DFI and ECM Discuss all aspects of DFI (Digital Fuel Injection), ECMs (Electronic Control Module), scanners, and diagnostic equipment. Fine tune your Third Gen computer system for top performance.
Has anyone ever read one of the old Hypertech proms?
Old 07-20-2018, 06:33 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Just wondering?
Was VATS defeated, if not, how did they know which code you had? Were the spark and fuel tables much different than stock?
I know the Stage 2 chips turned on your fans sooner and required a 160* t stat.
I did actually call Hypertech about it and the guy's responses made no sense to me.
Old 07-20-2018, 06:51 PM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Has anyone ever read one of the old Hypertech proms?
The only Hypertech I’ve read that didn’t have vats was a off-road tune.
The non street runners have minimal changes the thermomaster has changes to sa.
Old 07-20-2018, 06:54 PM
chazman's Avatar
Axle/Gears: BW 3.45
Aren't there several combinations of VATS they'd have to account for?
What changes did the Thermomaster have?
Old 07-20-2018, 06:57 PM
Engine: Lb9
Transmission: M20
Spark tables, fueling tables and power enrichment , tcc lockup and Gannon’s and offs. There is not a hz setting for vats is enabled or not.
Old 07-20-2018, 07:09 PM
chazman's Avatar
Axle/Gears: BW 3.45
Gannon's?
hz?
Anyway, let me run this by you, I've got an '89 IROC, where the previous owner installed 24# injectors and had a Miami area shop retune his PROM. I replaced the 24 pounders with stock 19# injectors and figured I could use the factory PROM from my other '89, (I replaced it with a Hypertech back in the day, I'm the original owner), but it wouldn't start. I blamed that on VATS. Any ideas? Just curious at this point.
Old 07-20-2018, 07:36 PM
Engine: Lb9
Transmission: M20
Stupid spell checker , fans on and offs and hz is the hertz signal the ecm expects to see.
Yes you can use the stock memcal with the 19#hr injectors.
It should of started that’s odd.
Old 07-20-2018, 08:35 PM
Drew's Avatar
The ECM Doesnt read the key value. Theres a separate box for reading the key and generating a signal that goes to the ecm. The VATS module has to match the key, not the ecm
Old 07-20-2018, 11:02 PM
chazman's Avatar
Axle/Gears: BW 3.45
So, more than one key and VATS module?
Old 07-20-2018, 11:07 PM
Drew's Avatar
15 keys, one VATS module. The module memorizes the key value on the very first start, and it looks for that key value from then on. If the key value is right, it generates a signal for the ECM. If the value is wrong, it doesn't send a signal to the ECM.
The chip can be programmed so the ECM doesn't look for the signal, hence vats delete.
Old 07-20-2018, 11:13 PM
chazman's Avatar
Axle/Gears: BW 3.45
I thought it was something like that. So, how do you order a Hypertech chip with no other info other than, TBI or TPI and auto or stick and have it work? The VATS must be deleted on those PROMs, no?
Old 07-20-2018, 11:27 PM
Drew's Avatar
The prom/ecm just looks at it as a yes or no question. The prom determines if the ECM looks for a VATS signal. The ECM looks for the signal, is it there? yes/no.
I've never heard of a commercial PROM having a VATS delete option. The signal from the VATS module is the same regardless of which key it's mated to. The ECM never knows which key value is being used, it just knows if the VATS module is saying it's the right key.
The chip just tells the computer to look for a VATS signal, or not to look for a VATS signal.
Old 07-20-2018, 11:53 PM
chazman's Avatar
Axle/Gears: BW 3.45
So the factory PROM from one '89 should not have been defeated by the VATS from my other '89?
Old 07-20-2018, 11:57 PM
Drew's Avatar
Shouldn't have mattered. Should be able to swap the ECM and PROM between a dozen cars as long they're the same year and same options. As long as you keep the key and VATS module paired, it's going to generate the signal the ECM needs.
Old 07-21-2018, 12:07 AM
chazman's Avatar
Axle/Gears: BW 3.45
Got it. VATS module is where?
