92 z28 5.7 automatic?....
Old 01-22-2018, 05:11 PM
jdracing's Avatar
Car: 92 RS 5-speed Garnet Red
Engine: 92 RS Automatic White
Transmission: 84 Z28 Automatic Red
Axle/Gears: Top to bottom 3.30, 2.70, 3.70
OK,I found a 92 z28 auto with the 5.7......
Im not understanding the tech,so would like to know how many of these were made?...
I thought I read somewhere that all 5.7 92s were automatic as well....
Can someone tell me if all were autos,and how many autos were made with 5.7?
Thank You,
JD
Old 01-22-2018, 05:35 PM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 92 z28 5.7 automatic?....
https://www.thirdgen.org/tech/techdb.php
There was never a 5.7l manual produced
http://www.nastyz28.com/camaro/camaro92.html
Old 01-22-2018, 05:54 PM
jdracing's Avatar
That's what I thought,but the tech page looks to say the car was automatic option?
Do u know how many were made?...Car is $2000.00
needs paint and drivers seat is worn from bigger guy getting in/out....
has 130,000 on speedo,but he said it quit,and put about 20,000 more on car....
body is solid,strait,dash pad cracked,needs headliner...runs really good...
Is this FAIR,or GOOD DEAL?
Old 01-22-2018, 06:05 PM
Engine: Lb9
Transmission: M20
Fair deal, you might find a better deal in the classifieds section here.
Old 01-22-2018, 06:10 PM
jdracing's Avatar
I looked already,nothing near me...Im in N.C.
is the car the 1LE version?...
If so,there were 705 built,I think.,...
I thought It might be rareer with the 5.7 engine?
Thanks for your help....
Old 01-22-2018, 06:14 PM
Engine: Lb9
Transmission: M20
I doubt it’s a 1le you can check the options with the spid codes under the center console arm rest.
Old 01-22-2018, 06:54 PM
jdracing's Avatar
What does 1LE actually mean?...I can't find it's meaning?
He said he had it looked up and only 500 or so were made?
What is 1LE??
Thanks again,
JD
Old 01-22-2018, 07:28 PM
Engine: Lb9
Transmission: M20
1le were larger brakes with aluminum calipers.
Old 01-22-2018, 07:34 PM
jdracing's Avatar
i'll get codes tomorrow....
is it in glove box?...is that all i need?
thanks again,
jd
Old 01-22-2018, 07:42 PM
Engine: Lb9
Transmission: M20
Yes, or run the vin here to see if it produces the tpi codes .
http://www.compnine.com/vid.php
Old 01-22-2018, 08:35 PM
jdracing's Avatar
i do remember him saying it has the performance handling pkg....
is that a clue it's a certain car?...
Old 01-22-2018, 08:36 PM
jdracing's Avatar
i clicked on your link and it came up blank page?
Old 01-22-2018, 11:02 PM
Drew's Avatar
3,038 350TPI 92 Camaros.
5,197 1992 Z28 coupes.
GM did not track how many Z28 coupes, also had the 350 engine. Presumably the 3,038 includes some B4C (Police Pkg) RS Camaros. So some of those 3,038 weren't Z28s.
Check the VIN number. 8th digit is an "8" on 350 cars, "F" on 305s, "E" on econo-toilet bowl injected 305s, and "T" on six cylinders.
Don't even worry about the small details. The vast majority of thirdgen Camaros are 305s. Most of those are low output sub-200hp boat anchors. Any 350 TPI Camaro is in the minority. When you get into the later years, production numbers were down because the 93-up body style was coming soon, and the thirdgens were long in the tooth. There's not much reason to even research 1LE. It's probably not a 1LE, and the 1LE package is mostly a bunch of monkey spank anyway.
If it's a decent car, and you like it, buy it.
Old 01-23-2018, 06:32 AM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
2,306 Z28 w/L98
Old 01-23-2018, 02:03 PM
jdracing's Avatar
will these codes read as if is a b4c?....owner of car says it is a b4c...
i need to know b4 i purchase?...
thanks for any help.
jd
Old 01-23-2018, 02:15 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
jd
Not a B4C. Just a regular Z28. All B4C cars should have the B4C RPO code. Also, pretty sure B4C was only available on base RS cars.
Old 01-23-2018, 02:35 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
Ok. You're getting a little confused here. The 1LE was a brake package that came on cars that were ordered with the 350 engine, G92 performance rear axle and AC delete, or on a 305, 5 speed with G92 and AC delete. If the car has AC, it's not a 1LE (unless it's a B4C, see below)
G92 was a performance rear axle option. On this car, the standard gear was 2.73. With G92, it was a package of other options that also gave 3.23 rear gears. This is was what you might hear as the performance model.
B4C was a police package or government use. The B4C option was used on the RS cars, not the Z28s. Can you say sleeper? This was the only way to get a 350 in the RS. If I remember correctly, all '92 B4C equipped RSs also had the performance brakes (1LE).
Old 01-23-2018, 02:51 PM
PurelyPMD's Avatar
Engine: LB9
Yes, that is correct. in 1992 all of the B4C's got the 1LE brakes, in 1991, only 13 of them did.
The car above is NOT a 1LE or a B4C but it is a nicely equipped L98 Z28.
Old 01-23-2018, 06:30 PM
Drew's Avatar
Would be nice if a moderator could combine the thread from elsewhere on the forum with this one. Kinda exasperating answering the same questions in multiple threads.
Old 01-23-2018, 07:57 PM
scottmoyer's Avatar
Where is the other thread, Drew. I didn't see it. or did I?
Old 01-23-2018, 08:11 PM
Ty92Z's Avatar
Car: 1992 Z28 1991 RS
Engine: LB9 LO3
Transmission: 5 speeds
https://www.thirdgen.org/forums/cama...ese-codes.html
Old 01-23-2018, 08:31 PM
scottmoyer's Avatar
Oh. Yeah, I wouldn't see that one. Not looking for cars to buy right now.
Old 01-23-2018, 09:42 PM
Drew's Avatar
Me neither, but "new posts" button.
Old 01-24-2018, 05:35 AM
PurelyPMD's Avatar
Engine: LB9
I read the forum the same way. User CP first, then New Posts.
Old 01-24-2018, 10:09 AM
scottmoyer's Avatar
Yeah, not me. I have a bookmark for the History forum, then I manually back out to the different forums I might be interested in looking at. When I had my Charger Scat Pack, I tried that option when viewing their forums and found so much fluff that didn't interest me any that I needed to sift through. Maybe I should try it here. You know, get into the 21st century!!
Old 01-24-2018, 06:12 PM
jdracing's Avatar
Well,I do appoligize for your time......If I can,i'll delete the whole thing.....
Reason I asked here,was because at the time no one had answered my questions....
I really do appoligize for being so much trouble.....
JD
Old 01-24-2018, 06:16 PM
Drew's Avatar
No, it's fine... Things happen, no big deal. JT already closed the thread. It's just nice to have things in the right place so that people can find those threads in the future. Kind of like the card catalog at the library.
Carry on.
Matt Bane
12-19-2009 10:11 AM
Yak
12-23-2004 03:30 PM
morale
07-15-2003 03:46 PM
cridom
06-09-2002 01:31 AM
Quick Reply: 92 z28 5.7 automatic?....
