4th Gen Pedals and Hydraulics for T5 Swap
Car: 87 Firebird
Engine: Mildly Built 350 SBC
Transmission: T5 5 Speed
I'm doing a t5 swap and I have everything for the car except pedals and slave and hydraulic setup. I do have a 94 3.4 5 speed Camaro that I can use for parts is it possible to use the 4th gen setup with the t5 for a thirdgen. I've read about 4th gen pedals not sure on the slave cylinder with the full setup if it could be used.
Re: 4th Gen Pedals and Hydraulics for T5 Swap
https://www.thirdgen.org/forums/prof...do=editprofile
Add your car and engine type for better answers.
V6 4th gen T5 doesn't bolt to a third gen V8 T5 bellhousing.
Google V6 T5 V8 thirdgen.org and read read read until you find why else it doesn't work.
I assumed a few details because you posted too few details.
Car: 87 Firebird
The 93-02 pedals have a shorter throw for activating the master cylinder, since the stud on the pedal is higher.
The concentric slave cylinder and bearing retainer on the 4th gen T5 could work on the third gen V8 T5, but wouldn't do any one item better than just getting third gen parts. I would be hesitant to go to a concentric style when the third gen style works, and is serviceable without dropping the trans.
Car: 87 Firebird
Just an update on using the slave cylinder. 93 to 95 3.4 cars use an external slave cylinder. I am going to use it and the pedals there may be modifications that our needed but it hooks the same way on the bellhousing and at the pedals, and since I'm using the pedals from the same car shouldn't be an issue in my case. So you can use the slave cylinder in this case but only if it came from a car with a 3.4. GM for some reason when they went to the the 3.8 they changed the slave cylinder to an internal style setup. Hope this helps someone out just figured I would post on the information I found out when I pulled the transmission and slave cylinder from the 94 Camaro I have.
BlueZee28
05-01-2020 07:54 PM
88FormulaKiller
07-13-2017 10:31 AM
85TAracer
10-03-2008 07:56 AM
