Sierra6's Official Turbo Iron 3.4 Thread
Old 03-18-2019, 01:43 PM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
I got the heads on yesterday so I thought it would go ahead and start my official build thread.
I bought the following turbo parts from a member on here:
GT3582R Ebay turbo
38mm wastegate
BOV
48lb injectors
2.5" intercooler pipe
air to air intercooler
Engine stats:
3.4L A.R.I. Canadian block 2.8L bored and stroked
Heads were ported by Robert Frank, and then I decided to knock the intake port dividers (for better or worse) and gasket match the ports (hope you don't mind me name-dropping you, Robert)
Mahle Hypereutectic pistons & Moly Rings
Head valve work done by Valley Engine Service in Hartselle AL
1.77" Manley intake valves, 1.5" Farrea Ex valves (both stainless)
Comp 260H cam, Comp 1.6" roller tip rockers, .469 total lift. Comp springs
I've port matched my intake manifolds, which can be seen by searching my other created threads.
Tuned with Megasquirt II by Swaim Performance Solutions in Eva AL (street and dyno)
I will be cutting up the Pacesetter headers to make the turbo headers. It will run like stock from the driver's side and meet up with a log on the passenger's side. After I get it welded up nicely, I will take it to get cera-coated with a coating supposedly good up to 2000 degrees.
Old 03-18-2019, 01:46 PM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
Re: WhiskeySierra6's Official Turbo Iron 3.4 Thread
I realized that one of the heads had a sensor bung blocked off. I decided to use this head on the driver's side, and to put the temp warning dummy light sensor in the intake manifold where the sensor for the cold start injector goes.
Old 03-18-2019, 01:48 PM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
Next step right now is setting the valve lash and blocking off the lower manifold cold start injector hole.
Old 03-18-2019, 03:26 PM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
I also gasket matched the turbo flanges from the header to the turbo exhaust inlet
Old 03-18-2019, 05:10 PM
HellHound's Avatar
Car: I drive trans am. Duh
Engine: Yes, I have one in the trans am
Transmission: I have one of those too In trans am
Axle/Gears: In the rear of trans am
Ill be watching this. Curious as to what all you do...
Old 03-18-2019, 05:19 PM
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
Transmission: 5 speed
nice one,thanks for putting this into a thread.we will be watching .make it work and finish it PLEASE!!!
Old 03-18-2019, 06:22 PM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
oh yes I definitely will finish it barring some huge catastrophe. I have slowly been working on this for years already. its a low priority since its not a daily driver, but I will slowly continue progressing until shes done.
Old 03-18-2019, 06:31 PM
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
for something different but definitely amazing and usable(undeniable fabricating skill) check out "bad obsession motorsports" build of a mini
with an all wheel drive celica drivetrain."project binky" on youtube.these guys are extreme perfectionists about every minute detail of this build
and its been going on for over 4 years.
idk but to me its riveting and brilliant.they have unique solutions to all of the unusual situations they run into.
Old 03-18-2019, 11:12 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
I've been watching that series for a few years now, love it. Lots of inspiration there, though with some of their later videos I can see where their expertise lies... definitely not with car audio... lol They did a good job of actually installing the stuff, as in making it fit, but there are much better ways to setup that system than what they did, even with their limited space.
I love seeing the solutions to space problems they come across though.
It was actually because of the one video they made where the 4 wheels are actually connected to teh engine and they use a ratched on the crank bolt to show this that I had to do the same when I put a custom drivetrain in my Datsun, though only 2WD. lol
Old 03-19-2019, 07:56 AM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
cool, I will check them out. But I have been plenty inspired already just from the people on here lol.
Old 03-19-2019, 12:20 PM
Street Lethal's Avatar
Okay, I'm in for another Turbo V6 project.
Subscribed.
- Rob
Old 03-19-2019, 02:33 PM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
Port matching the turbo exhaust inlet by the carbon lines left on it from the previous owner. i'm not very good at porting lol. I used my little dremel instead of a die grinder so it only turned out so well, but it should be better than it was.
Old 03-25-2019, 09:31 PM
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
porting is definitely an art of patience,steady hand,repetitious measurement and re-measurement and good tools(none of which i have,lol) but looking good.
