86 TPI 305 into 4th gen camaro start stall
we have spark fuel and injector pulse the one thing we can see is our coolant temp switch is broken can this void the engine from idling? we have this mocked up basically we plugged all the vacuum lines with electrical tape and dont have the radiator hooked up yet. but were getting computer power and everything but is the coolant temp sensor needed to idle?
Re: 86 TPI 305 into 4th gen camaro start stall
It's not rich in any manner but we're not running any coolant but we don't have a second module plugged in. It looks like a smaller version of the computer any ideas?
its an 86 305 tpi basically what im asking is what the frick is this thing?
5.5 MB
5.5 MB
I have no clue what is going on it starts and stalls I don't have any clue what codes are popping up as I don't have a scanner
I jumped a and b on the aldl and I got the 3 code 12s which I'm assuming is normal then 3 code 15s and followed by 3 more 12s which I've come to believe is the coolant temp sensor? I'm going to have to continue after work because my battery isn't charged. Any replies welcome.
ULTM8Z
04-22-2003 09:25 PM
