Where can i get these?
Transmission: Pro-built 700R4
Re: Where can i get these?
Q: What do I call them?
A: Impossible to find in good condition...at a reasonable price.
Car: 89 Iroc Convertible
I have a bag full of similar clips in white.Might also have some oem black ones
No luck with that part #, but i did find these while searching ebay.Which, if any would you guy pick? I like the 4th one. Anyone know the dia of the release cable?
https://www.ebay.com/itm/50-Wire-Rou...item5d61ccd0ef
https://www.ebay.com/itm/15-Door-Loc...3/351732312757
https://www.ebay.com/itm/25-Routing-...item1c3057cfef
https://www.ebay.com/itm/25-Cable-Ro...item51e046c068
91vertZ28 (07-04-2021)
Not sure about the size, but the fourth ones look fairly close to the OEM pieces from what I've seen.
I've actually considered using some small adel clamps in lieu of those plastic clips.
Yes, you'd have to use a short self-tapping screw or something. That is the main reason I hadn't actually gone through with it.
This thread reminded me of the caps that cover the spoiler 12mm nuts. Caps have "niagara" and "413" stamped on the underside. So i typed that into ebays search eng and got this. https://www.ebay.com/itm/253945599833 Just ordered them, will see what i get soon.
Did some repairs to the TBL mounts while i had the spoiler off.
I used these to secure my cable.They hold the hood release cable in place on the 1996-2000 Honda civics.Very easy to remove as the prongs protrude upwards on the upper rad support and are totally accessible.I have a ton of them that I snagged from the junkyards
Funny you posted this. I cant find the ones i bought on ebay. So i bought those same ones, should arrive soon.
https://www.ebay.com/itm/232531619152
So here they are, i also found black ones that look identical to the white part, cable hole is slightly smaller. Link below and i still cant find my first order.
https://www.ebay.com/itm/264851146391
Mounted
New Vs old cap, look identical.
Mounted
GOY
11-08-2004 01:36 PM
