BIN to start from?
Old 04-14-2018, 09:56 AM
Stuman's Avatar
Car: 1989 Z28 Camaro
Engine: removed 406 building 383
Transmission: 700R4 swapping to T56
Axle/Gears: Ford 9" 3.70 going to 4.10 or 4.30
BIN to start from?
Hi, I have an 89 Z28 that had a 406, 30 lb. injectors and 700R4 and 3.70 gear. I am changing the car to a 383, 36lb injectors and a LT1 T-56 and probably a 4.10 or 4.30 gear.. I have ordered a fast burn, cables, ALDL extreme, G1 adapter and two chips. My question is about the BIN file to start with. I have a custom made chip in the ECM that ran the 406 combo with the 700R4 that I could copy and use as a starting point or I found a BIN file on Gearheads EFI for an 89 Corvette 383 with a 6 speed. Trying to determine which starting point would be better. Any input would be appreciated. Thanks
Old 04-14-2018, 10:23 AM
ULTM8Z's Avatar
Re: BIN to start from?
Depending on what other changes there are besides cubes, If your previous bin ran the engine well, I'd start with that and just make the necessary changes to switch from manual to auto.
Old 04-14-2018, 11:52 AM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
APYP would be a good start with injector constant changed.
http://www.gearhead-efi.com/Fuel-Inj...Information-6E
Old 04-14-2018, 01:08 PM
Ronny's Avatar
Just for your info the CID is refleted in the base pulse constant. My 396 SB at 43 lbs FP and 24 lb injectors is 119 for all values in that table as it is a vac ref FPR. I would use a automatic .bin for sure. I think that is a safer way to go. I believe there are several parameters in the .bin specific for tranny. A 350 auto bin with a change in BPC should do it .
Old 04-14-2018, 01:09 PM
Stuman's Avatar
Thanks guys, I am going from Edelbrock Performer heads and ACCEL/Lingenfelter 219/219 cam with Super Ram to AFR 210CC and Comp XFI 230/236 8-467-8 and Stealth Ram.
Old 04-15-2018, 10:11 AM
Ronny's Avatar
With the larger cam you may want to add some timing at idle. Reversion if present dilutes the density of the air/fuel mix and that requires more time to burn the gases over the piston top. . Open loop[ idle may be helpful as well.
Old 04-16-2018, 07:38 PM
Stuman's Avatar
I am trying to get familar with Tuner Pro RT but I dont see a place to address the base pulse constant. I have been going thru the Scalars, Flags and Tables and try to figure them out.
Old 04-16-2018, 07:45 PM
Engine: Lb9
Transmission: M20
Injector constant ?
Old 04-16-2018, 07:54 PM
Stuman's Avatar
Thanks for the reply, base pulse constant was referenced by Ronny and Injector constant by yourself but I dont see these anywhere..
Old 04-16-2018, 08:00 PM
Engine: Lb9
Transmission: M20
To change your injector size use single and double fire fi size @ 40 Psig in the scaler.
Old 04-16-2018, 08:07 PM
Stuman's Avatar
Thanks, I'm using 36lb injjectors rated at 43.5 psi. Do I enter them as 36lb or 35lb at the lower pressure? I am reading hours each day everything I can find on this Tuner Pro and prom tuning but its alot, seems I always have more questions .....
Old 04-16-2018, 08:14 PM
Engine: Lb9
Transmission: M20
I would go with 36#hr and fine tune with your maf tables.
Here’s a good read on maf tuning
https://www.thirdgen.org/forums/atta...air-flow-tuned
Old 04-16-2018, 08:16 PM
Stuman's Avatar
Tuned, thanks for the info, I know us newbeis can be aggravating...I will read that material.
Old 04-17-2018, 08:55 AM
Ronny's Avatar
BPC vs VAC? Correction: The Utiity will calculate the values in table for you. That is for vac referenced(TBI). Port fuel (me) they are the same top to bottom.
Old 04-17-2018, 09:51 AM
Stuman's Avatar
Ronny, I am using a $6E definition file and APYP bin and I do not see BPC vs VAC or VAFPR. The link Tuned gave me last night is the best, most detailed article I have found yet on the subject. I am reading now and going to print a hard copy for reference.
Old 04-17-2018, 02:08 PM
Ronny's Avatar
Look in constants for Base Pullse constant. A single value.
In tables it is called BPC vs VAC.
Not sure why you would not have it. My port fuel .bin is 3006_bin I believe all EFI .bins have a BPC. See my correction above thread.
Can you search the TunerPro 6E def file for it?
Old 04-17-2018, 07:31 PM
Stuman's Avatar
I will look again for the BPC vs VAC in the morning when I get home from work. Thanks
Old 04-17-2018, 08:10 PM
Engine: Lb9
Transmission: M20
This is $6e mask not Dynamic EFI or tbi
Old 04-17-2018, 09:45 PM
Stuman's Avatar
I am stuck at work tonight but I have been reading and reading again the "Mass Air Flow Tuned Port Injection Programming and Tuning Guide" that Tuned gave me the link to. It seems that the 89 MAF 6E is different from the 86-88 MAF 32 and 32B. A quote from that document says
"The PW based tuning tables went away in $6E. Gone. $6E uses the MAF airflow and calculates an injector PW". So I guess you tell it what size injector you are using in single fire and batch fire and adjust fueling by moving the mass air flow tables up or down. Does this sound correct to you guys?
Old 04-17-2018, 10:27 PM
Engine: Lb9
Transmission: M20
That’s the approach I use when tuning $6e
Old 04-17-2018, 11:40 PM
Stuman's Avatar
Thanks Tuned and Ronny for the help and guidance. I'm sure I'll run into something else to stump me and I'll be asking questions again. Thanks again for the help.
doc
DIY PROM
17
05-12-2021 08:57 PM
thafaz
DIY PROM
07-30-2004 03:35 PM
Greenshamrock77
DIY PROM
06-09-2001 01:08 AM
BlueZ89
DIY PROM
04-02-2001 10:52 PM
Quick Reply: BIN to start from?
