Fuel Pressure ? LB9
Fuel Pressure ? LB9
Need advice on PSI (1989 LB9). Car will not start cold after putting new Bosch III #19 injectors (original injectors ohm’s where out of spec, rough idle, etc so I replaced from Southbay), I also replaced the stock regulator. Now when I turn the key on (no start) the psi will jump to 42 then after the fuel pump stops (2 secs) if will fall immediately to 30 then 20 then very, very slowly reach zero. I followed the manual and found that when I pinch off the return line I can get the psi to hold so the book say it’s the regulator. Now when I do get it started the PSI runs around 35psi at idle but when I pull off the vacuum hose from the regulator it jumps to 46-47 and holds. My question is should the PSI at all times be running between 40-47 and not 35?
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
Re: Fuel Pressure ? LB9
You may need a tune to properly run the Bosch III's. I agree with vinny R - you're fuel pressure is within normal range and what you describe would be considered acceptable to run. The regulators rarely seal perfectly so bleed down when you shut it off is normal. The vacuum signal reduces fuel pressure according to manifold vacuum and 35 while idling is normal.
The Bosch III 19lb injectors need to be tuned at about 17.5 lb and need the voltage offsets changed to run properly without high BLM's. It sounds like you may not be getting enough cold enrichment which is not related to the injector size constant in your tune so you may also need to increase the cranking fueling by adding to the "Crank PW multiplier vs. Reference Pulse" table.
You should also do a minimum idle speed and TPS adjustment since you got in there and changed injectors. Check your IAC steps when hot, check for vacuum leaks, etc.
GD
GD
Thanks for the info. When you say change the injector to 17.5 do you mean here as shown in the picture? I found the offsets on the form for voltage and inputted them when made a difference on the BLM.
Your correct on the injector flow rate. I’m curious to see what your blms are after the change. I have made the offsets change for members here and have got good results. I haven’t changed the flow rate not knowing how much this will change afr. But have yet to have any ecm feedback to see the change other than members feedback about throttle response being better.
I tried to upload the XDL file but this site doesn't allow XDL files to be uploaded. Anyway in the two xls files one is Bosch III with factory offsets and the other is Bosch III with adjustment offset based on forums. Let me know what you think. It runs much better than the factory injectors however the cold start up is not the same. If i crack the throttle just a bit it starts right up. This is a completely stock car with all the emissions.
Thanks I added the zip file.
Thanks I did see the IAC was low at idle but when you set the mini idle should you unplug your est (single brown wire)?
Command the iac in by jumping the aldl a to b. Unplug the iac and set the idle to 650 rpm I believe that’s the spec the article says lower. After the idle speed is set plug the iac back in. You can just set the minimum steps by using tuner pro. Just watch the steps and adjust the stop screw. Adjust the screw in to increase the steps.
https://www.thirdgen.org/tpimod2/
After the iac is set if your tps is adjustable with the 90-92 shouldn’t have slowed holes for the tps but it might. You can try to set it to .67-76 vdc.
http://www.fuelinjection.com/tpi/for...0Procedure.pdf
Car: 90 Formula / T-tops
Transmission: MD8
https://www.thirdgen.org/forums/diy-...or-sticky.html
But numbers are all over the map. The closest I could find to these numbers was from RBob in post #4 of the sticky thread.
I know your talking to the op but I have used post 5 offsets. For 700 & 710 Bosch 3s.
https://www.thirdgen.org/forums/diy-...0-voltage.html
#86
https://www.thirdgen.org/forums/diy-...ors-not-2.html
#86
Where did you find the injector pulse with correction -vs- battery voltage numbers? Are these correct and working? I'm trying to locate a source and found
Transmission: MD8
#86
#86
WICKEDDREW
01-20-2002 04:18 AM
