Intermittent check engine light. Maf? Need help.
Hi guys I have an 88 firebird formula with the 305 tpi and have been having an issue with the check engine light. It is not there when I first start it in the morning but comes on after I restart it. Powerloss and rough idle when it is on. Could it be an maf relay problem? I took it to a shop and they said it was an maf issue but they couldn't fix it.
Re: Intermittent check engine light. Maf? Need help.
https://www.ebay.com/itm/86-87-88-89...EAAOSwGvhUG5iY
Same temp sensor as vette but I think the lead wire might be a different length.
im sure this is a typo on price lol
https://www.ebay.com/itm/EGR-Tempera...gAAOSwq7JT1wtf
A MAF burnoff relay code wouldn't cause driveability issues. But you may want to check the MAF power and burnoff relays. The burnoff function itself is unnecessary and it doesn't matter if it doesn't function. I can be programmed out with a custom PROM chip.
GD
GD
I just checked the codes and it says 33 and 34. Is that related to exhaust/ O2 sensors or intake? Car burns really rich.
33 is maf grams per second high.
post 2 explains what triggers it.
https://www.thirdgen.org/forums/tpi/...de-33-tps.html
Driving down the highway today with no engine light (intermittent) and suddenly I had a complete loss of power, no throttle response at all. After about a second or two of zero power the car went back to normal, but the engine light lit up just after that, while I was driving. Does this give any hints as to what my 33 and 34 might be?
You should try the trouble tree.
After connecting the junper to ALDL G could I connect the other end to the fuse labed BAT and use that as my 12v source?
Still in the process of diagnosing my codes. Could a bad Catilytic converter be code 33? There is a knock/ crunchy sound in my converter when idling.
The computer is entirely unaware of the converter. It doesn't care if it's there or not. So it is not related to your codes.
I recently moved to the EBL system and eliminated the MAF from my equation. This has the benefit of not needing any of those circuits, and also never having to worry about replacing a bad MAF or it being a flow restriction to future upgrades.
GD
GD
Car: 1989 Firebird
Engine: 5.7 LS1
GD
GD
Ok, that makes sense. Is there any way to change that thing or would I just have to buy a brand new one? Maybe I can get a nice one from a wrecker?
Car: 1989 Firebird
Engine: 5.7 LS1
It could be a clogged cat, how rusted are the bolts can you simply un bolt it and test drive it and see? Or is it rusted solid and would need to be cut off? If you have the means I would drop it off and stick a temporary pipe in its place... temporary being defined at how enforced having the cat is where you live
Also the knock are you sure its the cat or could it be an exhaust valve?
Car: 1989 Firebird
Engine: 5.7 LS1
If it turns out to be the cat buy a new one, since there is no aft o2 sensors on these cars I would buy a high flow cat to stay legal and somewhat environmentally friendly. Most wrecking yards will not sell you the cat, they have platinum inside them and are worth more as scrap than they can sell them as used parts... and I think some states have laws about used cats being sold. Depending on where you live you can probably get away with no cat but if the car is ever inspected they can ticket you under the federal laws requiring the emissions not be modified... though NY, CA, and a few other states are the only ones that really hassle you on a car this old.
I live in California so that wouldnt be an option for more than a year or two. It looks like all the exhaust before the cat is rusted and all the exhaust after it is still nice and shiny. I could probably get it off with an impact. I'll try that and see if it helps any. Also, I want to check my vacuum lines in the engine, what tools would I need for that?
Car: 1989 Firebird
Engine: 5.7 LS1
Since you are in CA you will have to buy a CARB certified cat which cost alot more. Does it pass the sniff test?
Well the exhaust smells super rich of thats what you mean by sniff test. My current cat did pass smog last year, maybe I put that on when I need to smog it but use a non certified cat for normal driving.
Car: 1989 Firebird
Engine: 5.7 LS1
No the inspection where they put the probe in the exhaust pipe, that is commonly called the sniff test around here. Also CA has that 1000 dollar fine for exhaust too loud that started this year -- so yea be careful, they are no longer doing the fix it tickets.
You can do a pressure test using the O2 sensor port to check for a plugged cat. Should see no more than 1-3 psi back pressure.
But even if the cat was plugged - this wouldn't throw a MAF HIGH grams/sec code. Since the car only has a single cat, it being clogged or not affects airflow through the entire engine - which would lead to the engine choking and the flow rate through the MAF would be low, if anything.
It sounds like you probably have multiple problems. Definitely check out the cat situation but don't expect it to fix that code.
GD
GD
Yeah I'm tempted to just pay a shop a ton of money to fix it all so I don't have to deal with it all. It only has 52,000 miles but the amount of Gremlins makes me think it wasn't kept well. Maybe I'll just rewire the maf, change the ECM, buy a cat, and check the hoses.
Took a look at the Cat today, couldn't get it off because of rust, so Im going to go be some rust remover. In the process of trying to get the Cat off, I found that the clamp that clamps the exhaust to the Cat is loose, and that the fit between the two pieces is letting air get out. I'm going to buy a new clamp because that one is way to rusted to work and see if that fixes rattling/exhaust leak problems. I've also been noticing stuttering at 3500-4500 rpm and think that maybe my intake is whack. I have the original air filter box with a k&n filter in it. When I took a look at it, it was just a single black dot 3 inches in diameter where it was taking in air. I'm thinking that isn't normal. Before I bought it it had a cold air intake but California smog wouldnt even pass that. Finally, it is now taking a couple of starts and plenty of pumping the gas to get this thing fired up, could that be injectors? If any of you guys have any advice or have found solutions to these problems please let me know! Thanks for all of your help thus far guys.
Car: 1991 Z28 Camaro
Engine: 5.7L V8
Transmission: auto
Check all your vacuum lines too- particularly the EGR valve line- one of those comes loose and you'll throw a code...
Do any of you guys have experience with making and using fused jumpers? Tuned Performance said just some spade connectors and a 5 amp fuse. Would I have to get a fuse holder then extend the wires, connecting one to the battery and one to the ALDL/ OBD1 port G? I am just making sure I don't mess up and fry everything.
Turns out my Cat is busted, pulled it off and a bunch of little pieces of honeycomb came out. Buying a new one from Magnaflow. Thanks for all the help that got me this far!
Daapunk
12-17-2010 05:30 PM
