Hood hinges
Car: 1989 Firebird
Engine: 5.7 LS1
Hood hinges
So my hood had gotten to the point when you opened it the driver side hinge didn't act right. So you had to open it a foot or so then kindof twist the hood to to get the hinge to work right. Anyways the hinges had a good amount of play so I replaced them and it still does it, but with the new hinges the back of the hood sits high. I took off the center bump stop off the back of the hood and adjusted the hinge stops way down. If you push on the hood it goes down to below the finder line.
I have new side guides also so I put those on but it still does the same.
New hood structs also.
Is there a trick that I'm missing here I spent a long time re aligning etc but can't figure out why even with new hinges it opens strangly and sits high in the back... at least the old hinges didn't sit high.
The new hinges are OER.
The only thing I can think of is the weather stripping at the back of the hood, maybe I should replace that but I have a feeling new stripping would just make the problem worse.
Re: Hood hinges
My hood was doing the same thing before I took my car apart and I’ll need hinges too so I’m watching this thread. Is oer the only aftermarket option for hinges that you’ve found? They’re all I saw for factory replacement
i doubt it’s the issue but I would remove the struts and weather stripping and see if it sits flush. Or maybe the hinges are bolted down too far back and it’s an alignment issue? Maybe post pics
Car: 1989 Firebird
Engine: 5.7 LS1
Re: Hood hinges
I couldn't identify a different between the factory and the oer hinge other than the lack of play. I'll fiddle with them some more if that doesn't work I may see if I can re press the joint pins on the factory ones.
The odd opening action the more I think about it has to be off set. I may try ignoring the gaps and focus on hinge alignment. It didn't help that i had the entire front clip off the car during the engine swap.
Car: 90 Formula / T-tops
Transmission: MD8
Re: Hood hinges
Are you wondering if your hinge issue is due to removing them? I've read accounts where it is very difficult to get hinges aligned after removal.
BDR
Exterior Parts Wanted
06-20-2014 12:32 PM
hookin88formula
05-19-2001 01:53 AM
