full 2000 trans am swap into my 89 formula swap project!
Old 04-11-2019, 12:31 AM
forth81's Avatar
Car: 1989 formula
Engine: 305 tbi
Transmission: auto
OK i started a project with my 2000 trans am that got destroyed in a hit and run and I've made a playlist and will keep adding to it as i make videos from start to finish. The plan is to swap everything from my 2000 trans am ws6 in to my 1989 formula and also add a couple of turbo's to the mix and many other goodies. So i figured i would document it all and put it on you tube. I'm not a professional at cars and i've never done anything like this before. this will be my first project ever making videos about or being on camera and no one will really be there to help me film all the good angle's lol so bare with me and come along on this journey. i'm just getting started with and hopefully this will only take about a year or so from start to finish. there are already 5 videos in my formula swap project playlist. My channel is Crazy Asian Builds
thanks for your time
https://www.youtube.com/channel/UCMS..._as=subscriber
Old 04-11-2019, 07:07 AM
Boom's Avatar
Car: 1986 Iroc
Engine: 383
Re: full 2000 trans am swap into my 89 formula swap project!
That Mustang looks great! Sucks to hear about the Trans am getting wrecked by a drunk but at least its powertrain is going to live on in you 3rd gen!
Looking forward to seeing your progress. Good luck, I know the weather has been super crazy lately.
Old 04-11-2019, 08:29 AM
forth81's Avatar
Car: 1989 formula
Engine: 305 tbi
Transmission: auto
Thanks. yes the weather will probably slow me down but not stop me. but i'm hoping to go to friends house which has a lift for the actual engine removal.
Old 04-11-2019, 09:49 AM
forth81's Avatar
Car: 1989 formula
Engine: 305 tbi
Transmission: auto
So I've already got most of the parts i need gathered together for this full swap twin turbo build. And just in case anyone is wanting to know everything that's going on this car i'll put up a list here to see.thanks.
suspension:
umi boxed sub-frame connectors weld in
Umi adjustable torque arm
umi trans crossmember
founders panhard bar relocation kit
founders rear coilover kit
spohn front sway bar
spohn rear sway bar
spohn lower control arm
spohn lca relocation brackets
spohn front coilover kit
spohn wonder bar
Massive adjustable panhard bar
pa racing k member
pa racing a arms
edelbrock triangulated front strut bar
1997 z28 rear end with 3.73's
c6 grand sport heavy duty j55 front brakes
braided brake lines
try to put my 4th gen steering rack in aswell
interior:
full swap from my 2000 trans am
with ac and heat
exterior:
ram air I hood 93-97 style
tint
i pretty much love how it looks stock so not changing much here
engine:
stock heads and bottom end gaped rings though of course
ls9 head gaskets
arp head studs
cxracing twin turbo kit with T4 gt35"s .70 A/R Compressor - .68 A/R Turbine
custom intercooler and piping
oil cooler
tbss intake
92mm throttle body
88lbs. injectors
450lph intank pump
trunion kit
ls7 lifters
hardened pushrods
.650 double valve springs
custom turbo cam grind from cam motion
heavy duty timing chain
4th gen fuel tank
custom true dual exhaust
Trans:
t-56 6 speed from my 2000 trans am
Monster LT1-s Twin disc clutch
custom aluminum 4" drive shaft
also i will be refreshing all the weatherstripping, door hinges and window sweeps. also painting will be done very last after everything is perfect and will be completely taken apart and sprayed like a show car. if i think of something i forgot i will add it later. lol thanks and have a great day.
Old 04-12-2019, 10:54 PM
forth81's Avatar
Car: 1989 formula
Engine: 305 tbi
Transmission: auto
episode 2
Old 04-13-2019, 07:10 AM
Boom's Avatar
Car: 1986 Iroc
Engine: 383
I was wondering what that smoke in the video was, glad it was only a belt. You mention using a rear end out of a 97, couldn't you use the rear end from your 2000?
Old 04-13-2019, 07:39 AM
forth81's Avatar
Car: 1989 formula
Engine: 305 tbi
Transmission: auto
Yes of course I could use my rearend out of my trans am but my car has the 97 rear end in it already and I prefer that one due to the style of the e- brake it uses it engages the rear caliper to simply sqeeze the rotor. instead of a drum inner style e brake inside the rear rotor of the newer rear ends. Much simpler and a lot less moving parts.
