Dyno Don header gaskets
Looks like the Earl's gaskets he recommends are being discontinued - can't get replacement inserts for my gaskets.
I like the Remflex offerings but they don't seem to have a direct 1.5x1.5 round port gasket. They have 1.437 x 1.437 that says it's for weld bead style headers.
What's going to work? Earl's is dead to me if I can't get the inserts. Looks like Holley is pushing the Mr. Gasket products instead - more profit for cheaper chinese junk is what it seems. F**k you Holley.
GD
GD
Re: Dyno Don header gaskets
I use Mr Gasket #150. 1.5" round ports. But they are just regular gaskets. I spray them with PAM cooking spray.
Isn't PAM just aerosol vegetable oil? If that works well then perhaps something that would withstand even greater temps would perform even better? Just a thought. I mean basically it's a lubricant and keeps the gasket from bonding to the metal right? We use this stuff for brake slide pins and it's good to 3000 degrees:
What about the Mr. Gasket Aluminium layered gaskets? Part #7400G
https://www.holley.com/products/gask...ts/parts/7400G
GD
GD
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
all i have to say is if you CAN find remflex gaskets, or the ones you posted about will work, GO WITH THEM. They have been the BEST header gaskets i have ever used in the past 9 years.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
These are still available....
https://www.summitracing.com/parts/ear-29dc3berl
https://www.summitracing.com/parts/ear-29d03b3erl
Also these...
https://www.ebay.com/itm/Remflex-Sma...4383.l4275.c10
Also these...
https://www.amazon.com/Permatex-2035...00HFLAL0Q?th=1
GD
GD
That's the idea. I will have to try the Permatex stuff. Pam will still work for the carb gaskets.
Remflex does have a 1.5" round offering. 1 9/16ths actually (1.5625).
I've been using them with my RHS Vortecs. Possibly the best header gasket ever.
http://catalog.remflex.com/CHEVROLET...ket_p/2004.htm
to bring back an old thead, but looking for some gaskets for a set of don's headers I have coming. are the ram flex working well for guys long term? I honestly would like to run some mls gaskets if they make some that fit the ports. they are D ports right? my heads are D too
interesting. they recommend 2065 which looks like a d port, odd the headers are more square. I only saw one review on the ram tech and it trashed them pretty badly. which reminded me of every cheap composite I've used haha. but who knows what that person did.
I guess I'll try them. wonder if I should get the round 2004s or the 2065. I absolutely hate header leaks and changing gaskets. last time I went with some copper round gaskets and those bolts with the set screw in the middle that locks the bolts in place and they did well with the cheap headmans but don't exactly match the ports in the head, they hang over a bit on the top, or I'd just reuse the copper.
mls I've only used on newer ls and Ford stuff and always just reusing the factory and never had a issue. that's why I was thinking of trying the MLS cosmetic.
hmm
hmm
I own a performance shop and we use a LOT of Remflex (not Ram Tech - whatever that is) gaskets, and have never had a problem. As with anything you need proper tools and know how to use them.
Remflex is unlike anything you have used before. It is a compressible graphite gasket. Not a composite at all.
GDF
GDF
I used the Earls "D" port inserts once,... This is the poorest fitting of the ports when using the "D" port inserts on MY set of DD headers....
Here's how they fit once they got trimmed:
That set has been installed for the last 4 years with no issues yet. Next time I'll probably go with the full faced replacement insert, then cut to fit.
https://www.summitracing.com/parts/e...2erl/overview/
I am running the Earls gaskets for my setup with decent success... One thing to consider, that I think I have issues with, is the thickness of the gasket moving the headers out enough to change fitment. My passenger header is VERY close to the frame rail. If I could find a thinner gasket that sealed as well I would run it to help with my frame clearance.
Engine: 4++,350 & 305 CIs
Felpro 1404 or 1405 with 1" long bolts work very well and don't break the bank. I've never had to replace a set and have used the same set on several different combos without issues.
LT1Formula
07-22-2014 01:12 PM
