Upgrade plan set, which cam??
Hi, I've been lurkin here since I bot my 1986 IROC-z in Oct 2017, tryin to get educated on restoration/modifications. Car is a true survivor with only 10,600 documented miles. It was a Texas car for most of its life and among other documentation PO provided annual inspection receipts attesting to mileage. Tho car body was sound, clear coat was flaking off all over, so I had the car repainted by a restoration shop in FT. Lauderdale. Here's a a short video of car after respray:
So far, I have made the following changes:
Brake calipers rebuilt, new rotors installed.
New Stereo head unit (Retrosound) and speakers.
Momo steering wheel.
It drives fine, but it needs more power. I want to keep the car as stock as possible and so will keep the 305 TPI that's in there, but give it some help breathing:
Vortec Heads
Headman Headers
Scoggin Dickey Intake
Low Restriction Catalyst
Flowmaster exhaust
QUESTION: what cam should I get for this combo?? The car has the stock auto tranny and is for cruising on the weekends, so drivability is a priority.
I appreciate pointing me in the right direction. Oh, please don't recommend a swap for a 350, for now I'm keeping the 305. I come from the world of vintage motorcycles and have to believe 5 liters can get the job done
Vortec Heads
Headman Headers
Flowmaster exhaust
Re: Upgrade plan set, which cam??
Get the compression ratio to where it's needed and a cam like Comps XR258HR or XR264HR will work well with the Vortecs. There are probably a hundred variations of the 305/Vortec combo but that should give you and idea. Keep in mind that the Vortecs in stock form have lift limitations.
Thanks Skinny.
Doom, I reached out to Summit and they r steering me in a different direction:
1) COMP Cams Xtreme Fuel Injection Cam and Lifter Kits CL12-364-4
https://www.summitracing.com/parts/cca-cl12-364-4
2) BluePrint Engines Muscle Series Cylinder Heads H8002K
https://www.summitracing.com/parts/mll-h8002k
Though those heads r more expensive, they work with the stock intake manifold, making the overall price lower. And the BluePrint heads are better to boot. With the Vortecs you need to buy a new manifold and they sell em very dear...
Wouldn't that larger combustion chamber (64cc) on the BP heads screw up your compression compared to say the 56cc heads from Trick flow? such as https://www.trickflow.com/parts/tfs-30310002
Orr, thanks for heads-up (pun intended), I checked the applications tab and the 305 motor is NOT listed. You would think the Summit tech would know better....
Machining heads from 64 cc chambers to 58 cc? Better check into that. At about .006" per cc, that's a lot of material. That's over 35 thousandths and will invite a few fitment issues. Intake manifold for one. A 26 thou pass on my 68cc heads was about the edge of what could be done without complimentary machine on the intake.
FWIW. A 305 with a 9:1 CR and a 58 cc combustion chamber will have a CR of about 8.4:1 with 64 cc's. That's not enough to be noticeable really (in a mild street build) but leaving the CR low (with an appropriately spec'd cam) leaves power on the table and can also reduces fuel economy with all else being equal and up to par. That is, a suitable ignition curve with all the timing the engine wants at WOT and cruise as well as good induction and exhaust.
Digging around their site I came up with this one: Xtreme Energy™ XE249H; Hyd. Flat Tappet; '58-'98 Chevy Small Block
http://www.compperformancegroupstore...Category_Code=
Seems the lift numbers would work with the vortecs, is compatible with TPI and won't require aftermarket chips or programing.
Any comments on this choice would be greatly appreciated.
Car: 89 Firebird
Engine: 355 TBI
That cam isn't really much of an uprade. MAF cars can handle a lil more cam.
Do you know exactly which engine is in the car now (engine code)? With a little effort the current CR can be worked out. Then you can math your way through to what the CR might be with the Vortecs. Cam selection follows.
thtanner
Southern California Area
78
05-11-2020 02:01 PM
articwhiteZ
Aftermarket Product Review
55
05-27-2013 03:42 PM
Jas89TTA
03-13-2001 10:31 PM
