Thoughts on 85 Iroc purchase for resto..
Car: 1985 L69 Iroc/90 Iroc/99 Firehawk
Engine: L69/LB9/LS
Transmission: 5 spd/Auto/6 Spd
I picked up this 85 Iroc for $2500 to fix up. Just looking for input, good/bad, as this is a first time project for me. It is original, 74K mileage car. Base 305 (155hp). Car runs well, but needs paint work due to extended exposure to the elements. Interior is excellent with the exception of a 1" hole in driver side lumbar, and the normal falling headliner. Dash and all plastic is in good shape, no cracks, just needs a good cleaning. Owner had it for 18 years, and drove it minimally. Car has all original paperwork, and looks to have been undercoated when new. A few pics below:
Re: Thoughts on 85 Iroc purchase for resto..
Welcome to Thirdgen!
MOST of these cars don't really have value beyond the sum of the parts. Meaning it's not a special collector worth saving for financial reasons or anything like that, and honestly few are. BUT....it sure looks like a great car. Good bit of original doucments too, nice! Needs paint like you said, and a good cleaning and probably tune up, ...but assuming YOU bought it because YOU want it...I think it's a great car! Take lots of pictures and document what you've done. It's part of the fun and WE certainly enjoy following along. ....I also started a facebook page for my car since a lot of my friends aren't thirdgen.org members. Link is in my sig. It's kinda fun.
Enjoy it! Welcome aboard.
How is the undercarriage look? Also pull the side ground effects off the car and check for rust. These cars like to get rot under the ground effects. If no rot then go ahead. If rot is found get an estimate for repair to decide if you want to proceed.
Looks very fixable right now.
Transmission: World Class T-5
Axle/Gears: BW 3.45
Engine: L69/LB9/LS
Thank you for all the responses. Well, here are some more photos. Took 3 washes to get the grime off, and it still has some in the nooks/crannies. Love the stick as the hood prop...LOL, and of course, not paying attention, I think I fried the alternator washing the motor as my choke light is now staying on, but all and all at least she is clean, just need to sweep out the inside.
Engine: L69/LB9/LS
Abubaca, I went on a looked at your car on Facebook, NICE! You have done a ton to that car, but it is sharp.... Congrats!
I think as long as you do a repaint in the same color, keep the engine setup the same and keep the interior the original theme the car will always appreciate like all the other IROCS and be easy to resell when the time comes. As soon as you start changing the engine, exterior color or changing the interior to black and/or grey you'll lose some resale value.
Engine: L69/LB9/LS
Thanks Tibo.... I bought the car in PA, and had it shipped to IN. It does have a little rust on the bottom door seams, but that has been all I have found. The underbody is coated, and I haven't found any issues there. Plan is to keep it 100% stock as is, just get it back in shape to be a fun weekend driver during the spring/summer months. Not looking to build a show car.
Received 1,160 Likes
Car: 1986 Camaro Drag Car
Engine: 383 on Ethanol
Transmission: Automatic
Axle/Gears: 3.90 Currie 9 inch
I would have bought that car, too! Looks like a great buy! Congrats on the new ride!
...keep the engine setup the same and ... the car will always appreciate like all the other IROCS and be easy to resell when the time comes. As soon as you start changing the engine, exterior color or changing the interior to black and/or grey you'll lose some resale value.
Engine: L69/LB9/LS
Thanks 1MeanZ, for the input, I appreciate it. I did check the under body by putting it up on a hoist, so far, everything looks good. I am not planning to change the motor since it runs well. If something would happen to it, then I would consider a change, but to me, it isn't money I am wanting to spend currently.
You can make an LG4 car run great. This is my 82 Z28 after a carb rebuild and played with the timing on the car. Everyone will dis the lg4, but there's nothing wrong with it. Does it have as much power as a tpi? No, but the TPI cars are super slow by today's standards, too. If it runs good, DRIVE IT and enjoy the hell out of it!
IROCIN,
I believe you picked up a steal of a car. Of course Im extremely biased since i have a white 85 myself. Keep us up to date with pictures as you work on it.
