EBL Trigger for two fans at separate temps.
Car: 1991 Pontiac Firebird
Engine: 355 TBI
Transmission: 7004R
Axle/Gears: 3.27/42 ?
Hi all,
Recently, I've been having an overheating issue in stop/go traffic. The reason is because my second fan isn’t turning on due to the head temp sensor connector/wiring burning up. I want to setup both fans to be triggered via the ECM, however, I also want them to be triggered sequentially and by different temperatures.
Here is my setup:
Here is my question:
Thanks for any help!
Here is my setup:
- I have a 91 TBI Firebird that originally came with a single electric fan.
- I swapped in dual LS1 fans a few years ago.
- Fan trigger configuration:
- 1st fan is triggered via my EBL ECM
- 2nd fan is triggered via the head temp switch
- Problem:
- The 2nd fan isn’t working because the heat temp. sensor/wiring for it is fried (AGAIN!).
- This is probably the 4th time I’m having to fix it. Even after putting a spark plug sock on the connector
- I have DynoDon headers and I don’t want to wrap them because they look quite nice and I spent a lot of money on them.
- Is there anyway to enable the second fan to be EBL controlled?
- I figure this is easy if I want to turn them both on simultaneously. However, I would want to turn them on at a specific/different temperatures.
- With my original setup (that keeps burning up on me) this works since the first turns on via the ECM and the second turns on via the head temp. sensor’s enable temp.
Re: EBL Trigger for two fans at separate temps.
Did you look at d8 and e12 option . I’m guessing you have a p4 ?
http://www.dynamicefi.com/EBL_P4_Drawings.php
Or just 1 fan on c2 for the flash 2
http://www.dynamicefi.com/EBL_Drawings.php
I don’t thing the ecm can support running two fans on the same output.
You would need to run a head temp sensor and second relay. The sw555 switch works well on at 210f and off at 205 iirc. You can find it at RockAuto.com
Engine: 355 TBI
Transmission: 7004R
oh wow! That would work if I have P4 but how do I know? As far as I’m aware I just have the normal “EBL Flash ECM”
Currently, my first EBL fan is connected to C2. I followed the diagram for fan setup here:
https://www.dynamicefi.com/EBL_Drawings.php
If it’s hooked to c2 it’s not a p4, sorry should of read your tbi profile.
https://www.rockauto.com/en/catalog/...an+switch,4312
Engine: 355 TBI
Transmission: 7004R
Ok. The sensors in that link is what I’m trying to avoid using.
i have an idea but not sure if it’ll work... it’s to use the CTS sensors input and find something else that works off of thresholds that I can set. Maybe N2O or something ...
Napster, the XDF doesn't support controlling dual fans separately w/Flash, and I wouldn't try to wire it elsewhere in the ECM trying to use it in a different location to control it, seriously don't do that. I would suggest one of two things. Remove the sensor switch from the cylinder head and re-locate it into the intake manifold coolant port, and simply extend the harness wire to reach it. This will eliminate the headers frying them on a routine basis. Or, wire the second fan to come on in conjunction with the first fan, that is very easy to do. Just do so prior to the fan relay, preferably by the fans themselves, not the back of the ECM...
- Rob
- Rob
Engine: 355 TBI
Transmission: 7004R
- Rob
- Rob
Thanks for the ideas. As far as I'm aware though, I believe I can only perform one of the suggestions you provided:
- SL: Remove the sensor switch from the cylinder head and re-locate it into the intake manifold coolant port, and simply extend the harness wire to reach it. This will eliminate the headers frying them on a routine basis.OP: The current sensor on the intake manifold is the CTS sensor. How (if possible) would I go about keeping both the CTS sensor and the fan control sensor using the intake manifold?
- SL: Or, wire the second fan to come on in conjunction with the first fan, that is very easy to do. Just do so prior to the fan relay, preferably by the fans themselves, not the back of the ECMOP: This I could do. I read some say that this puts a lot of load on the electrical system all at once. I also thought it was important to get them to run in sequence?
They sell water necks with fittings for sensors, or you can even drill and tap a port anywhere on the manifold where there is room. It's very easy. The wiring by the fan would be the easiest route, of course, but then you are subjected to both fans being triggered at the same time, which will cause a spike in your injector voltage momentarily. Although I run an EBL-P4 w/two fans, I re-located the coolant gauge sensor in the same manner (which is originally on the cylinder head as well), and run it right next to the water neck. I have no sensors in the heads anymore, both the CTS and coolant gauge sensor are on the intake manifold. It would be a breeze with a TBI manifold in comparison...
You can see it here.
- Rob
- Rob
Engine: 355 TBI
Transmission: 7004R
That’s a good idea...
I have the Edelbrock 7101 Performer RPM manifold which does have a lil spot for another sensor if you drill & tap.
Disregard the tape measure...
I think I may go with that solution...
Engine: 355 TBI
Transmission: 7004R
So did some more research:
Seems that the thread size for the stock fan temp sensor is actually 3/8-18 NTP.
I also called Edelbrock and confirmed that the suspected spot is good for drilling/tapping.
So all I need is the tap, a matching drill bit, extend the wire, and then plug the head port.
Maybe I can get this all done today after work
Thanks for the help!
TransAmGTA88
08-12-2014 01:10 PM
five7kid
09-27-2009 08:51 AM