Old 03-25-2019, 09:32 PM
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
they have recently added several episodes,i had to binge watch to catch up but i really love it.
Old 03-26-2019, 12:20 PM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
Yes it is, and thank you. Another problem I have is I don't get brave enough to do it until I've had a few beers, and then i'm not so accurate lol.
Old 03-26-2019, 03:56 PM
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
in many cases less is more with porting as well.gasket matching is good..there's definitely a science to it and its pretty daunting for a newb(like me)
i would like to try a junk set sometime to hone my skill before ruining my vortec's(which really don't like much porting beyond gasket matching)
Old 03-27-2019, 08:02 AM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
right, I only gasket matched for the most part myself. but some of the ports were so misaligned that it looked like it was more than just port matching by the time I got done. the turbo will hopefully make up some for any errors on my part.
Old 03-28-2019, 09:11 AM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
Re: Sierra6's Official Turbo Iron 3.4 Thread
Cut up the pacesetter header & started mocking up the passenger's side turbo header log.
Old 04-01-2019, 08:45 AM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
More progress yesterday. Got the log tacked up . We've decided to mount the turbo in front of the engine instead of where the airbox was. Also did a coolant throttle body delete.
Old 05-30-2019, 08:17 AM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
more progress
Old 05-30-2019, 09:26 AM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
Old 06-10-2019, 09:23 AM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
here's the completed system. after I get it sandblasted it'll be ready for the Ceracote c-7600 glacier black coating, good for over 2000 degrees.
Old 07-30-2019, 08:09 AM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
done
Old 07-30-2019, 08:23 AM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
leaving the turbo unhooked until I can get it tuned. stock 3.4 injectors still in for now.
the electric cutout is fun to play with, and I love how it sounds at idle.
I took it down the road twice. felt pretty good for N/A. It dies when I come to a stop. it didn't do that before we took it apart. hopefully this can be tuned out. I didn't make any changes to the IAC or TPS. Left the TPS connected to the TB just like it was.
Can't stop the oil leak at the pan for the return line. Might have to just weld it up.
Old 07-30-2019, 08:25 AM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
btw that's an ebay t4 blanket over an ebay t3 blanket.
Old 07-30-2019, 08:41 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Wow nice job. What are you doing for tuning? Is it up and running?
Old 07-30-2019, 09:31 AM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
I'm using megasquirt ii for tuning.
Old 07-30-2019, 08:22 PM
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
wow,heck of a job so far.i never doubted you,this is motivating stuff.i look forward to seeing it run.congrats so far!!
Got the stance a little better,might have to loose an inch in the rear yet.its always something with these things,isn't it?
Old 07-31-2019, 07:48 AM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
Thanks man! Yeah yours looks awesome! I've ran out of money on my turbo swap. Be a long time before I can make the exterior pretty lol.
1986BANDIT (08-13-2019)
Old 07-31-2019, 04:37 PM
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
yeah,it looks good from afar but far from good!!! but thanks,it is kinda good looking,its
just when you know your car inside and out the little things stick out and bug you.
i look at some of the cars on thirdgen.org and feel ill because they look so incredible
Old 08-13-2019, 07:49 PM
HellHound's Avatar
Are you boosted yet?
Old 08-13-2019, 07:50 PM
1986BANDIT's Avatar
Car: 1986 trans am
Engine: 305/350
i just picked this up,it was too good a deal to pass up
1988 GTA -L98 350,loaded
Old 08-14-2019, 09:28 AM
Sierra6's Avatar
Car: 1985 Firebird
Engine: 3.4 turbo
if you're asking me, not yet. it's been so hot here that I think i'll wait a few weeks to get back at it. I don't want to send it to my tuner for him to datalog it with no AC.
34blazer
11-16-2011 05:57 AM
9secz28
04-13-2008 09:45 PM
daves12secV6
07-29-2006 11:19 AM
fast86
11-05-2003 02:08 PM
fast86
10-12-2001 02:06 PM
Quick Reply: Sierra6's Official Turbo Iron 3.4 Thread
