turn signal lights don't work, they just stopped
Old 08-17-2018, 10:12 PM
ubigbad's Avatar
Car: 86 firebird TA
Engine: 305 4 bbl carb
Transmission: 5 speed
Hi everyone:
I have an 86 firebird that the turn signal lights don't work, they just stopped.
I replaced the relay (bought 2 so I have a spare) and checked all the fuses, Hazard lights work, brake lights work, tail lights work, parking lights work. green arrows on dash don't light up. ether right or left. but work for hazards.
don't know what to do now any help would be appriciated
Old 08-18-2018, 07:44 AM
92RS-HeritageEd's Avatar
Car: 92 RS / 90 IROC-Z
Engine: 305 / 350
Axle/Gears: Non-Posi / Posi - Both GU2 - 2.73
Re: turn signal lights don't work, they just stopped
Turn Signal Flasher?
Old 08-18-2018, 10:06 AM
ubigbad's Avatar
Car: 86 firebird TA
That is what I replaced still have nothing
Old 08-18-2018, 10:16 AM
Engine: 305 / 350
Bummer, I misunderstood when it was referred to as a relay.
Do you get the audible click when moving your Multi-Function Switch (Turn Signal Lever) up and down?
Do you hear the consistent ticking when your Multi-Function Switch (Turn Signal Lever) is positioned for Left or Right Turn?
If yes, despite the Signal Indicators in the dash being out (potential bad bulbs) have you got out of the vehicle and checked operation of the exterior turn signal lights front & rear when the switch is moved?
Could be a wiring matter, or faulty Multi-Function Switch... Just offering any help I can until a 3rdGen Vet chimes in...
Old 08-18-2018, 10:35 AM
ubigbad's Avatar
Car: 86 firebird TA
When I move the turn signal switch on the column up or down I get no sound from flasher no lights inside no lights outside for the turn signals . I have checked all the bulbs and they test and work ok.
Old 08-18-2018, 10:43 AM
PaulyC's Avatar
Check your turn b/u fuse first. If that is ok then since you already tried a new flasher you may be looking at a faulty turn signal switch. All of those lights go through that switch.
Old 08-18-2018, 10:46 AM
Engine: 305 / 350
We're heading into uncharted territory my friend but by chance do you have an aftermarket car alarm?
With no lights and no sound, we would need a Haynes or better yet a GM Service Manual for the wiring diagrams...
I've found the diagrams online @ http://www.austinthirdgen.org/?pid=19
Also, See PaulyC's reply, he may be confirming my assumption of a faulty Multi-Function Switch...
Old 08-18-2018, 11:02 AM
ubigbad's Avatar
Car: 86 firebird TA
I have checked all the fuses and they are good , going to get out my multi meter and test light to check the milti function switch. Any advice on testing the switch?
Thanks for the replies will post my results
Old 08-18-2018, 11:12 AM
Engine: 305 / 350
The best I can suggest is following the wiring schematic/diagram below...
http://austinthirdgen.org/mkportal/m...ody_wiring.gif
going from the actual bulb connectors backwards, It appears power flows through the dk blu wire?
I'm still learning schematics myself...
Old 09-09-2018, 11:11 AM
cbshirey's Avatar
Did you find a fix to this? I have the exact same problem!
Old 09-09-2018, 12:28 PM
ubigbad's Avatar
Car: 86 firebird TA
Yes I jumper the hazard power to the turn signal power at the plug to test and it all worked. So I traced the purple wire backt to fuse block and fiund the purple wire was briken in back of fuse block. Ince I reconnected it everything worked again
good luck
duanejangula
12-15-2017 06:23 PM
Jared11
11-13-2008 10:12 AM
MetalliCamaroRS
11-13-2001 09:10 AM
Quick Reply: turn signal lights don't work, they just stopped
