Hawks LS1 AC lines.
Old 12-11-2018, 06:37 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Hawks LS1 AC lines.
Ok what is the trick here... I'm running factory 2000 exhaust manifolds and am trying to install the Hawks hose kit for the LS swap. There is no way the AC pump will go into the bracket because of interface with the low pressure line and the exhaust.
Old 12-11-2018, 06:52 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Re: Hawks LS1 AC lines.
Never mind there is a foot note that they will not work with factory manafolds ... I don't think that was there when I ordered the lines... Well crap guess I'll have to get someone to modify the 2k line bracket... Luckily I kept that.
https://www.hawksmotorsports.com/a-c-line-kit-82-92-camaro-firebird-ls1-conversion-a-c-line-kit/
Old 12-11-2018, 08:48 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I remember seeing that note when I ordered mine last year. If you plan to sell them, let me know. I am doing another swap.
Also, let me know if you figure out a good way on how to run them with the stock manifolds... That is whole reason I swapped to longtubes!
Old 12-11-2018, 09:08 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Since I have a tubular k memeber I can run the factory lines I'll get a local shop to modify them... Or order a crimper and do it myself.
I was planning on finishing the car next week... There goes that plan.
I'll let you know on the lines the fitting nut is a little scuffed from me trying to figure out how to make it work but otherwise good shape. I went ahead and put them on with pump sitting on car so I could pull a vacuum and make sure all the other new parts are good. So far holding strong.
Old 12-11-2018, 10:42 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Found these... Up down or straight back. Not quite as pretty as Hawks compressor block.
https://coldhose.com/specialty-fittings/compressor-adapters.html#category_174
I also saw one that swivel but can't decide if it works for the LS pump, what is the generic model of the ls1 pump?
Old 12-12-2018, 08:47 AM
Supporter/Moderator
ShiftyCapone's Avatar
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Aeroflow Performance makes AN style AC lines so you can custom route your set-up.
KWIK performance also sells various compressor blocks.
Old 12-12-2018, 11:16 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Thanks will look into those also. Found a custom hydrallic shop they said they can crimp, flare, weld, and do pretty much anything to make custom lines so... I think I'll go that route.
However was looking the 5.3L engines use a different pump. the fittings are on the side of it. This looks like it would be an easier fit. question is if I could find a bracket that would line it up with the fbody pulley.
Amazon Amazon
Old 12-12-2018, 03:11 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I have truck brackets and compressors and a 4th gen (I think) compressor. I could look at the pumps and tell you whether the mounting points are the same between the two
Old 12-14-2018, 10:56 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Dont know if this helps any, but i modified the stock piece.I wouldnt mind trying the hawks part or similar w/ custom made lines to boot.
Old 12-18-2018, 11:38 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Got the lines made, pulling a vacuum at the moment on the system. Hawks lines will be for sale.
utfan01ss
08-24-2023 07:14 AM
toxik IROC
26
07-18-2014 07:15 AM
oners2nv
07-25-2010 04:18 PM
ebmiller88
05-28-2007 04:34 PM
Quick Reply: Hawks LS1 AC lines.
