MSD 6A to coil in cap style distributor?
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
EDIT: This is super confusing. See post #2.
Got this setup a while back from a friend who had it on his thirdgen. Not sure how he had this wired up.
I see you unplug the ignition module inside the distributor and plug the black connector into the dist. And you ignore the tach output on the dist and connect the tach wire to the 6A box.
But where do you plug these loose spade connections in to?
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Re: MSD 6A to coil in cap style distributor?
After watching a few youtube videos on how to wire the 6A to an HEI distributor... I honestly have no idea how this was wired up previously!
The magnetic pickup plug on the MSD box is crusty as if nothing was ever plugged into it.
Going to just hack all this off and wire it up properly.
Can I buy the plug for the magnetic pickup connection on the MSD box? Rather not cut the pigtail off.
You know there are instruction sheets out there to explain how to install an MSD? Because shitdawg, I haven't even looked at them in a decade and I know you don't use the crank trigger harness with a stock distributor.
You'll shoot your eye out.
Here, five minutes Googling, 20 seconds scanning the instructions.
Full instruction PDF - https://static.summitracing.com/glob...s/MSD-6201.pdf
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
That's not for an HEI setup. And yes, you do use the magnetic pickup with the stock distributor. Know where I read that? The instructions. Because I DID Google it. Then I even posted that I found further information via YouTube.
I answered my own questions. Going to pick the magnetic pickup cable up and wire it in.
If you're sure you've got it all figured out, then good for you. If not, look through the instructions until you get to the diagram that matches your distributor/coil/module, and read it.
If you're using a 4-pin module, you probably don't want the 6ft extension cable. The PN 8861 is the 8" harness to connect the pickup in the distributor directly to the box. With the 5 or 7 pin modules, or any of the other ignitions used stock on thirdgens, you just tap into the existing wiring at the coil.
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Sorry, was dealing with some asshats on FB groups for the same question and got a bit frustrated with the whole thing there.
I do know the setup was installed and working on an HEI thirdgen, so I really have no idea how it was all connected. Those extra spade connectors really threw me.
Ended up hacking that whole mess off and just wiring the two from the MSD box to the C- and B+ terminals on the cap & grounding the center pin.
Ordered the MSD 8861 magnetic pickup adapter as well as the 8860 pickup cable to get the dist signal to the MSD box.
Then I believe it's connected correctly according to the instructions I found!
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Ok, so found what he had done to use without the magnetic pickup. Second setup.
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
Good thread
I've been wondering about this
How would this work for going from hei to msd 6 box and billet msd distributor . My setups too big for stock style 7pin module so ive moved to the msd distributor non hei . Got spark working from the box but it's cut out signal to the ecu for the injector pulse.
mike_c
02-03-2014 05:35 PM
camaro1122
07-24-2011 03:18 PM
Looksthakill
Alternative Port EFI Intakes
02-13-2011 08:32 PM
nichoulas83Z454
06-07-2003 05:14 PM
