[ID] WTS 427SBC long block+ cheap $4000..
guys I posted this before..cant see it listed anyplace... this is a deal..
intake has been sold and NO water pump or front brackets.. its all forged billet splayed caps
SFI flexplat
canton racing oil pan (w/pick up and oil pump)
one off LPE valve covers(sold)
ATI super damper
comp cams mech roller lifters and cam.. ENDRA X lifters $600+
timing cover chrome or canton matching pan or aluminim 2 piece.
MLS head gaskets (you get to install the heads)..heads are new in box..test fit for pic.
ARP head bolts SS outer bolts SET new in box.
and on and on..dont need it ..its all 100% brand new parts
parts are selling off from day to day..this is what left at this point..
ya wana drive over and pick it up..$4000!!
will kick in a few other new things ya can always use...
SFI flexplat
ATI super damper
Re: WTS 427SBC long block+ cheap $5200shipped
link to info about this eng
https://www.thirdgen.org/forums/engi...ck-photos.html
Re: WTS 427SBC long block+ cheap $4000 shipped
Are you in Idaho, Washington or Indiana?
Re: WTS 427SBC long block+ cheap $4000..
I suppose the real question is not where you are but the engine is. Either way, it's about a ten hour drive from northern Alberta.
COTM Editor
Received 1,855 Likes
Car: '89 Firebird
Engine: 7.0L
This is getting stupid cheap. And you'd have to be stupid to not buy it.
Car: '87 Vette C4
Engine: 400 + .040 = 409 ci
Transmission: 700R4 built
Axle/Gears: Dana 44 w/3.42's
….. Is there a Fastenal store near you ? They ship store to store on their own trucks pretty cheap … this is a great deal ! I just spent $3500 FRESHENING my 421 or I'd be all over this ! …..
short block 100% new parts all forged
Block set up for dry sump/wet sump. mains getting oil first (like they should be) lifter valley screens race prep front to back of valley.
spayed 4 bolt caps with ARP studs. all caps are 4 bolt front to back. even the oil pump is 4 bolt with ARP oil pump stud.
H beam rod
SRP pistons
Forged Crank.
Canton Racing 7qt oil pan kick out pan. with oil return. for blower or turbo. crank scraper. baffles. trap doors. screw in dip stick set up. with temp gauge bung.
Melling HV oil pump and rod.
Canton 1 piece pan gasket.
ATI Super damper
sfi flex plate 168 tooth
AFR 220 Eliminator race ready heads 75cc (on this eng = 10.9 to1 cr) 65cc heads close to12 to1)
Cometic mls head gaskets.
aluminum 2 piece timing cover OR Canton Racing cover match's iol pan Or chrome you pick.
Push rods for this eng. ( geometry) was checked with top name parts..$140 value
ARP head bolt set SS outer bolts in this set..
ALL PARTS ARE BRAND NEW IN BOXES..
also have MSD starter for $180 more w/eng
or a GMPP perm mag starter for $100 w/eng
price to sell..cheap! till the 8th.. then just using for trade some day..
good sawp meet stuff..
nothing like new parts..
H beam rod
SRP pistons
Forged Crank.
ATI Super damper
I'm glad somebody is finally benefiting from this engine.
And congratulations to the smart person that recognized a great deal.
