HELP! Sudden Coolant Leak. Car Making Weird Noise in Reverse/Overdrive
So I have a 1986 Camaro IROC Z. I changed oil 3 days ago and have driven every day since with no problems. Today I went for a short drive, barely reached 60 and when I got to my parents house I noticed a smell. I parked in the street and popped the hood. Sure enough coolant was all over the top of my engine. It was all over the TPI and running down the firewall and rear of the engine. My car was maybe at 140F.
I waited a couple of hours went out and checked the car. Checked the dipstick and it was full. Fired the car up and in idle it's fine. However in reverse and overdrive it makes a weird noise, which you can hear in the post video. RPMs are normal and Oil pressure is normal. It leaked coolant not transmission fluid.
However, in the coolant puddle I did notice a rainbow as if there was some oil present. I'm not sure if that's from my car or just old oil in the wet street. But what could cause these problems? Upper rad hose is fine, lower rad hose is fine, thermostat housing looks good, water pump seems normal. Thermostat and gasket and lower radiator hose are almost a year old. While water pump is 3 years old. What is this noise?
Update: It looks like that coolant hose in front of the throttle body above the water pump broke. The on right above the thermostat.
Re: HELP! Sudden Coolant Leak. Car Making Weird Noise in Reverse/Overdrive
Yep. Likely a hose failure. On anything this old you should really just replace ALL the hoses. Also looks like the coolant is a nasty brown color and probably needs flushing.
No idea on the trans noise. Check the fluid I guess. Hard to think of a relationship between that and the coolant leak.
GD
GD
GD
GD
As for the transmission. I might have to take it back to the shop and have it warrantied again. I'll post the video in the transmission forum.
It's Dex Cool. For whatever reason or another, the car had dex cool in it when I purchased it 7 years ago. I think the last owner had the coolant flushed at a Chevy Dealership and that's what was in it. So I've used dex cool since.
GD
The car wasn't designed for OAT coolants, and the dealer really shouldn't have put Dexcool in it. OAT coolants eat plastics and there's really no reason to run them on a third gen. The plastic radiators from this vintage were not created with OAT coolants in mind. One only has to look at the early Vortec intake gasket / OAT coolant debacle to understand what it does to plastics.
GD
GD
3rd gen radiators are aluminium and plastic. Unlikely that he installed a high performance welded aluminium unit right before selling it.
GD
Anyway, you don't want to just cut a length of hose to replace it. The sharp bend will cause standard hose to kink. Molded hoses in the correct shape are available.
Part numbers:
GM 10108509
Gates 18777
Dayco 87653
Delco 14097S
Received 1,662 Likes
Don't use Dexcool in a traditional SBC. The molecules are too small, it will escape through EVERY paper gasket. Water pump to block, intake to heads, water pump cover to body, etc. etc. etc. That stuff goes RIGHT THROUGH paper.
Meanwhile, your problem is, a hose popped. Probably the upper rad hose. They're notorious for getting pinholes right past where the hose clamp is, ESPECIALLY if you use worm gear clamps on em. How barbaric.
Change the hose, get the spring type hose clamps like the factory used (for good reason), flush ALL the Dex out of your system and put back in about 60/40 to 70/30 DISTILLED water to GREEN antifreeze. May I please emphasize, get ALL the Dex out of your system: the mixture of that with the green stuff produces MUD, which will CLOG every smaller passage (radiator, heater core) in the system. May I also please emphasize, DISTLLED water; NOT garden hose, NOT RO filtered, NOT NOT NOT NOT NOT NOT. you need DISTILLED water ONLY.
This is 2020, not a 60s cruise-in. Do WHAT WORKS, not what "they've always done". It's not "always" anymore.
Does Dexcool affect Fel Pro gaskets? 90% of my gaskets are Fel Pro. Including the thermostat and water pump gaskets. When I swapped my thermostat back in march the old thermostat was completely clean. It had been in the car for 7 years (it was 195 I swapped it for 180). My intake manifold water outlet was clean too and so was the upper radiator water outlet. Even when I last flushed the coolant back in March no gel no gunk nothing. It was all clean. I refilled it with Dexcool and yes I used distilled water, I've never used tap water in my car. Inside of the radiator looks spotless. I'm running 50/50.
If you're talking about the hose that runs from the intake to the throttle body, I just learned the same lesson. I had replaced every hose last year except that one and it ruptured on me a month or so ago.
Part numbers:
GM 10108509
Gates 18777
Dayco 87653
Delco 14097S
Part numbers:
GM 10108509
Gates 18777
Dayco 87653
Delco 14097S
I also ordered a few cheap barbs. I'm going to do the coolant throttle body bypass.
Reddragon88gta (07-13-2020)
Yeah the Fel-Pro gaskets aren't any different from any others in that regard. The Dex will find its way through them. Look closely at the back of your WP, the WP -> block gaskets, thermostat, intake, etc.; you'll probably be able to see pink/orange crusties beginning to form on them. It's just simply not suitable for use in an older motor that isn't sealed with rubber gaskets and O-rings like modern ones all are.
Aren't all the fel-pro gaskets rubber? At least they felt rubber. Especially the thermostat and waterpump gaskets. All of them felt rubber and have that rib that helps it seal better. Same for all my TPI gaskets when I replaced the EGR. I'm sure my valve cover gaskets that are coming are rubber too.
I switched my '86 to DexCool in 1996. Almost 25 years later, I have no cooling system problems. Prior to that, I replaced the heater core. Twice. It's on the original radiator, mostly original hoses, gaskets, everything.stock. I check pH and change/flush whenever it starts climing about 7.2 (normal routine for everything I have). TDS and TSS were less than 10mg/l at last check. The only things I didn't check (and saw no need) were the D.O. and FOGs.
As one person here famously remarked once, the original gaskets by then were not brewed and glued tree bark.
dan_o_89_rs
01-29-2009 03:24 PM
Bill 88TA
09-27-2000 03:47 PM
