Mechanical to electrical
Car: 1987 Firebird
Engine: 2.8L V6
I’m trying to instal a 140 dash in my car but mine is mechanica and the one I bought is electronic how do I convert this to work?
Re: Mechanical to electrical
Or use a Vss sensor with a Vss buffer or Dakota digital sgi-5
https://www.tpiparts.net/inc/sdetail/7587
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
shouldn't an 87 firebird come with an electric speedo?
my understanding was that the electric speedo started in 86 on the firebirds, but of course I could be wrong...
Going to have to install the yellow VSS Buffer box and get the correct electric VSS with the correct (electric) speedo gears in the tranny. IIRC the 87 Firebird dash harness is already wired for the electric speedometer and you just need to add the correct parts. However; I'm not sure if the 2 wires leading to the Tranny mounted VSS are included the engine bay harness,... so plan on needing to also add the tranny VSS plug and wires. ( I think they connect to the Buffer thru/at the C207 connector )
irocz8292
Carburetors
08-26-2002 05:19 PM
Mkos1980
04-04-2001 09:41 AM
crazeinc
03-27-2001 08:18 AM
Superblue87Formula
10-24-2000 01:55 PM
