est to hei swap
Old 09-20-2018, 05:06 PM
tattoojohny's Avatar
est to hei swap
1993 chevy suburban with est dist. can i rewire the four pin connector that sends signal to tbi injectors as it sits ,no pulse please help.trying to make change do to lack of funds and already have hei laying around..
Old 09-20-2018, 05:17 PM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: est to hei swap
Are you asking if you can rewire a devorced coil hei to coil in cap ? The answer is yes. But some tbi manifold use a larger distributor base so the distributor might not fit.
Old 09-20-2018, 06:05 PM
Re: est to hei swap
i got it to fit with some grinding but no start no pulse is there a procedure or jumper of sorts ?and thanx
Old 09-20-2018, 06:07 PM
Re: est to hei swap
oh i see its the smaller one and the hei is in and i pour gas into tbi and it will idle for a min but die ,obviously cause no pulse lol round and round we go lol
Old 09-20-2018, 06:24 PM
Engine: Lb9
Transmission: M20
Re: est to hei swap
I have no idea what your factory wire colors are . But here is a schematic showing the large coil in cap distributor.
Here is a testing procedure for the pu coil. If the coil is ok the icm can be found on eBay for cheap to get you by until you get a better quality ac delco or Borg Warner ect..
https://easyautodiagnostics.com/gm/4...ed-icm-tests-1
Old 09-20-2018, 06:29 PM
Engine: Lb9
Transmission: M20
Re: est to hei swap
Here’s what I mean about cheap icm
https://www.ebay.com/itm/LX340-Ignit...item3f59e8c8ed
Old 09-20-2018, 07:19 PM
Re: est to hei swap
i see ,thanx for info so i take it hei is out of question do to not having some kind of interrupt circuit ,if thats what there called like abs or crank sensor with an exciter wheel type of thing ?...my old dist was plumb wore out ,original to truck
bowtied_gta
07-24-2018 03:17 PM
squirrelybird
06-02-2004 01:59 PM
elcamin0_77us
01-27-2004 05:49 PM
SmuurF
11-15-2002 10:01 AM
RSpeed
08-27-2001 01:11 AM
Quick Reply: est to hei swap
