TPiS Mini Ram Porting and 113 heads.
Doing a project for myself. '86 IROC with a '91 L98 engine. Decided to port the heads and use a mini ram. Converted the heads to 8mm 2.00/1.570 valves and used a LS drop in kit. Erson 226/234 camshaft. Should be a nice little fun ride!
Engine: 4++,350 & 305 CIs
Re: TPiS Mini Ram Porting and 113 heads.
Nice, did you get any b4/after numbers on any of it? I did a set of 113s almost 20yrs ago and we picked up 6/10ths in the 1/4 over the stock 87 350 iron heads.
Nice! I'm sure they will be fun! Is your portwork able to be purchased?
Thought I'd heard the name b4, just making sure. I'll PM you
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Looking forward to seeing updates! Seems like this is going to be a pretty sweet little setup. Did you port to a 1205 gasket?
Chad, did you happen to get my PM?
@Gd here is the flow numbers on a set of 128s I have that were changed from square port exhaust to d port. I’m sure the 113s ported here flow more.
https://www.thirdgen.org/forums/engi...113-heads.html
@chad what lift are you at , just curious how much lift you can get with the 113s and your springs.
sorry missed post 3
Honestly, I wouldn't spend the money on them if I was a guy that was looking at heads. So much better stuff out there. I did it because I do this and I had them. If I did it all over I would put set of Pro-Filer or something like that on it. I still would have ported them. Just have a problem not touching something! lol
sorry missed post 3
GTAman
11-30-2015 11:12 AM
mypontiac
05-10-2003 09:59 PM
