EBL and IAC Tuning
EBL and IAC Tuning
Hey guys. Really hoping someone can chime in here on what my plan of attack should be. I believe at this point that I've narrowed it down to the IAC parameters and calibration in the BIN.
I'm running a 334 stroker with a 110LSA, 222/230 @ 050 cam. My old setup was a mega siamesed SLP runner setup. I got the tune not spotless, but damn close to it as far as idle quality goes. Then, my "I can never leave anything alone" syndrome struck and I sold the SLP setup, bought a superram, ported it and bolted it on. Now, I seem to be having some idle quality issues that I'm looking for advice on.
I bolted everything up and fired up the engine running off the tune I perfected with the SLP setup. I really wasn't expecting to have to make any serious changes other than maybe some corrections to WOT fueling, but I immediately noticed a huge issue with the idle.
With the correct IAC adjustment of 20ish steps, I was having an unstable idle. It would idle fine one minute, then the next it would start surging. You could watch the IAC steps, AFR and the SA swinging wildly around along with the RPM. There was a back and forth swing by as much as 1500RPM. It would do this for a few moments, then even back out, settle for a bit and then start surging again.
BLMs were around 134, and then would drop once the surging started. I made a revised Low VE map with the fuel bumped up and a "Bowl" around the idle area with the fuel evened out in the 4 cells I determined the engine liked to idle at. Didn't seem to make as much of a change as I expected so I then decided to take the IAC out of the equation on a hunch. I adjusted the throttle stop screw to 0 steps at idle. All idle air was being pulled around the throttle blades at this point. It then idled BEAUTIFULLY without a single hiccup...Until the fans kicked on. It then started the same violent swing for a few seconds and would even back out until the next time the fans were commanded on which would in turn trigger the IAC to open. During one instance in about 20, the engine actually stalled when the fans turned on.
There are no signs of a vacuum leak anywhere and other than the idle quality, she's running damn good. It's actually pulling MORE vacuum at idle than it did with the last setup (Went from around a 55kPa idle to 45kPa). Just trying to get this one detail ironed out. Also worth mentioning, this issue only seems to occur out of gear. If the transmission is placed in gear and the torque converter places a load on the engine (Shifting the fuel map into a higher kPa area), the idle is much more smooth and consistent. I am also not ruling out the possibility of a faulty IAC however, It's not terribly old and I purchased it about 30k miles back as a NOS ACDelco.
What IAC Scalars/Tables should I pay attention to and what changes should I be making?
Re: EBL and IAC Tuning
So, I won't be able to flash it and do a test idle until after work today, but I was playing around in the BIN last night and made a few experimental changes. I am under the impression that the IAC needs to be "desensitized" a bit so it won't be so quick to make changes.
- Adjusted "Idle bowl" in low VE fuel map. Once warm, engine favors idling in the 40 and 45kPa cells. Not 45 and 50 as previously thought.
- Changed IAC Dead Band from 32.5 to 50.
- Changed IAC Gain Breakpoints from 62Hi/50Lo to 100Hi/75Lo
- Increased fan on bump steps from 15 to 25 (The way it surges and bogs when the fan turns on is like it's starving for air)
Any ideas on what else to play around with or if changes should be made to the minimum idle steps table?
Car: check
Engine: check
Transmission: check
There may be some battery voltage drop that is triggering the IAC. Set this parameter to 25 V to stop the IAC from opening:
IAC - Volt Drop for Steps
RBob.
RBob.
So when I got home last night, I checked and the "IAC - Volt Drop for Steps" Scalar was already set to 25.
I spent the better part of the next hour experimenting with different things from the deadband to the idle steps table to the gain breakpoints. What I noticed was that the engine would do fine until it tried to settle to the commanded idle of 950RPM. You could watch the RPM drop and the IAC steps decrease, then right as it hit about 950RPM, it would suddenly "sag" to about 800 and start the surging process again though not as bad as before.
I then changed the commanded out of gear idle to 1050RPM and it did flawless at this setting with 10-15 steps remaining on the IAC once settled.
IN GEAR, it will idle fine at 900-950. Like I said, it is holding more vacuum with the new setup so I seriously doubt I have a vac leak. Any other ideas as to why it's behaving this way?
