Accident
Old 04-18-2018, 09:08 PM
SketchyZed's Avatar
Car: 1991 camaro z28
Engine: 5.7
Accident
So I was in an accident and I was wondering about if this was fixable
Old 04-18-2018, 09:14 PM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Accident
Ouch , looks like it needs a new quarter
Old 04-18-2018, 09:44 PM
Jacobaxeman's Avatar
Car: 1991 Camaro RS
Engine: Hot 355ci
Transmission: Beefed TH350
Axle/Gears: 4:10
Re: Accident
Definitely fixable; New bumper and quarter and she'll be looking brand new!!
if you don't mind me asking, what happened?
Old 04-18-2018, 10:23 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
Re: Accident
Hows the drivers side? Any movement? Looks like a hard hit and these cars being unibody tend to transfer impacts thoughout the chassis.
Old 04-18-2018, 10:31 PM
SketchyZed's Avatar
Engine: 5.7
Re: Accident
I was at a four-way intersection turing left both lights are green I thought I could have made it I thought he was further out than he actually was I'm almost completely out of the middle of the road he then realizes Stomps on his brakes and then his car pulls to the right and slams into me my rear side but by that time I already made it a cross..
As for the other side nope nothing is messed up frame is straight the strange thing is after this accident the infl rest light went off before is it would always stay on but now gone
Old 04-19-2018, 07:41 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Re: Accident
Honestly I think you might be able to push a lot of that out, I don't see any deep creases or anything just a big dent. I'd massage it from the inside and you might be able to get by with a light skim of bondo.
Old 04-19-2018, 08:46 AM
SketchyZed's Avatar
Engine: 5.7
Re: Accident
I got some more picturs
Old 04-19-2018, 09:46 AM
82tarecaro's Avatar
Re: Accident
The sail panel ripple is what will be the bitch to get right. You can see the quarter also pulled away from the top of the door. If you can find a clean quarter and sail panel, that would probably be your best bet.
Old 04-19-2018, 10:46 AM
BOTTLEDZ28's Avatar
Transmission: A4
Re: Accident
Buy a brand new quarter panel, rear bumper and taillight. The body shop will cut the old quarter out and just replace it. I did this on an old car I had about 20 years ago. To keep cost down, you can see if the body shop can blend the paint but with it being a hardtop, I doubt they will do it. So, it looks like the entire roof and driver side quarter will need to be blended. Plan on getting the entire back of the car repainted as well as the passenger side door.
Old 04-19-2018, 04:57 PM
SketchyZed's Avatar
Engine: 5.7
Re: Accident
How much would you think it would cost to fix
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
Transmission: Dynamic Racing Reverse Manual 700r4
Axle/Gears: 9 Bolt 3.45
Re: Accident
Just get a new quarter. as someone above said, the sail panel will be hard to message back, especially with the body line running through it.
Old 04-19-2018, 07:02 PM
SketchyZed's Avatar
Engine: 5.7
Re: Accident
okay
Old 04-19-2018, 08:28 PM
SketchyZed's Avatar
Engine: 5.7
Re: Accident
found out i might be at fault but wont know for sure till monday so i have to sit and wait till then to fix her but my question is there anything i can do to get it at lest looking some what better, oh and i found a small hole right under where the spare tire goes its like a seam was ripped open and the metal frame of the rear bumper got smashed threw
Old 04-19-2018, 08:43 PM
88IROCvertZ's Avatar
Car: 1988 IROC Z Convertible
Engine: 305 TPI (LB9)
Transmission: 700 R4
Axle/Gears: G80 GU2
Re: Accident
If you’re not at fault, you might be able to get a top dollar fix.. usually damage to the rear of these cars would total them because of the unibody.. you can’t fix them right for cheap enough.. you can replace everything in the front pretty easy even the frame.. the rear was always tougher..
It doesn’t look like a super hard hit, but a hell of a job to get it done right
Old 04-19-2018, 08:50 PM
SketchyZed's Avatar
Engine: 5.7
Re: Accident
yeah anything i can do after all this just to get things moving
Old 04-20-2018, 10:45 AM
SketchyZed's Avatar
Engine: 5.7
Re: Accident
Could I just get a 2x4 and a rubber hammer to get most of it out
Old 04-20-2018, 10:50 PM
ZsTransAm's Avatar
Car: 89 Trans am
Engine: 5.7 TPI
Re: Accident
The dent won't just pop back out if you hammer on it. Its possibly fixable for someone who is an expert bodyman, but unless you know what you're doing then you'll screw it up worse. Most likey a shop will want to put a quarter on it and blend the roof. If your trying to save a few bucks they can shoot a clear blend in the other sail panel to avoid painting the other quarter.
Fixing it will probably cost more than the car is worth to fix. Estimates are free though, take it to a few body shops and see what they say.
