Belt squealing need help
Hi
I have a 88 GTA serp belt
I have a squealing at idel
I have bbk underwrite pulleys
And I changed my tensioner pulley and the a.c. delete pulley didn't fix it
I noticed that the hash marks on my tensioner ideling are not lined up
It's at 1 o'clock vs 12
Maybe I have the wrong size belt
It's new 91.5 "
Maybe I need 91 or 90.5
Or a new tensioner
Do you guys know what those marks mean
Which way is to loose
Which way is tighter
It's new 91.5 "
Or a new tensioner
Re: Belt squealing need help
Try spraying some water on the belt...
If the noise gets louder you have an issue with the belt slipping, most likely due to incorrect tension or some sort of contamination on the belt and/or pulleys.
If it goes away temporarily and then comes back, you have a pulley alignment issue.
If theres no change, then probably a bad bearing in one of the accessories or tensioner pulley.
I told you I already changed tensioner pulley with a new one and I have a.c. delete pulley I changed it
2 days ago
I cleaned my lower crank pulley bbk
And the noise went away for from 1 day now it's back
I know I have a tiny leak from my water pump weeping hole that got the lower crank pulley damp
I just want to know what the hash marks are for on the tensioner
2 days ago
Yes it does
I'll go get a pic of it right now and show you
Ok well don't ever buy Napa belt
It's 1 year old
It may be under warranty
I'll have to ask them tomm
Ty I'll let you know
It's 1 year old
Maybe a tiny bit
But I can't tell
I'll see if it is under warranty tomm
Ty again
I'll let you know
But I can't tell
Ty again
I'll let you know
Car: 1989 Trans Am
Engine: sp357
Do you have a smog pump on your car ? If not you need a different belt than stock and MAY have to change your belt routing, a stock length belt will not work. IIRC '88 would need a shorter belt than stock for smog pump delete where as '89+ uses a longer belt (which I have).
Thread on smog pump delete and belt routing/sizing if applicable - https://www.thirdgen.org/forums/exha...-pictures.html
I have bbk under drive pulleys
And I had to get a custom belt to fit it
And then I got a ac delete pulley and deleted my smog pump
The Napa belt under warranty so I just got a free one cause
But it's 91.5 " long and its on and no more equalling for now but it's still on The same hash mark
I think at happened is after I did the bbk underwrite pulleys my alt voltage at idel wouldn't charge my car
So I got a really small alt pulley from a shop here and after that now it's 14.3 ideling and it's fine now
But I never thought to resize the belt after that
Now I think I need a 91 or 90.5????
The noise is gone but if it wears out the inside in 1 year obv your right
Some thing is wrong
Some thing is wrong
Zerocyde
06-09-2018 06:01 AM
