Under hood heat
Under hood heat
Hi all. I was surprised on the amount of heat after a 20 minute drive. Yesterday it was about 105 outside. I had taken the stock air induction set up off to clean it up. When I pulled in the driveway I put my hand over the hood bulge opening before I turned the engine off. It felt like a furnace was blowing on high. My car is stock lg4 with a clutch fan and even with temps over 100, it doesn’t overheat. My air induction system works as it’s supposed to but I’m considering leaving it off. Getting the hot air out of the engine bay seems more important. Thoughts?
Re: Under hood heat
My car is the same as yours, and I agree with you.
I don't want that much heat under the hood, even if the engine is not overheating.
But whatever you do, you don't want to feed the carb that hot, underhood air.
In other words, no open element air cleaner!
Re: Under hood heat
I would think that:
1) If there's no overheating issue,
2) You build or have a cold air inlet such as the factory TPI twin filter element, cowl induction or something,
then it really doesn't matter how hot it gets under the hood. Within reason of course.
What's really needed is a CAI (of course) and a heat extracting hood like a late model Corvette. Whatever goes through the rad is exited through a louver/vent in the hood. That and ceramic coated headers.
Seems to me this exists or existed on some level at one time. I'm thinking a Japanese deal form the 90's.
Here's the Vette version.
Re: Under hood heat
I've been following his thread. That's a tough one.
The hood I think would be difficult to execute. Not so much the hood itself but the shroud needed to get from the rad to the discharge area of the hood. I've checked out the Vette's OEM arrangement and it's tight. Really tight. I suppose you could go free air. It would lose some efficiency obviously but maybe better than nothing. But there's also the matter of rain...
Re: Under hood heat
Could something like that be done with this hood?
This one below has been modified.
Re: Under hood heat
If you incorporate that excellent looking cold air package then any holes punched in the hood I would think would be a benefit.
I've seen folks suggest that leaving the back end of the cowl induction style would help with removing under hood air. The problem I see with that is the exit of the cowl against the windshield is actually a high pressure area and air is drawn in. I think it's less pronounced today with the laid back windshields compared to the 60s/70s but it's proven to work that way. Holes on the side of the cowl on the other hand would do a pretty fair job.
Re: Under hood heat
I follow you Skinny. Good Thinking.
That primered hood is MINE. Someday it will find it's way onto my car.
Re: Under hood heat
Cold air first Mr No! I love the ram air aspect of it too. Then deal with the heat under the hood if that's needed.
You Firebird guys are kind of left out when it comes to the Camaro TPI filter housing but after seeing what Speier has accomplished with his, I'm thinking of abandoning my cowl induction approach and incorporating the modified TPI arrangement. Cold air. Ram air. Plus the hood is open in the back for whatever benefit that might provide taking into consideration what I said earlier about the high pressure area.
Re: Under hood heat
Re: Under hood heat
Re: Under hood heat
If that's workable, then absolutely. As mentioned, if there's no overheating issue, as in engine temps beyond acceptable, and you can supply outside air to the induction system, then that's the approach to take.
Re: Under hood heat
No sarcasm intended although I see what you mean. By excellent looking I was referring to it's apparent functionality rather than the execution. Looks to be effective doesn't it?
EDIT: What I'd like to see is how and what it seals to.
Re: Under hood heat
See this: https://www.thirdgen.org/forums/auto...ml#post6350187
Firebirds have a lower hood line than Camaros. Therefore, you probably can't fit the taller lid. But standard height versions are available.
Re: Under hood heat
Do you have the single or dual snorkel air cleaner base?
Re: Under hood heat
The taller lid lets you use a 1" taller air filter element. If stock is 2", then you get a 50% increase in filtering capacity.
Re: Under hood heat
The restriction is the single snorkel itself. Each snorkel of the dual snorkel base is at least two times the size of the single. If your engine is stock, then it's not an issue. The extra inch in added height of the taller lid might not let your hood close.
Re: Under hood heat
Look at how much larger the snorkel(s) are on the dual snorkel base.
Re: Under hood heat
Does that gasket on the top of the filter housing couple to a source of outside air? FWIW, although I've been around these 3rd gens for a while and I've seen that style of air cleaner in pictures, I've never seen one in person.
Re: Under hood heat
Yes it attaches to a unit that attaches to the hood. During WOT the solenoid open a directs outside air from the hood bulge.
Re: Under hood heat
I actually have a late 70s Corvette air lid that is nearly identical to the 80s Monte Carlo lid. It can fit the taller filter. I also have an IROC air cleaner. Unfortunately I don’t have the ducts.
Re: Under hood heat
My solution to controlling under hood temps. You can find these on ebay.
The following 2 users liked this post by pwdbychevy:
dmccain (07-12-2020), NoEmissions84TA (07-12-2020)
Re: Under hood heat
Not a bad idea actually.
Re: Under hood heat
That would take care of the CAI part. As for under hood heat, as I mentioned, if the engine's air supply is satisfied temperature-wise and there's no overheating issue, then it doesn't really matter.
Car: 89 Firebird
Engine: 355 TBI
Re: Under hood heat
When I bought my car it had the cold air induction deal with the donut atop the air cleaner and all that. Wasn't impressed so I removed it for an open element nd the car seems to run cooler as certainly the hot air exits the cowl. I do like the idea of the side vents mentioned above . Getting air under the hood of these birds and keeping a stock look has always been a problem
Engine: 4++,350 & 305 CIs
Re: Under hood heat
You can also pull off the rubber seal on the rear bottom of the hood. Just know that it will suck a bit of the under hood heat into the interior fresh air vents on the cowl area. Also, whatever other smells and fumes coming from under the hood will enter as well..
Also a trick used by the top speed guys to drop under hood air psi build up.
Re: Under hood heat
dmccain (07-13-2020)
Re: Under hood heat
Maybe I'm missing something in the translation but if you have a source of outside air through the bulge in the hood, then why not use it on a full time basis? Bypass the WOT solenoid.
Re: Under hood heat
I can see that's a tough one. Probably the only way to accomplish that is to cut vents. One in the hood grill posted earlier. The other, and I'm not entirely sure how it all fits together, but might be to use the fender grills that came as an option on the Firebirds. At least I think it did on some model years.
Found this link. Item number 8 labelled as "extractor".
https://www.wholesalegmpartsonline.c...roduct=2531338
Re: Under hood heat
Jenkins (07-12-2020)
Re: Under hood heat
