383 tpi vortec heads 3.73 back to 2.77
Car: 89 Firebird Formula
Engine: 383 tpi vortec heads Xr 269 cam
ok maybe this is crazy or just plain stupid but here is my question. I have a 383 vortec head tpi producing over 450 ftlbs torque with 3.73 gears and 700r4 rebuilt.
the car is an 89 formula ws6 no suspension modifications. Since I am producing so much torque and spinning like crazy does it make sense to drop back down to stock 2.77 gears.
i assuming since I have more than enough torque from the engine I can sacrifice some low end torque to wheels for high end speed.
does this make sense? Responses with some real world experience or explanations are appreciated
thanks
thanks
Re: 383 tpi vortec heads 3.73 back to 2.77
I have my stock 2.77 in the garage- will switching back hurt or help my 1/4 mile?
That's a hefty change. Would you prefer it? Depends on if you enjoy the rpm it turns at the speeds you use it at.
If you're crossing the 1/4 finish around redline with the 3.73, the change will not improve the overall usability of the car at the track. Traction will. Usually a 3.42 is an ideal gear for the TPI powerband. If you're considering doing a smaller change, try taller tires.
If you're blowing the tires off at the launch, you might have a MPH at the finish you are happy with, but it will be lower if/when you get traction. Don't let pride mess with you.
A 2.77 rear sitting around for sale doesn't get much interest, and that's for a reason. It's not going to improve the drivability or performance of the car. It's going to add mileage.
Figure out what you really want the car to accomplish and whether a change will do it, and whether you want to spend the time to do it. Traction can be added with suspension or tires, or by possibly pulling some timing but letting it advance back in.
So is it fair say without any other changes a change to 2.77 gears would improve 1/4 time with better traction and therefore reduce overall mph at end of 1/4?
i really love my stock formula rims and the tire profile so I prefer not change tire or rim- for me the formula is the rims
thanks for replies
thanks for replies
No suspension changes just welded sub frame connectors . Are there any fool proof suspension changes to gain traction or are they all install and adjust until optimum is reached.
Is this what your are suggesting as a first mod to suspension?
Suspension is bone stock- no changes
I have done some mild porting on intake, axel runners and plenum and my preference is to stay tpi looking.
so the question is does a high torque 383 match better with 2.77 or 3.73 gears for 1/4 mile time?
I installed LCA relocation brackets, new LCA's and an adjustable torque arm and it helped traction a TON. Night and day. From my reading, it was likely the new angle with the LCA relocation brackets. This was done with a 3.27 and a 2500 stall on a bolt on L98. I can't see changing gears or an intake (both good ideas) before properly setting up the suspension.
If your worried about the best 1/4 mile time then the gears are only a small portion of the equation, you have to look at your entire combo and where your making power etc. I'd work on your suspension first IMO
I have a good 9 bolt with 2.77 gears I have to check the cones but I don't think they bottomed out I don't even have 99,000 yet on my car
Car: 1983 G20 Chevy
I also had 3.07 gears in my old G20 van with a TPI 383. Stock 1,600 rpm converter in a beefed up 4L60E. It ran a 13.9 @ 101 mph.
jonnybcamaro
04-11-2011 12:16 AM