Difficult to say for sure without looking at a datalog. Normally when the engine shuts off when the fan kicks on, this would indicate a voltage drop in the system from a bad connection, or a weak alternator/battery. This is why I mentioned the possibility of any loose connections left over from the intake swap. A disconnected O2 sensor will do the same thing when the engine reaches Closed Loop temperature and suddenly makes the switch. Same bin you're using from the old intake setup with nothing changed, other than an increase in idle vacuum due to the better breathing SR which is normal. There is no O2 correction in Open Loop (you're using BLM, right?), so it would be either a steady Rich or Lean condition, no surging, up until Closed Loop is enabled... but if it is surging when cold then it definitely sounds like a mechanical voltage issue and not a tuning issue, especially considering that the tune was practically dead on from with the old setup just prior to the intake swap (which was the only change). Are all sensors reading correctly in the diagnostic screen? A higher RPM might be a band aid for the weak charge, which is why it seems okay at a higher idle RPM. Post up a datalog...
- Rob
- Rob
- Rob
- Rob
Also, don't pay any mind to the fan on bumpstep deal. That was only an issue when I adjusted the throttle stop to where the IAC read 0 steps. Once out of gear idle was adjusted to 1050 and normal IAC operation restored, the engine does just fine when the fan kicks on with the "Fan On Bump Steps" set to 20.
Car: check
Engine: check
Transmission: check
{edit: OK, we were posting at the same time, so since this has been tried...}
Try open loop idle and see how that is. Check this option flag:
Option Word 1 - Bit 2 - OpId
Sometimes the closed loop prop gains just driven everything crazy.
RBob.
RBob.
I'm about to go out and fornicate with it some more. Will post up datalog shortly.
Rob and Bob (Catchy!),
Here are two datalogs enclosed into a ZIP file. The first is with a commanded idle of 1050 in CLOSED loop. I believe I even let it log long enough for the fan to turn on at the end. The second log, the ONLY two things that were changed were the idle was commanded at 950 and the option word flag was checked to force OPEN loop idle. The 1050 idle you will notice fluctuates ever so slightly but the IAC and idle control parameters keep it well balanced. Even when the fan turns on, it hardly misses a beat. Sounds healthy idling in the driveway on the 1050.
I then turned it off, flashed the 950 BIN and started it right back up. You will see that from the very start, it's a total crap show and even triggers the stall saver. You can watch the WUD and watch the RPM/IAC steps begin to drop as it attempts to settle but then it goes totally haywire, surges like crazy, settles out for a moment and just keeps repeating the process over and over.
Also keep in mind that this seems to be a problem only out of gear. In gear with the converter placing a load on the engine, it will idle at 900-950 no problem.
Please tell me you guys see something I don't. I can't imagine any reason that this thing can't idle lower than 1050RPM.
EDIT: I have also tried the 950 idle in closed loop as well. There is very little change, if any at all.
800rpm at 40-50kPa is set to 13.8. The next cell up is 1200RPM, also set to 13.8. I can't imagine how this is causing the issue epsecially since attempting a closed loop 950 RPM idle still does the same thing.
What would you recommend trying? Won't hurt to press a few keys and watch the show.
Originally Posted by FireDemonSiC
Are you referring to the table, "Open Loop - AFR vs RPM & VAC"?
I would need to see a datalog for the 950 bin in CL to see what is taking place to compare...
- Rob
Absolutely, just look at the difference in the O2 reading as well as the injector duty cycle from the 950 bin, the O2 is pegged rich from the commanded fuel, and the duty cycle is swinging between 4 and 10. The OL graph is based on an average. Remember that these engines idled at a much lower RPM from the factory, and as the RPM rose to 800-RPM and above, the target was no longer 14.7, but 13.0 because your already on the throttle at that RPM from the factory. Once we increase idle RPM to compensate for a more radical camshaft (which normally ranges between 800 and 1000 depending on the engine), we need to alter the graph to reflect a higher stoichiometric RPM. So the cold AFR OL target will be rich to compensate for the dense air, and gradually leans out when fully warmed up to 14.7. If your target is 14.7, and the OL is set to 13.0 because of the RPM position, it will surge (tug of war)...
- Rob
- Rob
Certainly won't hurt to try.
Great information. I was always led to believe the opposite. That due to the increased duration and overlap, the O2 is only measuring what's in the exhaust and not the chamber and therefore, more idle fuel was needed. So are you suggesting to try setting the 40-50kPa table at 800-1200RPM to a stoichiometric AFR of 14.7?
