Calling james C for help(door handle)
I see you have a parts assembly on the exterior door handle any more pics? I got my new handle on and the top clip/rod connected but cant figure out where exactly the bottom part of the rod goes into. the rod has a small 90 kink in it then proceeds going straight down
Re: Calling james C for help(door handle)
The end drops in the top of this arm on the latch
We were discussing this very thing in another thread.....I drew a diagram. Post #7.
https://www.thirdgen.org/forums/body...-problems.html
Drew in that pic, it looks like there's a perfect hole on the SIDE. Important to note (as you stated) that the rod goes in the TOP, not the side. When I redid my doors, I thought the side was the obvious place to put it. Doesn't quite work. Again, as you stated, it definitely goes in the TOP hole.
seent he diagram had it together within 1 minute now that I understood it but now my latch wont open for the striker post. its stuck and wont let the door shut???? the handle released the door once but now i cnt close it
So had a panick the door wouldnt shut, and I park my car outside. I ****ed with it a bunch and finially the indoor lever released the latch I could close it but now I cant get it open. all the rods are hooked up. however the lock slider doesnt fit perfect in its slot. when i push the the fullw ay forward only a little orange/yellow mark color shows up. I'm just glad I got the door shut before it rains though.
Hawkeye1980 (11-02-2019)
My driver door is still stuck shut. It happend after I put the lock slider back on I must have pryed on it to hard to get it back into the plastic? it move back and forth and clicks but maybe slightly less than the passenger door?
Trying not to stress over this but I am a little lol. If all fails can I take the sail panels off and undo the striker? if all fails how will I get this dang door off?
I'm out of idea I'm praying on some knowledged fellers here for advice!
Have you tried to push the door open when the handle is lifted? I had mine do that one time because the rods were dirty. Maybe you bent yours slightly with the same result. It would release the striker 99% percent of the way. A slight push wouldn't do it. Had to give it a good palm smack!
Next would be to take off the black door trim that mounts right along the top of the door. Should give you some access into the door to play around in there a litttle bit.
Whether you use pliers,or just your hands, from the inside OR the little piece of metal the lock tap clips to......I'd work that lock lever back and forth until it releases.
I did bend the rod a little bit the one to the exterior handle trying to figure it all out, after was explained to me earlier I had it in there as fast as a GM assembly line worker. I bent it back best I could but the door handle worked up until i put the plastic slider lock back on its piece by the interior door handle
I'm not sure what I'm gonna do. Obviously I dont want to tear **** apart and take the door off since when you tear into old **** more stuff usually breaks!
Yes I;ve studied that diagram off another thread!
It's all hooked up like so, but my door just wont open. I think I bent the lock rod when i tryed to pry it back/squeeze it into the plastic casing that goes around the whole handle assembly. The outside handle and inside worked prior to me putting all that stuff back on. So I think my issue is with the lock itself. with it all back together the orange reveal tape on the plastic slider(the lock) doesn't show as much as the passenger door now when in the lock position.
Thanks!
Thanks!
This is EXTREMELY FRUSTRATING on the passenger side. What side does the black or yellow plastic rod clip go on for the passenger side please? Towards the mirror or towards the back of the car?
Is there a difference in the metal connection rod regarding passenger and driver? I have 2 of the same and the driver side works perfectly. I bought a passenger side one on eBay from a fellow follower here. But I cant get this thing to work right at all.
The clip on the door handle snaps in from the side towards the back of the car.
Keep in mind the driver's/passenger's sides are the same, but they're mirror images of each other. The clips are color coded and different. The passenger's side door handle clip will be Black or Orange/Red. Driver's are White. The rods for the handles and lock cylinders are different too. You need to be sure to use the right parts on the right sides, or it's going to cause problems.
