L98 oil filler cap location - forward or aft ??
Car: 87 Trans Am
Engine: 5.0
So who knows (or can remember) the ORIGINAL orientation of the left side rocker cover on a L98/B2L ??
Did they leave the factory with the oil filler cap located FORWARD or AFT ??
See attached pics - the pic with the oil filler located AFT is of an all original L98 in a 1988 Formula 350 with 3015 miles.
The pic of the oil filler located FORWARD is of an all original L98 in a 1990 Formula 350 with 9200 miles.
Which one is factory correct ???
I guess it could depend on the year, but I highly doubt it.......originality experts, please chime in !!
Car: Eclectic 3rd Gen Formula Circa 1990
Engine: Bone-stock, re-newed L98 5.7 TPI-SD
Transmission: 1352-065-914 Rev.3(T5-WC)
Axle/Gears: 3.08
Re: L98 oil filler cap location - forward or aft ??
Forward... I believe? Man... it really looks like you posted pics of MY car. They could be twins aside from the Delco battery LOL.
Car: 87 Trans Am
Engine: 5.0
I bet we get a 50/50 split on the answers to this - just like a Florida election result
A friend who was a GM tech in the late 80's seems to think he remembers the filler cap located AFT on the new cars ??
If so, my guess is it was flipped around on the 1990 car to make adding oil easier ???
Car: 87 Trans Am
Engine: 5.0
I may have answered my own question.......here is a pic from a 1989 Pontiac sales brochure
that shows the oil filler cap AFT
Car: 91 Trans Am convertible
Engine: LB9
Axle/Gears: G80/GU2
I'm pretty sure earlier TPIs with the larger oil cap were aft and later TPIs with the smaller oil cap were forward, if you look back at those pics you'll see the different size caps.
Location: *member since 1999, I think - just can't remember my old name, and the big site crash...*
Engine: 5.7L L98 TPI
Transmission: 700r4 Automatic
Here's my 1989 5.7L B2L GTA
On my 90 Formula TPI it's forward and easy to get to. On my 89 Firebird TBI it's buried on the forward passenger side. I have to do some thinking to get to it. I've often wondered if it's in the right place all these years.
Car: 87 Trans Am
Engine: 5.0
Good info - thanks guys!
In summary, it sounds like the oil filler cap was located AFT 1987 - 1989 L98's
and forward starting in 1990 - I assume this is the same for the LB9 ??
I never knew this, there is incredible expertise on this forum !!
Transmission: World Class T-5
Axle/Gears: BW 3.45
My former '92 LB9.
My '89 LB9.
My other '89 LB9.
My '89 LB9.
My other '89 LB9.
Car: 87 Trans Am
Engine: 5.0
Chaz....now you've confused me....
Now I am wondering if there was no set way and it was just how whoever installed the rocker cover on the engine production line did it ???
Car: 87 Trans Am
Engine: 5.0
I take that back - the pics you attached support my findings previously stated..... thanks!
Engine: 4++,350 & 305 CIs
I would like to add that the 89 brochure has to older, large cap on it.
I'm guessing they just used all old stock up until the 89 small caps came in but I thought the large caps were 1/4 turn and smalls were screw on.
All my 89s are small fill caps in the rear position.
All my 90 and ups are small caps in the forward position.
Also, I've seen a few veeery late 92s that the covers went to black with small caps in forward position. (these engines have more fun stuff in them, blank TB plate, textured corvette runners, flattop hyper pistons, PM rods, and a bit different oil pan)
Car: 87 Trans Am
Engine: 5.0
I'm guessing they just used all old stock up until the 89 small caps came in.
Car: 87 Trans Am
Engine: 5.0
There are a few pictures of a good example here http://www.last1992camaro.com/pictures/page6.html
It might be a dumb question, can the rocker cover be turned around to have the filler in the front?
Are the bolt holes different in a different position?
Louis
Louis
My very late 92 (August 92) also has black valve covers, my 88 GTA has silver/aluminum covers. My 92 has a threaded cap, the GTA has a 1/4 turn cap.
And no, its not possible to turn the cover around. Center screws won't line up anymore. You can switch sides left /right but then the ports for the PCV won't line up with the original hoses.
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
We have heard that GM was running out of engine parts late in the model year and was taking parts from wherever they could to finish up that last production year.
Steve86TA
11-24-2006 08:02 AM
speed88
08-24-2001 03:03 PM