Old 04-21-2018, 07:05 AM
SketchyZed's Avatar
Engine: 5.7
Re: Accident
okay it was worth a shot
Old 04-21-2018, 09:20 AM
Car: 1983 Z28
Re: Accident
Yes, you could. And you wouldn't make it worse either. Just watch a couple youtube videos on the basics of dent removal and go at it. That dent is BIG but its not BAD.
Worst case scenario is you end up buying a new quarter to replace it with anyway.
If you were doing this on a mint 69 ZL1 or something then I'd be a little more cautious, but it's a thirdgen. parts are plentiful. it'll be a good learning experience.
Old 04-21-2018, 01:43 PM
SketchyZed's Avatar
Engine: 5.7
Re: Accident
yeah thats one thing i said im gonna be replacing it anyway why not learn from it who know this might kick off an auto body career for me
Old 04-21-2018, 03:30 PM
ZsTransAm's Avatar
Car: 89 Trans am
Engine: 5.7 TPI
Re: Accident
Not bad? If the shop writes to fix it, I bet it'll be 10+ hours on the dent alone. I have 2 years of experience in bodywork (before I switched to the paint) and I would never touch it myself. Fixing a dent isn't as simple as banging on it with a hammer and filling the rest with bondo, its about understanding how metal moves. If he takes a hammer to it then it'll be that much harder for a bodyshop to fix it.
Please, before you mess with it take it to a bodyshop and see what they say.
Old 04-21-2018, 07:27 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Accident
I believe your statement #1 that I quoted above to be correct .
With that being said , sure , a free estimate from a professional bodyshop couldn't hurt , but , if it truly is more to fix it than it's worth the guy might as well dive in and learn whether or not he has the mechanical/artistic aptitude(s) to do bodywork right . Some do , some don't , who knows till they really try , and as the guy himself said ; "This might kick off an auto body career for me" .
Old 04-21-2018, 11:11 PM
ZsTransAm's Avatar
Car: 89 Trans am
Engine: 5.7 TPI
Re: Accident
If he finds out that the cost would be so high that he'd never be able to afford to fix it then I agree, if he wants to try then have at it. But after he does, most shops won't touch it. Also, speaking from experience, bodywork is something best learned starting with small dents and working your way up as you gain an understanding how to do it. Maybe he would be good at autobody but he's setting himself up to fail if he starts with this. You wouldn't run a marathon before you've tried jogging around the block, would you?
Old 04-22-2018, 10:07 AM
SketchyZed's Avatar
Engine: 5.7
Re: Accident
monday im going out asking body shops around town and see how much it would be
Old 04-22-2018, 10:16 AM
SketchyZed's Avatar
Engine: 5.7
Re: Accident
and also i know some people who wouldn't mind working on it if the shops say no or are too expensive a family friend who is a diesel mechanic but does body work on the side he wouldn't mind helping out
Old 04-22-2018, 04:47 PM
ZsTransAm's Avatar
Car: 89 Trans am
Engine: 5.7 TPI
Re: Accident
That's good to hear, hopefully you can save it then. Looks like a pretty solid car aside from the damage.
Old 04-23-2018, 06:19 AM
Car: 1983 Z28
Re: Accident
Except that it is? If you aren't replacing the quarter then you are going to have a skim of bondo on it (not FILLING. . . but a skim). The backside is accessible, there are no sharp creases to worry about acting wonky.
Glad you're having a shop look at it, I recommend sitting down before they tell you their number
Old 04-23-2018, 07:14 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Accident
Most of that could be worked out from the inside and not need a new quarter. I've seen a lot worse fixed. The trouble is finding someone that's good. Some PDR guys dig a challenge to hone their skills so that's an option too.
Old 04-23-2018, 09:15 AM
Drew's Avatar
Re: Accident
That scenario is called "Failure to Yield". AKA you were turning left, you were supposed to yield.
Don't start trying to fix it yourself until that is your last resort. Even if whoever ends up cutting off the quarter and reskinning it, they'll probably want to pull the dent first to get the substructure right.
And whoever said "it's open on the back side" probably hasn't tried to work around the spare tire mount.
Old 04-23-2018, 05:08 PM
SketchyZed's Avatar
Engine: 5.7
Re: Accident
got a quote today $3,833.25 was the cheapest at a big time body shop near me but i know i get get it cheaper with a family friend
Since its cheaper than i thought it was gonna be im not gonna worry about fixing it myself and just wait a few months to save up and fix it
Old 04-24-2018, 07:37 AM
Car: 1983 Z28
Re: Accident
Cool. Might be able to bring that down a bit if you provide your own parts (tail light, bumper cover, etc).
Old 04-24-2018, 10:44 PM
ZsTransAm's Avatar
Car: 89 Trans am
Engine: 5.7 TPI
Re: Accident
You really don't know what you're talking about. When you have 10 years experience in autobody come back and tell us about dent removal.
