UMI strut mount bearing isn't turning?
Has anyone had an issue where the strut shaft doesn't turn in the strut mount with UMI caster/camber plates?
The lower body of the strut turns but the shaft doesn't when turning the wheels left/right and results in the steering feeling stiffer.
Re: UMI strut mount bearing isn't turning?
I had the same concerns with my Founder's set of caster/camber plates. I talked to the shop that aligned it and they said it will loosen up and not to be concerned about it. They also told me that it wasn't necessary to run that washer under the nut. I was concerned about the locking portion of the nut not grabbing enough threads to do its job properly. It looks like we have almost the same set up. I just installed the Founder's plates and Koni yellows.
Tidan (07-13-2020)
Tidan (02-08-2021)
Ok, i checked and mine does not rotate, but if i jack up the front end about 4-6" it does. So only when the load is removed from the tires, but i can turn the steering wheel with just a finger. Its never felt stiff/hard. Also my strut mounts (J&M) are going on 16 yrs. I haven't seen any negative effects form the mounts or to any strut i've used.
Tidan (02-09-2021)
Thanks for checking 841LE!
Wondering if other peoples plates don't turn either.
I'd like to get my steering a little lighter as currently it won't self center very well when I'm coming out of a powerslide - steering feels pretty stiff.
Tidan (02-10-2021)
