I would ask member southbay08 if there is a difference.
Old 01-22-2018, 02:37 PM
LiveIt!'s Avatar
Will do and will report back here, thanks!
Old 01-22-2018, 03:29 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Reversing the equation for the BPC value, in the AZTY BCC the 3.1l injector flow is 16.5 #/hr. AZTY is the latest release for the '90 - '92 MPFI f-body's.
RBob.
Old 01-22-2018, 07:06 PM
southbay08's Avatar
We have been recommending the 15's for the 2.8/3.1
They actually flow a little higher than 15 so they are fine for that application.
Old 05-26-2020, 01:14 AM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Would these injectors work? They are similar to Bosch III. But they dont mention flow rate. Currently on a budget build. If it wasnt for my budgeting, I would definelty go for SB injectors. I have an 1989 V6 Firebird. 2.8l.
Old 05-26-2020, 10:13 AM
Engine: Lb9
Transmission: M20
I haven’t had good luck with the Bosch knock off injectors even with offset data.
Who knows they might work in a pinch.
Chevy86 IROC-Z (05-26-2020)
Old 06-22-2020, 06:25 PM
85Z28NOS's Avatar
Car: 85 Camaro & 84 Fiero
Engine: 350 HSR
Transmission: LT1/T56
Axle/Gears: 8.8w/4.10
I just installed a set of 0280155703 injectors in my 3.1 after getting a bad set of factory ones from a supposed rebuilder out of Cali. (I know better but I didn't check with Southbay as I did this before even going on TGO)
They are rated at 16lbs/hr so they are slightly bigger but so far are working good. These were originally used in Dodge 2.0/2.4 engines
Should also mention I did look at some factory Denso ones that are rated at 15lbs PN# YL8E-C2B but would require a EV6 to EV1 adapter for an additional $10
Chevy86 IROC-Z (06-23-2020)
Old 06-29-2020, 04:35 PM
85Z28NOS's Avatar
Engine: 350 HSR
I decided to try the Denso injectors using the adapters just to see how they compared
and these things work great! left the tune stock with these injectors. The previous bosch injectors were running just a tad rich but nothing I would complain about. these show a noticed improvement over those though. just another option to the old injectors
Dante93GTZ
01-09-2011 02:40 PM
formul8!!
09-20-2001 02:09 PM
Quick Reply: Camaro 2.8 Specific Fuel Injectors?