Fortunatly the OP can afford to fix and won't be taking your advice.
Old 04-25-2018, 09:35 AM
Car: 1983 Z28
Re: Accident
You're right, I don't have 10 years, only 5. Good luck to the OP, it may be a long road but it feels good when you finally finish it up (whether it's by your own hand or someone else's). Then you find something else that needs fixing lol.
Old 05-05-2018, 07:22 PM
SketchyZed's Avatar
Engine: 5.7
Re: Accident
i found a guy who can do it for 2k to fix it and paint the whole car i found him through a friend and he showed my some of his work
Old 05-06-2018, 07:59 AM
dagwood's Avatar
Received 1,160 Likes on 653 Posts
Car: 1986 Camaro Drag Car
Engine: 383 on Ethanol
Transmission: Automatic
Axle/Gears: 3.90 Currie 9 inch
Re: Accident
I work at a body shop, and have been in the business for 16 years. That is not a "bang it out and fill it" kind of job. That is a new quarter panel job. No reputable body shop would ever even think about repairing that messed up quarter panel. Some fly by night dude might be willing to try it, but it'd NEVER be right. You have splitting seams on the back side, and damage around the taillight area, sail panel, and wheelwell where the body lines change. Fix it right.
I actually laughed out loud when I read about most of that popping out from the inside and only needing a "skim coat" of filler. So so so WRONG.
Old 05-06-2018, 02:42 PM
SketchyZed's Avatar
Engine: 5.7
Re: Accident
i haven't talked to the guy who would do the job yet i don't know how he would fix this he might try to pull it out or replace it i just have to talk to him about it, and also if there is just a tiny chance i can save it i will take it because if it messes up i just need a new panel
Old 05-06-2018, 07:04 PM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
Re: Accident
The pain of expensive correct bodywork will go away far faster than the despair of poor quality medium priced work.
Top quality isn't expensive - it's priceless!
Old 05-06-2018, 07:47 PM
82tarecaro's Avatar
Re: Accident
So true.
Old 05-06-2018, 10:33 PM
dagwood's Avatar
Re: Accident
Amen, brother! Couldn't have said it better myself!
Old 05-07-2018, 06:14 AM
Car: 1983 Z28
Re: Accident
that's good!
Old 05-13-2018, 12:02 AM
ZsTransAm's Avatar
Car: 89 Trans am
Engine: 5.7 TPI
Re: Accident
Hopefully he's a better bodyman than he is a painter. He's not taking off headlights, taillights, grills, mirrors, door handles, and he's doing a poor job of scuffing the paint too. Not trying to scare you but I seriously doubt this guy will be able to fix that quarter. You get what you pay for and you're not paying a lot.
Old 05-13-2018, 10:02 AM
SketchyZed's Avatar
Engine: 5.7
Re: Accident
oh i know hes sketchy im most likely not going to him but if no one else will do it
Old 05-15-2018, 08:46 AM
SketchyZed's Avatar
Engine: 5.7
Re: Accident
So far I called two places to see how much it would be to replace my quarter they said they would call me back for a price one was a week ago the latest one was a day ago
Old 05-15-2018, 07:54 PM
SketchyZed's Avatar
Engine: 5.7
Re: Accident
[UPDATE] i got a call form a body shop while i was at work the said just to replace the quarter would almost be 2k but they wouldn't know for sure so i need to bring it up there next time i can
Old 05-15-2018, 09:01 PM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Re: Accident
I.... don't want to work.
I want to bang on the dent all day...
I... don't want to pay.
I just want to bang on the dent all day!!!
Old 05-18-2018, 07:44 PM
SketchyZed's Avatar
Engine: 5.7
Re: Accident
I hate waiting on time to pass but at least it gives me time to decide if i want to change the color or keep it the same, what colors would you say are the most common to paint a camaro?
Old 05-21-2018, 05:58 AM
Car: 1983 Z28
Re: Accident
Black, Red, Blue, and White.
Just based on what's on this site.
Old 05-21-2018, 10:37 PM
ZsTransAm's Avatar
Car: 89 Trans am
Engine: 5.7 TPI
Re: Accident
I think if you want a complete paint job with that repair, especially a color change, it'll double or triple your bill. But if you do, I vote black or silver.
Old 06-09-2018, 05:58 PM
SketchyZed's Avatar
Engine: 5.7
Re: Accident
Right now im just gonna get it fixed gonna try and hunt down some parts for cheap too to see if i can make it cheaper also see if i can just get the shop to fix it and put primer on it and have some one else paint it if it will make it cheaper
Old 06-09-2018, 09:30 PM
NoEmissions84TA's Avatar
Re: Accident
Have you seen this? https://www.thirdgen.org/forums/memb...ml#post6149847
Quick Reply: Accident
