Wiring Help- fuse keeps blowing
Old 04-19-2018, 08:28 PM
JB89TA's Avatar
Just picked up an 89 T/A yesterday, so excited to have it back. Only issue I have is the fuse keeps blowing that controls the headlights pop-up/down and I also think that is the same fuse that has dash lights and running tail lights (they aren’t working either). When I replaced he fuse, the headlights did go down but it blew again. I’m assuming there is a wiring issue somewhere. Any idea how to find it and deal with it? Thanks for he help!
Old 04-21-2018, 01:34 PM
FluffyK's Avatar
Car: 1988 IROC-Z
I'm assuming that the fuse you say keeps blowing is the CTSY fuse?
It appears that the CTSY fuse feeds power to the Headlight Switch to engage the Headlight Door Module On or Off. When the Headlight Switch is off, 12v from the CTSY fuse is fed to the 'Off' connection on the Headlight Door Module, and vice versa for the 'On' connection when the headlights are switched on.
It seems like your Headlight Door Module is drawing too much current when the Headlights are switched on and that's what is blowing the CTSY fuse. I'd check to see if pin 'A' (the 'On' connection) on the Headlight Door Module is grounded and is therefore blowing the fuse.
Here's a wiring diagram showing the Headlight Door Module aswell as the Headlight Switch:
Old 04-21-2018, 09:57 PM
JB89TA's Avatar
Re: Wiring Help- fuse keeps blowing
Thanks for info... looks like this may be a bit compicated for me as wiring isnt something I have any experience with. Ill see what I can find.
Old 04-21-2018, 10:25 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Simple answer, unplug the headlight module, if everything proceeds to work as it should, you have found your culprit or at least the part of the wiring being affected, if it pops still, then the issue resides elsewhere in the schematic of that fused circuit. If everything still works with the module unplugged, turn the headlights off, plug the module back in completely, and see if unplugging one headlight motor at a time affects the fuse, as a motor can create too much draw too as it ages.
Old 04-22-2018, 08:45 AM
JB89TA's Avatar
That makes sense... Ill give that a try.
Old 04-22-2018, 09:53 AM
JB89TA's Avatar
No luck. Unplugged both, flipped the switch and the fuse blew again. It’s my understanding that the other options on that fuse “tail” fuse, is the instrument cluster lighting, tail lights and not sure what else. Seems like there is a wiring issue but I’m not confident in how to find it.
Old 04-22-2018, 10:05 PM
84redta's Avatar
I'll pull the schematic tomorrow for you. Shouldn't matter but 305 tpi or 350 tpi? If 305, auto or stick?
Old 04-23-2018, 05:54 AM
JB89TA's Avatar
305 tpi stick. Thanks!
mizz0313
05-13-2015 10:42 PM
FAST RS
02-13-2003 09:33 PM
VampireHunterC
12-29-2002 02:44 AM
Flash84Z28
Car Audio
08-15-2001 08:02 PM
89ROC
11-24-2000 05:50 PM
Quick Reply: Wiring Help- fuse keeps blowing
