Best sound from sails
Old 11-10-2018, 05:36 AM
5.0ta's Avatar
Car: '86 Trans Am
Engine: 5.0L TPI
Axle/Gears: 3.27 posi/disc
I want to upgrade the old sail panel coaxial 6X9's with something better...I'm thinking of 6.5 component set up...thoughts?
Old 11-10-2018, 02:40 PM
instro84's Avatar
Car: 89 tta
Engine: turbo v6
Transmission: 200r4
Re: Best sound from sails
i put 6.5 components in my sails, sounds pretty good, i have 4x6 in dash in and 5 in kick panels.
Old 11-10-2018, 04:01 PM
5.0ta's Avatar
Car: '86 Trans Am
Engine: 5.0L TPI
Cool...sounds like I'll be building some enclosures for the 6.5's and mount the tweets separately...I'm planning on 6's in the kicks and mounting the tweeters in the a-pillar trim eliminating the dash 4x6's.
Old 11-12-2018, 12:36 PM
RunawayRadio's Avatar
Car: 1987 GTA, Digital Dash
Engine: L98 TPI
Transmission: 1994 LT1 T56
Axle/Gears: 9 bolt, 3.27
I have 6.5 diamond audio components in the sail panels and i'd recommend it over the stock 6x9's if you have a good amp to drive them. I 3D print fitted/recessed mounting plates for people up here in Canada that make the jump.
You might lose a bit of the midbass from the smaller speaker size, but you more than make it up in sound quality with a good component set. Adding a small sub in the back (or large if you hate breathing lol) rounds out the rest of the system. These cars can be great platforms when you take the speakers out of the dashpad.
Old 11-12-2018, 01:11 PM
5.0ta's Avatar
Car: '86 Trans Am
Engine: 5.0L TPI
Thanks Runnaway...you're set up is exactly what I have in mind...this is what I'm going to do...6" in the kick panels with the tweeters in the a-pillar trim and 6.5's/tweeters in the sails with my two 12" subs in the cargo area...I have a 100w amp, is the amp enough to push all those speakers?
Old 11-14-2018, 10:54 PM
Engine: L98 TPI
Thanks. If you're planning on pushing 10 speakers (4x tweeter, 4x woofer, 2x 12" sub) i'd say not even close. You'd need at least 300w RMS to drive those subs alone half decently.
You can get away with 50w RMS per speaker channel, but i'd recommend at least a 4 channel amp capable of 300w RMS total (4x 75) for the speakers. If you're thinking of dual 12" subs, I'm guessing you want it to pound. you'll need a 500-1000w to drive that well. You can get a good Class H amp from arc audio that can be hidden easily and will fit that power envelope. The hatch glass will also amplify the sub ~3db if i remember right.
For comparison, I put in a single sealed box 10" sub with a 1000w Class A amp. The front components (4x passive tweeter and 4x woofers) are powered by a second 4 channel Class A/B with 180w RMS per channel. The sound is phenomenal, and it hits hard enough for the SQ setup i was going for. Everything is hidden, but it took me some work to get it that way. These cars can deliver great sound if you put some thought into it.
Old 11-15-2018, 07:22 AM
5.0ta's Avatar
Car: '86 Trans Am
Engine: 5.0L TPI
Thanks for the info!!!!....I listen to hevy metal so I'm not really shooting for glass shattering thump, I just want to be able to cruise with the tops out and not have distortion from the radio maxed out.
Old 11-15-2018, 08:49 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Those plates are really cool. Could you print a set of those without the holes in them and sell them?
Old 11-16-2018, 05:44 PM
Engine: L98 TPI
Thanks. I'm actually working on the last design revision before selling them commercially, however, I've already made up a few sets for people in my area that couldn't wait. They'll be available in either black or white.
What do you mean about removing the holes though? The speaker holes themselves?
Old 11-16-2018, 05:47 PM
Engine: L98 TPI
You're welcome! You definitely don't need dual 12's then. Try a single paired with a decent amp and enjoy. you can set the gain controls separate from the stereo; if you size the amp properly you won't need to go above half volume at 100mph. I'm talking about an aftermarket deck though - the stock one isn't great in a modified system.
Old 11-16-2018, 06:40 PM
instro84's Avatar
Car: 89 tta
Engine: turbo v6
Transmission: 200r4
i'd like a set if you have a few extra
Old 11-16-2018, 08:32 PM
5.0ta's Avatar
Car: '86 Trans Am
Engine: 5.0L TPI
Yes those plates are sweet!...are the 6.5's free air or enclosed?
Old 11-16-2018, 08:53 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Yes, without the speaker holes, so I could cut what ever I wanted into them, for 6x9s or something
Old 12-10-2018, 03:13 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
I put JBL 6x9s in my sails. They sound good!
Old 12-10-2018, 06:05 PM
Galaxie500XL's Avatar
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
Polk Audio 6x9's in my '88...now I need a larger amp.
RCAR7395
02-28-2009 04:34 PM
MN305TBI
Interior Parts Wanted
06-25-2008 10:35 PM
Turbo01SS
12-04-2007 07:48 PM
Quick Reply: Best sound from sails
