Stupid Push to start button!
Car: 1989 Camaro RS
Engine: 305 V8
Transmission: 5 Speed Manual
So I purchased my 89 RS and it has a push button to start thats wired straight to the starter. So i jave to turn the key to the on position to activate the pump and everything, the push down the button to start the car. I was told the VATS is bypassed bu i dont know....
My question is where do i start if i want to get it back to normal? I have no idea what to look for cause he must have done it cause something was broken....
Thanks!
Thanks!
Re: Stupid Push to start button!
Does the car start if you turn the key all the way? My car was wired up like you described. I removed the button and wired it back to normal. No vats on mine though.
WildCard600 (07-13-2020)
Car: 1989 Camaro RS
Engine: 305 V8
No it won't start with key at all. Imma try something and if it works ill write up what I did incase this ever happens to someone else. In the meantime continue shooting ideas to me.
You should just need to move the "start" signal wire from the button back to the ignition switch. Then you can remove the button completely and the car should function as normal.
Hypothesis - someone bypassed the VATS starter enable relay using a the momentary switch because they didn't understand how to correctly bypass it. Rip out whatever they did and revert it back to stock. If the start enable relay is bad, missing, or isn't being triggered by the VATS module then bypass it with a jumper wire and a couple spade terminals.
GD
GD
Lively (07-13-2020)
Car: '91 TA vert
Engine: turboLSx
Follow the wires for the momentary switch back to where there attach to the car. I agree it's probably to bypass the VATS starter relay.
Car: 1989 Camaro RS
Engine: 305 V8
It goes straight to the starter, and the other wire goes to a body ground. Question does the vats just disable the starter or does it also disable the fuel pump? Because if its hooked up the way it is then it makes sense and i can just throw a resistor in and rip out the switch and be done right?
Car: '91 TA vert
Engine: turboLSx
I don't see how if could go from ground to the switch and then the starter. The starter solenoid requires power to actuate it so power has to come from somewhere.
I never understood the point of putting a push button start on the car if you still have to put the key in the ignition. Why not just turn the damn key at that point?
Car: 1989 Camaro RS
Engine: 305 V8
Car: 1989 Camaro RS
Engine: 305 V8
The wires go from the the switch right through the firewall... across the engine and straight down to the starter. Didnt lift the car to check but i can only assume it went right to the starter and dont know of any relays under the motor. However both wires go to the starter.
If the engine runs, then the ECM has already had VATS bypassed or it wouldn't fire the injectors.
The VATS relay wasn't properly bypassed by the sounds of it. Sounds like you can remove the push-button wiring and proceed with the proper VATS starter enable relay bypass.
GD
GD
Lively (07-13-2020)
Car: 1989 Camaro RS
Engine: 305 V8
GD
GD
Car: 1989 Camaro RS
Engine: 305 V8
So theirs no need to trick the vats by making it think the keys in? The key will be in but he clipped the wired at the cylinder.
Car: 1989 Camaro RS
Engine: 305 V8
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Oh, the indignities to which some people subject 3rd gens. These cars are becoming increasingly rare, and knuckleheads with diagonal cutters and crimp connectors should get their hands smacked any time they get near a Firebird or IROC.
the311godfather
02-09-2008 11:06 PM