- Rob
Ryangreen19 (08-09-2023)
Think of it this way; if you set your SA-Idle State advance to 24*, but your SA-Main Table was only averaging 10* because of the current location of the RPM & kPa, what do you think will happen? The very same thing, it will idle surge, but in your case it is the fueling that is skewed. Think about it, if you're running a VE that was tuned very closely in Closed Loop for a 14.7 idle AFR, but you suddenly set the Open Loop idle flag that is now targeting 13.0 AFR, the very same thing is going to happen. Remember that Open Loop has no O2 feedback, so how does it know that it is at 13.0 AFR? It doesn't. You're telling it based on the other parameters, and if your VE is already tuned for 14.7 at idle, but the OL is demanding 13.0, the difference is causing your surge.
- Rob
- Rob
Also, I know you were just using it as an example but for the sake of eliminating any doubt and taking one more factor out of the equation, I have the "Idle State SA" Scalar enabled. It is set to 28*, and the spark table all around the idle area is also flattened out to 28*.
I get what you're saying. I will try more tinkering tomorrow and post up the results. Can't fire it up anymore tonight without the cops showing up.
The commanded AFR is used in open loop fueling calcs, so if there's a large change in it from cell to cell ie 14.7--->13.0, it is going to affect fueling significantly regardless of how smooth the VE table is in those cells.
FWIW my experience with idle tuning on my XFI280 383 is to ignore the wideband and narrow band 02s completely. When you have that much overlap (230/236), there's going to be fresh air going into the exhaust, skewing the sensor readings. My suggestion would be to set AFRs for the idle region to the same value, and keep it constant...for now. Use the multi-bank capability of the EBL and load several bins with consecutively higher idle SA values; all have the same VE. Pick the bin which produces the most vacuum, lowest MAP value. Drop the idle SA by a degree or two so the Idle SA correction can still pull the engine back up if it idles low. Once you have a good SA value, start leaning the sucker out at idle. Can do this easily with the multi-bank feature. Ignore the o2s and keep leaning it out until it starts surging. You'll know when this happens. Add more fuel until it stops surging and check the plugs. If they look good, then BAM! Idle fueling and spark is now dialed. Set your IAC steps again, and you're good to go.
My wideband reports 17-18:1 at idle, and the narrowband rarely blips over 0mv. Normally, this would seem like an issue, but the motor has never idled better. I know I don't have any exhaust leaks. The readings are just a symptom of a lot of cam, and yours may be this way too. If your wideband is displaying 13:1, you may be much richer in the combustion chamber.
Hope this helps!
Now imagine tuning a smaller 305 cube engine with the stock 48mm throttle body, stock runners, with 23x/23x on a 110-LSA (flat tappet mind you, not a roller), with a Closed Loop idle at 900-RPM. The Hg/kPa doesn't move, it's rock solid (about 11" in P/N at idle), with IAC steps at about 35. I mean yes, the IAC can be ignored if need be, and an Open Loop idle can be enabled if so desired, but it's really not needed in my opinion. Just have patience, and you will get it very smooth in all areas with all of the sensors working as one. This is an older video from last summer, but I am linking it because it is relevant to the EBL and IAC control in Closed Loop...
- Rob
- Rob
1991LE (07-21-2019)
Funny, I just recently had an encounter with the five-oh doing that very same thing. Was out tuning idle, time flew by, and it got pretty late. Explaining you were busy tuning usually doesn't fly very well with them. They were nice enough and gave me a stern warning.
Hope this helps!
Hope this helps!
And I just have an old man as one of my neighbors. You know how they can be. Usually starts complaining around 8PM but the noise ordinance in our county doesn't start until 10.
Well, here's a couple more logs.
These are both with a commanded 950RPM idle. The only difference is one log is open loop, and the other is closed loop.
In this tune, I multiplied the entire AFR table from 1600RPM and below by 10% (Made leaner). This took the commanded AFR around the idle area from 13.8 to 15.2. In one last ditch effort NOT in either of these logs, I tried leaning it out even further to a commanded 16.8. I thought that would have made a considerable change, but it still idles and surges EXACTLY the same. Absolutely no change at all. It is still Idling fine on the 1050 BIN.
Someone please tell me they see something amiss in these two logs. It simply refuses to idle at 950 out of gear. At this point, I'm stumped.
Huh? It was plugged in. I just took the snorkel off and put it in the shed for the night. I specifically remember disconnecting it.
I'm also looking at the EBL WUD right now and the last recorded reading from the IAT is showing 41F. What do you see?
Interesting! I believe we could be onto the source of our problem! I recall when I first built this engine, It wouldn't run for more than 10 seconds before shutting off. I sent a log to RBob and he spotted the same thing. He explained to me that there are 3 stages of a code being triggered although I can't recall exactly what he said. But I dod remember I had to increase the "MAP Hi" limit for the MALF33 Scalar to 79 and that fixed the problem.
