[OH] Fasteddi spring clean out. Step in! Lots of racing goodies.
Car: 1991 Camaro RS
Engine: BBC 509 Merlin ii 9.6:1 pump gas
Transmission: ATI pro th350 sfi case. TSI 5500 st
Axle/Gears: Strange S60 4:10s
I have quite a bit of stuff for sale. Prices listed are before shipping. Local pickup is avalible within 60 miles of Toledo Ohio. I'm willing to meet if within reason. Location Luckey, Ohio. 15 minuets south east of Toledo.
All items are OBO as well. No low balling please I'm only selling most of the stuff because it's just a parts mess at my shop. I'd like to clean up some storage room.
First is small block chevy items:
Summit 2 piece timing billet aluminum cover P/N G6312. $115
Victor jr intake model 2999 (1 inch taller version) $170
Howard's street retro hydraulic roller lifters. (12 lifters total 4 more needed for V8 sbc) P/N 91164N. $150
Ptc 8 inch custom tq converter. Stalled at 4800rpm behind 525hp 385sbc that ran high 10s in the 1/4 4.10 gear, 28 inch tall tires, 3350 race weight, foot brake at 3k launch 6500 shift rpm. $350
MSD 6al-2programmable (comes with all cable to tune box) has lots of goodies built in, 2 step, 3 step, map sensor hook up, boost timing retard, custom timing maps etc. P/N 6530 $275
MSD 4-dis plus. Amazing box for any 2,3, or 4 coil pack dis set up. Many many options on box. P/N 62152 $400
MSD 8920 tachometer adapter $35
MSD 83606 distributor. DOES NOT need ignition box. Rev limiter built in. Pro billet style. Mechanical advance. Fits big or small block chevy. $200
Merlin Grumpy Jenkins 345cc BBC iron heads. 119cc chambers. Flow well over 350cfm. LOCAL PU $675 for the pair come with springs retainers valves and locks installed. For hydraulic flat t cam up to 0.600 lift.
Merlin 360 single plane intake for BBC 4150 carb mount. STD heads $165
Chrome mr gasket chrome short water pump for BBC. Comes with chrome v belt pulley. High volume gpm. $100.
Set of 16 Crane 1.7 roller rockers for BBC 7/16" come with lock nuts and 7/16" rocker studs. $125
Turbosmart TS-0501-1140 Ultra gate 38mm comes with 7 and 14psi spring. Only used for a dozen hrs or so. $125
Will add pictures as I can and please post or PM for more pictures as needed and or information. Will continue to edit as I add more items.
Car: basic third gens
Engine: that I like
Transmission: to restore
Axle/Gears: and enjoy
Re: Fasteddi spring clean out. Step in! Lots of racing goodies.
Will the BBC heads work on a GenV block?
Car: 1991 Camaro RS
Ttt. Almost summer time bump. Obo on all parts.
Car: 1991 Camaro RS
Bump.
Merlin BBC 345cc heads
6al 2 programmable
Ptc 8 inch 4500 stall. Custom for a 10.70s 385ci all motor.
Merlin BBC 360 single p. Intake
BBC 1.7 crane roller rockers set of 16
Hughes full man rev. Valve body. Th350
Areo. 340 l/ph fuel pump e85 compatible nib.
Turbosmart 38mm waste gate w/springs.
2 piece timing cover billet. Sbc
Performance products sfi har. Balancer. 8 inch. Sbc
Bump obo shoot me a offer worse I can say is no
6al 2 programmable
Car: 1991 Camaro RS
Car: 1985 Z28
Engine: 383
Axle/Gears: 10 bolt/3.73
This is not meant to be rude so please don't take it that way, but are you getting the PM's I've sent? I sent one on 6/8 and one on 6/13 and haven't received a response yet, and I'm concerned they're not going through as you've been pretty quick to respond in the thread.
Car: 1991 Camaro RS
Yes i got them. Im sorry i dont get on here too often. I had a guy come over to just buy some BBC heads the other day and ended up buying almost everything i had for sale. So all is sold from this list.
Mod please delete thread. Thanks.
Destructive099
46
06-08-2007 01:15 PM