Old 04-15-2019, 11:04 PM
forth81's Avatar
Car: 1989 formula
Engine: 305 tbi
Transmission: auto
episode 3
Old 04-20-2019, 05:27 PM
forth81's Avatar
Car: 1989 formula
Engine: 305 tbi
Transmission: auto
episode 4
Old 04-26-2019, 09:48 AM
forth81's Avatar
Car: 1989 formula
Engine: 305 tbi
Transmission: auto
episode 5
Old 04-28-2019, 12:24 PM
forth81's Avatar
Car: 1989 formula
Engine: 305 tbi
Transmission: auto
check out my channel here https://www.youtube.com/channel/UCMS..._as=subscriber
episode 6
Old 04-28-2019, 06:29 PM
TOM305T/A's Avatar
Car: 1987 GTA 350 auto
subscribed
Old 05-05-2019, 01:45 PM
forth81's Avatar
Car: 1989 formula
Engine: 305 tbi
Transmission: auto
episode 7
Old 05-09-2019, 11:09 AM
forth81's Avatar
Car: 1989 formula
Engine: 305 tbi
Transmission: auto
finally removing the engine and transmission. thanks for watching.
episode 8
Old 05-20-2019, 10:18 AM
forth81's Avatar
Car: 1989 formula
Engine: 305 tbi
Transmission: auto
episode 9
Old 06-05-2019, 10:07 AM
forth81's Avatar
Car: 1989 formula
Engine: 305 tbi
Transmission: auto
my channel https://www.youtube.com/channel/UCMS..._V2UoQkZvNYRhA
episode 10
Old 06-05-2019, 04:30 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Just did the same thing except I bought my donor from coparts, and kept the 89 formulas dash/gauges etc and not quite as many suspension upgrades.
You will find the dash from the 2k will fit in the thirdgen, but it just doesn't quite look right unless you make some custom filler panels and door panels so you don't have gaps.
http://bigbrakeupgrade.com/ has the brackets to use the front 2k brakes on the thirdgen, but you will not have ABS sensors so if you intend to keep ABS you will have to find a solution there as unfortunately the 4th gen k member doesn't fit the thirdgen.
Old 06-05-2019, 04:42 PM
forth81's Avatar
Car: 1989 formula
Engine: 305 tbi
Transmission: auto
yeah i know in my list i put the brakes i'm using and the k member i'm using the c6 hd j55 grand sport brakes and pa racing k member. and i'm doing a complete everything swap including the body harnesses and door panels and will be making anything custom that i need to out of fiberglass. and yes i probably won't be able to use the abs system but that's ok. i know it can be done but that's one i don't mind if i skip. thanks for the message.
Old 06-15-2019, 10:35 PM
IROCgiraffe's Avatar
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
Subscribed.... Finally convinced myself to swap my '87 IROC.... I have a running donor '99 SS.... looking forward to watching the videos to help game plan my swap.
Old 06-17-2019, 09:36 PM
forth81's Avatar
Car: 1989 formula
Engine: 305 tbi
Transmission: auto
thanks i hope it helps you in some in any way.
Old 06-17-2019, 09:37 PM
forth81's Avatar
Car: 1989 formula
Engine: 305 tbi
Transmission: auto
episode 11
Old 06-29-2019, 01:50 PM
forth81's Avatar
Car: 1989 formula
Engine: 305 tbi
Transmission: auto
episode 12
thanks for watching
WildCard600 (06-29-2019)
Old 07-09-2019, 09:08 PM
forth81's Avatar
Car: 1989 formula
Engine: 305 tbi
Transmission: auto
episode 13
Old 07-21-2019, 12:50 PM
forth81's Avatar
Car: 1989 formula
Engine: 305 tbi
Transmission: auto
episode 14
thanks for watching
WildCard600 (07-21-2019)
Old 07-31-2019, 10:05 AM
forth81's Avatar
Car: 1989 formula
Engine: 305 tbi
Transmission: auto
episode 15
here is my channel
https://www.youtube.com/channel/UCMS...V2UoQkZvNYRhA/
WildCard600 (07-31-2019)
jaygt
Members Firebirds
21
05-05-2017 01:33 PM
bungy74
09-22-2012 12:17 PM
y2kmaro
10-20-2001 08:20 AM
Quick Reply: full 2000 trans am swap into my 89 formula swap project!