Old 07-21-2018, 01:54 AM
Drew's Avatar
Deep inside the dash. On the Firebird it's on the back of the heat/ac duct. Pretty much need to remove the dash to get to it.
Old 07-21-2018, 06:04 AM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
I was told by another member that this is the VATS module. I found it behind the drivers kickplate. It is stuck to a piece of TAR that it is behind, you can kinda see the Tar tape stuck to it. Not sure if this is the same as your 89 or not.
Old 07-21-2018, 07:26 AM
chazman's Avatar
Axle/Gears: BW 3.45
Thanks guys!
Old 07-21-2018, 08:27 AM
Drew's Avatar
Negative Ghost Rider, that there is the starter enable relay. The VATS module turns the relay on/off based on the 'handshake' with the key.
You can bypass that relay and the starter will crank, but the engine won't fire unless the VATS module see's the right key and communicates with the ECM.
Old 07-21-2018, 10:39 AM
Drew's Avatar
Additional info that may quell potential confusion.
This is the VATS module. Those two screws on the back of the HVAC ducting are where it's mounted on a 91 Firebird, and I would assume most thirdgens. If it's not clear, this is between the firewall and the duct, behind the dash, behind the main heater box, etc.
And the handy dandy VATS description and component chart
Old 08-30-2018, 11:05 PM
SirReveller's Avatar
Car: '89 'ROC
Engine: 5.7L
Old 08-30-2018, 11:31 PM
Galaxie500XL's Avatar
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
If I recall, the square wave is a 50 hertz square wave...so a 50 Hz oscillator circuit could conceivably fool the ECM that VATS is working.
Old 08-31-2018, 10:04 AM
Engine: Lb9
Transmission: M20
Originally Posted by SirReveller
I’m not sure if it’s a improvement over stock or not.
this one listed is for a 88 tpi 350 automatic
it is missing the piggyback adapter that connects to the memcal.
https://www.summitracing.com/parts/h...n/?prefilter=0
Old 08-31-2018, 07:25 PM
Car: '89 'ROC
Engine: 5.7L
Thanks Bri- no deal at all if incomplete. On PN/year compatibility though I think that’s just Summit not being totally accurate:
http://www.hypertech-inc.com/vehicle...x?AAIAID=45316
Old 08-31-2018, 07:31 PM
Engine: Lb9
Transmission: M20
That listing is odd, that’s a big difference some 88s had vats and all of 89.
the adapter that’s missing from the prom looks like this.
http://support.moates.net/g1/
Old 09-02-2018, 12:35 PM
GeneralDisorder's Avatar
These are the same price, and have a low-profile ZIF. I rather like them better than the G1:
https://www.ebay.com/itm/GM-MEM-CAL-...gAAOSw6EhUTbiC
Old 09-21-2018, 11:16 PM
chazman's Avatar
Axle/Gears: BW 3.45
Someone on one of the 3rd gen FB pages claimed to read a Stage 2 Hypertech chip and this is what he said:
The differences over a stock PROM (Use AFUD 305, 5 speed, 3.45, G92) are these: Spark increased at WOT by 5 degrees from 1600-4800, WOT air fuel ratio increased by 4%, Open loop air fuel ratio increased by 2-3% in operating range, Fan on temp lowered to 160, MAF table one adjusted with slightly richer off idle, Less spark retard on hot engine, some EGR tweaks. So lots of little things but primarily more spark are WOT. If you compared a stock G92 chip and Hypertech with premium gas AND base timing set at 6 ... Hypertech should be faster. If you base timing is NOT at 6 ... then most likely it will ping and pull timing out ... thus going slower. My 2 cents.
quick90rs
04-28-2013 11:01 PM
Sostar18
DIY PROM
08-04-2002 08:48 AM
jamesbern
Carburetors
12-21-2001 06:35 AM
Joseph Andres
Aftermarket Vendor Review
11-01-2001 12:42 AM
Quick Reply: Has anyone ever read one of the old Hypertech proms?
