WTS B&M 700R4 MANUAL/AUTO W/9"B&M CONVERTER $1000
my used but like new B&M 700R4 manual auto non lock up was posted for sale..
this trans is close to new..used for a short time before pulling it.. after car broke..(rod)
the converter is the 9" 3000 stall non lock up
the trans is manual auto = you can shift it..or leave it in gear and 3rd or 4th and it will do all the shifting ..or shift it to 7000 if you feel the need.( )
has the vet servos. kicks tires over not tryn to show off..just shifts that nice.
just took the pan off and deburred the case to clean it up to like new.. (B&M DID NOT DO DEBURRING).case in now glass smooth..
trans has less then 200 miles from the last time it was looked at over 5 years ago..its been sitting on a shelf..
new front and rear seals will be included so will all outer seals..just to make sure (tail shaft O ring also)
its done in a nice black (that's that it was listed as) hammer tone finish with new B&M decal (like when I got it years ago)
also tossing in New in wrap braided ss Dip stick. New in box Polished Pan with drain plug bolts and rubber gasket
its getting shipped with standard pan (for shipping)
and tossing in a new filter even the one in it is still clean filter is new in box. just to be sure..
this refinish was done has I deburred the case.. its time to go to go new home
https://www.summitracing.com/parts/bmm-70421/overview/
still like new always clean..this converter works Fantastic! was getting 3200 on a footbrake..
this trans and converter is a set and must be used with one another.. Non lock up.
SALE PENDING FUNDS
but ya never know and a separate post..
makes for easy feedback rating..
SALE PENDING FUNDS
Re: WTS B&M 700R4 MANUAL/AUTO W/9"B&M CONVERTER $1000
pallets done..made 4'x2' too pack your converter and your free parts on
some of your free goodies..Polished aluminum pan(in box) Braided SS dip stick..not shown front rear seal to be sure as it's been sitting. rear tail shaft O ring when ya do you speedo..and a new filter.and 2nd pan gasket..the pan that's on the trans now also has a new gasket...just in case
thanks
Jeff
thanks
Jeff
articwhiteZ
03-24-2016 05:46 PM
articwhiteZ
07-01-2012 03:06 AM
articwhiteZ
12-16-2011 10:33 PM
rescuesigns21
05-20-2007 03:03 PM
