Help fix my cursed '89 firebird 350
I am Re posting this from Reddit and ill slightly modify what I said and have verified myself,
I have been trying to get this car to run it sat for a few years but did start, drove just fine until starter died so couldn't start it at all, I have replaced many parts on it and learned many things working on this car, me and dad, I am not a mechanic but am trying to learn but I need someone to help who knows how to work on cars
Car: 1989 Pontiac Firebird formula 350 Engine : 5.7 Fuel injected L98 (stock)
(First part of video) So the issue is that whenever I try to start my firebird, it would not idle with the MAF sensor connected, it would try, somewhat idle for a second but die,
(Second part of video) Whenever I would disconnect said sensor the car would still struggle a little to start when cold but if i tap the gas, it would idle but I think its on limp mode because if i try to put in drive or reverse its very weak on power
(Strange note: if I let car warm up for a little bit with MAF disconnected, then shut off, Conncect MAF it would struggle to start but then idle, still with weak power)
I have replaced many parts I might have lost track but here is what I have done myself
MAF + MAF RELAY
FUEL FILTER
ENTIRE DISTRIBUTOR SHAFT AND CAP
SPARK PLUGS AND WIRES
(For these 2 I have not calibrated or set but even unplugged it doesnt change behavior)
*IDLE AIR CONTROL
*THROTTLE POSITION SENSOR (I recently did fuel pressure test and it marked 40~ psi and did a smoke vacuum test and found nothing)
I did also do a weird test where i would start car with MAF connected, but the throttle intake duct not attached, if I brought the intake that connects MAF to intake close to the MAF it would sense air and engine would stall, could this be the MAF? Because I replaced it with a quality Delphi 250$
please help if you are a mechanic I've been trying to fix since 2021 but with school and work its become impossible for me and want to give one final attempt before I admit defeat and send to a shop
MAF + MAF RELAY
FUEL FILTER
*IDLE AIR CONTROL
Re: Help fix my cursed '89 firebird 350
Get TunerPro software. One version is free and the better one is a donation of like $40. Need a cable he lists on his website for like $60 I think.
You can also jumper pins A and B then count the flashes. it will flash the same number of times then flash like 3 times then 4 times for a code of 34. This repeats until all codes are given. When it repeats the same flashing sequence as first you have received all the codes.
Also be on the look out for vacuum leaks. I had a plenum gasket leaking and it sounds similar to what you’re describing. Tape off the intake, disconnect the vacuum hose to the brake booster and blow cigar smoke into it. If you have a leak you’ll see smoke coming from somewhere. That’s how i found mine.
Car: 1992 Firebird
Engine: 3.1L LH0
Transmission: Tremec TKX
Axle/Gears: 3.23 Torsen
I believe code 12 is what will flash first to let you know it's in diagnostic mode. It'll flash once, pause, then flash twice, and pause again. That'd be code 12, and that just means you're in diagnostic mode; any saved trouble codes will start flashing after that. If it was, just for example, code 34, then after the pause following code 12, it'll: flash 3 times, pause, flash 4 times, pause.
