strut tower brace
Transmission: Pro-built 700R4
Re: strut tower brace
I'm partial to the BMR STBs. I know they clear the TPI plenum and I like the aesthetics of it because it frames the plenum nicely as well.
COTM Editor
Received 1,855 Likes
Car: '89 Firebird
Engine: 7.0L
OP has a base model Firebird. Base model Firebird hood has the least clearance of all the styles. I can tell you from my own experience,
* BMR won't fit
* Heidts 3 point TBI won't fit
* Heidts 3 point TPI wont' fit
* Kenny Brown won't fit
My own opinion is that if it is made for TPI then it won't fit.
* BMR won't fit
Aside from the faux hood vents, I didn't think there was any difference underneath between the T/A hoods and the base birds.
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Not common knowledge. That's why I took time to help.
I mean really, when was the last time you saw a tricked out base model Firebird? Not many people would do that.
Mine is a base and my 3 point wentin easy. I heard thats uncommon so i was pretty stoked when i installed it.
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Ya, I've heard the QA1 fits and that is what you have. I was only trying "fixed" bars and not the style with hinges like the QA1. I haven't found a fixed style yet that fits.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Did you contact DSE to see if their new line will fit? They might have some insight since it was just released.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
The two bolts on each strut act as a pivot. So it can rotate about that joint. So it's not truly fixed. If one strut side goes up the other side doesnt arrest it fully. It's not constrained in every axis.
COTM Editor
Car: '89 Firebird
Engine: 7.0L
See the thing is a TPI never went in a car with a base model Firebird hood. It's not a combination that has to be considered. My LS engine sits much lower than the TPI and I could easily have a strut tower brace made to fit if I want.
TheJoeY88
01-14-2017 09:03 AM
kurfbird
10-31-2016 11:28 PM
Daltonthirdgen
10-30-2016 05:37 PM
