Lower TPI Intake Differences?
Car: 1989 Formula Firebird
Transmission: 5-speed
Axle/Gears: 3:45
I have a stock 1987 Formula 350 TPI, and will be replacing the intake gaskets. The lower intake is filthy, and I came across one from an 89 Camaro that looks really good, also one from an 89 Corvette. Will either of these fit on my 87?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Lower TPI Intake Differences?
The 89 f body will work just no hole for csi timer switch. The Vette base has to have center holes elongated to fit 72 degree bolt pattern.
Engine: Lb9
Transmission: M20
If you do use the Vette base block the rear egr feed and coolant hole 1/8npt hole.
Car: 89 PONTIAC TRANS AM
Engine: 5.0 TPI
Transmission: Stock 4SP 700R4
Axle/Gears: 4TH GEN 3:23
Also wasn't 89 the first year to not have the cold start injector on the TPI intake? That might be an issue putting an 89 intake on the 87
Engine: Lb9
Transmission: M20
The passage is still in the intake so it’s a matter of what runners are used if the provision is there on the runner itself.
