help removing broken exhaust manifold bolts
Old Jun 4, 2026 | 09:43 PM
rustyjones85's Avatar
i desperately need to be pointed in the right direction.
my passengers side exhaust manifold finally came out, but i have broken bolts. they snapped off when threading out, and are stuck pretty deep in the thread.
unfortunately due to the location of the car and lack of tools, lifting the motor is not an option for me.
a/c box is already removed, i will attach a photo of my work space.
shhh i know it looks awful
Old Jun 5, 2026 | 08:53 AM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
Re: help removing broken exhaust manifold bolts
With the remains of the bolt tops too far into the head to weld a bolt onto them, then olny solution that I know is to drill them & try an easyout to attempt to remove the broken bolts.
In the future, oldtimers would use a big ballpean hammer to beat on the bolt head to attempt to loosen the bolts. Did that on the exhaust manifold bolts many years ago & no broken bolts.
Old Jun 5, 2026 | 07:30 PM
tbroadfoot125's Avatar
Engine: 87 5.0L TPI
Soak them down with some Kroil penetrate for a while, drill and easy out them is about your only choice I know of. The Kroil oil is somewhat expensive but it really works! Deep creep works really well also but not as good as the other stuff. If there is anyway to thread another bolt in, drill through a spare bolt and use it as a drill guide so you will hit near center of the broken bolt with your drill bit.
Old Jun 7, 2026 | 12:40 PM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
I have viewed "Project Farm" , a product testing guy using SCIENCETIFIC test methods, for years. His picks have never let me down.
He recently rated the LEFT hand drill bits, the best and they are moderately priced.
You will need "Easy Out" or other broken bolt extractors. All this if mig welding on a nut is not an option.
Amazon Amazon
T.L.
Nov 10, 2018 08:53 PM
Jimmy2x
Jan 3, 2018 08:49 AM
syboarder
Mar 13, 2012 12:29 PM
Frozer!!!
May 7, 2006 11:00 PM
FirebirdNYC
Jun 24, 2004 12:21 AM
