Ford 9 inch and bmr torque arm
Car: 1991 camaro z28 convertible
Engine: 5.0 v8
Axle/Gears: 9 bolt 3.23 borg worner
So I’m almost finished with the ford 9 inch install, the rear is from trick chassis and I got an adjustable torque arm from umi, the problem is wich ever way I try to bolt it down the mounting bracket on the torque hits the rear.. has anyone ever used this combo? Or have any ideas on what to do
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: Ford 9 inch and bmr torque arm
Some 9" Ford castings require clearance for of the case ribs to fit the torque arm.
Engine: 5.0 v8
well the mount on the torque arm has 4 bolt holes, And the pictures in the instructions use the 2 bolt holes closest the passenger side when I try to mount it on the support of the rear the mount in the torque arm hits one of the bolts for the support, if I use the 2 closets to the driver side then it hits the center section of the rear
Engine: 5.0 v8
Got it, had to grind down some of the bracket for the torque arm and everything fell into place
tinkerinmatt
01-18-2013 10:11 AM
QwkTrip
02-16-2011 10:51 PM
3833rdGen
03-10-2010 02:52 AM
ChevyCamaro4lif
01-21-2004 09:51 AM