However, this raises the question of exactly what is triggering these codes. The "MALF34 MAP Lo Limit" is set to 14kPa in the BIN and we can see it never drops that low in either log.
Also, I cannot seem to find a parameter to adjust for Malfunction code 23. What gives?
Also FWIW, my IAT has been relocated to the snorkel. and the 41F reading is accurate. Ambient temperature where I am is currently 35ish F.
- Rob
Code 23 will have an affect on fuel delivery in terms of running very rich, which the system is trying to correct for at lower RPM's giving you that surge. The richness is verified by the O2mv and Injector Duty Cycle data being shown during the log. Bob will be against this, but try clearing the codes by disconnecting the battery for a few minutes, then restart using the 950-Closed Loop bin. Run it for a few minutes to see if the surge returns, then recheck your malfunction codes. If they, or more importantly it (23) returns, then it is more than likely the sensor itself at fault, which the circuit will need to be checked. If it comes back after reconnecting the battery, before checking the circuit go into the XDF and uncheck; Malf Flag - IAT23 and see if that fixes your issue first...
- Rob
- Rob
And I agree with you on the malfunction code and the fueling issue. That would explain why the wideband was still reporting the same 13.0:1 AFR even with all the changes.
Also, I do believe there is possibly a problem with the IAT sensor. I bought the V6 caged version from NAPA a couple years ago. On a few instances during some logs, I have observed it very briefly report an extreme negative value and then go back to normal.
Car: check
Engine: check
Transmission: check
Something else to try, set all values in these two tables to 10°:
SA - Idle Low Compensation
SA - Idle High Compensation
Someone else running the SuperRam had to do that to prevent idle surging.
RBob.
RBob.
Wouldn't that run...bad?
I have the zero cell set to 0* on the Idle high table, and 1* on the idle low table. All the rest of the cells are 3*ish. I may experiment around with it more once I get the IAT and fueling issue taken care of.
Probably not an issue, but is there any reason you're running in valet mode?
Alright guys. I admit defeat. I'm tired of chasing my tail. I tried literally everything. Adjusting IAC, adjusting spark advance (Bob, your idle Hi/Low compensation tip made a noticeable improvement BTW), leaning out the fuel and etc. All of these GREATLY improved the idle quality but I can't get it to idle below 1000 out of gear and 950 in gear without it going haywire. I THOUGHT I had it when I leaned the AFR out to a reported 16:1 and I THOUGHT I had it again when I reduced the idle advance a few degrees (It was at 28 resulting in a tug of war between the idle air and the spark advance. Reduced to 25) but, she just doesn't like it.
Honestly, I'm OK with that idle though. It sounds aggressive (About as aggressive as can be for having an X-Pipe) and gives great idle amperage off the alt for all my gizmos. BTW, those two codes for the IAT and the MAP were from the other night when I forgot to put the snorkel on and started it up with a naked throttlebody. They were stored, but not active. The reason it stumped me at first was I thought flashing a new BIN clears the codes but I was mistaken.
Here's a video from last night after everything had been done:
Now, I've got one last thing I need y'alls help with. A new issue has popped up in the midst of all this. Off a warm start, everything is perfect. But now, with a cold start. it does this:
Usually what will happen is it will stall out the first attempt, and on the second attempt will idle high for a few moments then settle down. This morning however was particularly cold and it stalled out 3 times. I had to feather the gas pedal for a few seconds to keep it running and get it on its feet.
IAC steps at key on, engine off are 153. What's going on here? It's as if it can't breathe.
It sounds like someone is guilty of playing around with the IAC settings way too much...
There is no reason your engine can't idle smoothly at 800-RPM, and no reason why it should be stalling during a cold start.
Which bin did you start with, and can you upload your current bin so I can see it?
- Rob
- Rob
- Rob
- Rob
Have a look. This BIN is a very molested version of the F_3001 BIN (5.4L with 280 cam). That's the BIN I started with to get the engine running 4 years ago.
Ignore high speed VE table. It's optimized for the old intake and the car hasn't left the driveway yet.
I'm putting together a new bin for you to try, I will upload it once you give me your injector size and fuel pressure setting. I will also include the notes as to what was changed. This will be a test bin, so upload it and see if it fixes your issue, okay. Just waiting on injector size and fuel pressure...
