Stereo and horn fuse blowing
The fuse that operates my stereo and my horn has blown. When I try to replace the fuse with the correct amperage fuse it Sparks incessantly and then blows within seconds. This leads me to believe there is a short. Has anyone experienced something like this? Is there a likely location for the short?
Axle/Gears: 10 Bolt 2.73 Open
Re: Stereo and horn fuse blowing
Is the cigarette lighter on the same circuit?
If so, try removing it, then try the fuse again. The coils get corroded, and short. I've also heard of, but not seen, the lighter socket also corroding and shorting.
Car: 88GTA
Engine: 5.7TPI
See this diagram for Horn Circuit. Convenience Center above right knee.....buried!
https://www.thirdgen.org/forums/atta...-horn_001m.jpg
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Yeah, X2 on the lighter. Was my problem once. Just unplug the lighter socket from the back but careful with the connector. That orange wire is always hot. Probably took out your dome light, power mirrors and a bunch of stuff all on the ACC fuse too.
Happy hunting! I've got good OEM sockets and lighters if you end up needing one and can't find any
Henry
Henry
If I unplug the wire to the socket won't power still be coming through the wire? Is there a way to delete the wire completely so there are no potential fire hazards?
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
If you never want the lighter to work you can just cut the wire from the connector and insulate the end of it. Or insulate it until you want to plug a lighter back in. just protect it from grounding on anything while you're testing the circuit by putting in a new fuse
85berlinetta2.8
06-10-2004 08:35 PM