Axle/Gears: BW 3.45
https://youtu.be/2-CvxdsrHIQ
Does your car have a 2.73 or 3.23 gear?
Yah to be clear, I agree, if it's not rusted out, then you got a good deal on a good car. Clean it up and enjoy it.
Hopefully no one thought I was advocating you yank the LG4, I just wanted to note that in this case I don't feel a PROPER and clean engine swap would not devalue the car.
I have an 88 IROC with an LO3 and T5(and a 2.73 rear that someone swapped in and it's been overheated a zillion times and I suspect the valve springs are wasted because it valve floats at 4500rpm LOL). I got into a bit of an acceleration contest with a newer Dodge Dart SXT a few months ago, we were nose to tail to start and I barely got around him out by 65mph LOL!! So yes it's slow, but it's still fun and that's why we even do any of this. So if the LG4 makes the right noises and keeps you smiling, then have at it.
Engine: L69/LB9/LS
It sounds nice, and for me, that is the enjoyable part. I agree, even the HP 245 horses back then would be pale in comparison to a lot of cars today. Being in the office all day, the tinkering on a car is the stress relief i enjoy. I am enjoying the forum, and talking with folks into the same cars. I have been on many that are not as community minded and seem to focus on who has the "bigger/badder" car, which is a waste. I am sure I will be bouncing ideas off of all of you going forward. I greatly appreciate the feed back all of you have given. As for gearing on this car, I have no idea..... I'll have to look into it.
You found that here in pa? I gotta start browsing Craigslist again every couple days! As much as didn't like one of my old bosses from back in the day, he knew how to buy a car, and by the pics you did good! Body, motor, and interior were his criteria... Car had to have 2 of the 3 going for it. And that car appears to! What I would do with it? For that price and the fact it's an lg4, I'd do a big LS motor! Heck, i wouldn't even paint it, it'd be a cool sleeper. If that's possible for an IROC Good luck and enjoy it whatever you do with it!
Engine: L69/LB9/LS
Zya5point0, yep, found it out in Mill Hall. I found it thru Facebook Marketplace, I tend to use it more now than Craigslist. I went back/forth with the guy for about 2 weeks, and finally got an agreeable price for both of us. The pursuit is half the fun!!
Car: 82 Z28
Transmission: BW T-10
Your LG4 acceleration vid reminded me of mine! Almost the same as yours but 4 speed and ditched the cat. Richer secondary metering rods too. Goofing around with too much wheelspin!
https://youtu.be/watch?v=CrojciV7o4I
Car: 82 Z28
I don't drive it very often, most recent pic here: https://www.thirdgen.org/forums/memb...ml#post6195616
Car: 82 Z28
Thanks! it's a very original, but typical 82 with a really nice paint job I did about 15 years ago. Still has the original, somewhat worn interior, etc. Runs great, tho!
Engine: L69/LB9/LS
I sanded down the rust and put primer on the car before putting it away last fall. The paint is a temporary rattle can cover. She goes off to the shop on Monday to be sanded down and repainted as she should be with a good base/clear paint job. Excited for her to look "fresh" again! I'll post some photos once I get it back.
I recommend Phoenix Graphix for your stripe kit and door decals as they are as close to original as possible. And whether you or your paint guy install the IROC-Z decals, take a quick look at where the original door decals sit....Real easy to misplace.
According to your build sheet, your car was built 14 days before mine. I also have my fog light switch in the strange location in the lower dash as well.
Looking good so far man.
Engine: L69/LB9/LS
Thanks Motown.... Yes, I am going to go with Phoenix for the graphics. Toying with the idea of just doing the striping and the Z28 logos on the car, and leaving the IROC-Z off for a bit to see how it looks once I get it out of paint.
Engine: L69/LB9/LS
Have a little prep left, but should be shooting primer and paint this week. Looking forward to getting to see the final product on paint. Then it will be on to getting the headliner replaced, and some fabric dye done to fix some of the seat fade.
Can't wait to see it when its out of paint and back together.
IROCIN (06-25-2019)
Engine: L69/LB9/LS
Decals and striping went on today. Major work is done, now on to the details......
Drew (07-04-2019)