- Rob
- Rob
I don't have much time my dude, gotta leave soon. But a quick search showed you're running 22-lb injectors at 50-psi? If this is the case, BPC vs VAC should be 168, you're at 200. I see that you increased it by a percentage though in that searched thread, but I am putting it back to 168 for this test bin. Again, this is just to settle the idle down to 700-RPM in gear, which is more than doable. You can always change the BPC vs VAC to whatever you want to afterward...
- Rob
- Rob
Flash this bin in as a test. It is just what you originally started with (F_3001), but I changed the SA along with the VE to your settings from your bin above. The BPC I set to 168, and I also just tweaked the Idle RPM a little. Let me know if it continues to surge. Keep it in CLOSED loop with the narrowband though okay lol. Stay away from Open Loop just for the time being...
- Rob
- Rob
- Rob
- Rob
I cannot tell you exactly what the fuel pressure is right now because I'm waiting for my 4an hose to be delivered so I can hook the gauge back up. But 50PSI with the vac line connected sounds about right. I turned the regulator down a couple notches the other night. It was higher.
Also, I cannot comment on whether or not the BIN you uploaded works because the engine will not start with it loaded. It just sits there and cranks. Even tried opening the throttle a tad while cranking.
See now that is what bothers me. The only parameters that were changed were based on your bin above, as I started with the F_3001 bin and changed the following, see below pic. The base/initial timing is yours, the ide state is yours, the VE is yours, and the Main SA is yours. The only thing I did was lower the target RPM in the IAC and adjust the BPC value. Strange that it won't even start. It might be the 3001 bin. Try starting with an L98 bin.
- Rob
- Rob
- Rob
- Rob
Wouldn't it make more sense to tweak the IAC settings in the BIN I uploaded instead of starting all over again? ALOT of stuff was adjusted from the original 3001.
- Rob
I mean when it gets right down to it (save the bin you're working on);
* Start with an L98 bin
* Change Base/Initial timing to 11*
* Change Idle State to 25*
* Change BPC vs VAC to 168
.... and start the engine.
The other stuff like timing and fan tweaks comes later. If that engine will not start with what I outlined above, then something else is wrong. You're running a 334 with good cam, and 22# injectors. It doesn't matter how good the intake flows, because its' the idle that you are trying to sort out, and the kPa is telling you what the vacuum is, it isn't a devastating amount (mine's at 65 kPa).
- Rob
- Rob
Also, I think I know why it stalls on a cold start. I just remembered that I zerod the "Open loop - AFR Multiplier vs CTS" table because the previous AFR before we started all this and on the old intake would result in a fast, rich surge on a cold start.
Once it gets going, it still surges until it hits roughly 95-100F on the CTS but this one is more of a lean surge.
Actually no. GM had it very close in terms of the IAC and injector settings with both the LB9 and L98. The 3001 bin might be tailored to a specific engine. Remember that when we tune, we are only tuning fuel to air, as air is always a given. Only two differences between the LB9 and L98 are timing and fuel, with two entirely different engines. The other settings in the bin are practically the same between those two GM codes. Overlap is really no big deal, as mine has plenty, and mine idles low. So starting with a stock GM bin, changing the BPC vs VAC based on both engine and injector size, and everything will fall into place, and if it is slightly off, then we tweak. I mean swapping intakes is no big deal, as a slight difference in kPa at idle should not be causing the surge. Something else is going on. Wish you lived closer so that I can physically see the damn thing...
- Rob
- Rob
Why not use the "Copy from compare" feature of Tunerpro to copy all IAC settings from an L98 BIN into my current one?
- Rob
You can do that, but I recommend starting with the L98 bin because Bob might have changed a lot to the 3001 bin in comparison to the L98, not to mention you yourself might have made more changes on top of the CTS multiplier that you might have forgotten about. It's the Cold Start, and IAC settings that you're after from the L98. Whatever is easier though. The VE and SA is minuscule because it is already close, and can easily be dialed in afterward. What's important though is your base timing matches the spark reference, and the injector size...
- Rob
- Rob
I will then try modifying an L98 BIN and seeing how that runs.
Understand that whatever changes Bob made to that BIN have more than likely been replaced by me. When I first started on the tune for this thing, I sat down and spent the better part of 2 hours reading through the entire EBL_Calibration HTML file, getting familiar with what every parameter did (To my understanding, not alot of people do that) and making changes that I thought would be optimal for my setup along the way.
Along the way of getting the engine running and the tune ironed out, there were several scalars and tables for spark advance and IAC settings that I copied directly from an L98 bin already.
