Spent the last couple months making a heads up display for my turd. Pulls data directly from the gauges, runs it through an esp23 and sends it to a horizontally mounted screen in the dash where it reflects off the windshield. I made a full YouTube video on it here https://youtu.be/nEz2zk0gkSg
Interesting, is that dimmable with the instrument lamps?
I put a separate **** for HUD dimming under the radio along with my interior lights pwm dimmer and my subwoofer volume. You can see it in the third pic
That is very cool. That is one example of newer "Tech" that I actually appreciate since it's helpful, w/no drawbacks.
Can you/could you move the projector closer to the driver to move the imaging further up in the view? Or would that make it get blurry? The image is very clear and easy to see for being projected on a standard windshield.
Do you mind sharing the part numbers/sources for the things needed to put this together? I'd like to try this in my C4, which doesn't have the issue of the speaker in the dash. I love what you did there, and I would appreciate having that feature during track days.
Here's the GitHub for the project and I've got all the main component links in my video description. https://github.com/Lost-Arts/Heads-up-display
I'd recommend using the first display instead of the one I ended up using mostly because it's cheaper, way simpler coding wise and the library to run the display has features that make it so much easier to use. I'm fairly certain you could do the same custom backlight setup with it too.
Hmmm....I guess I don't know how to use or navigate GitHub
Oh sorry I copied the link from my YouTube description and it got cut off and sent you to some guy names "los" instead of lost arts lmao. Here's the real link https://github.com/Lost-Arts/Heads-up-display
