Shortblock done some pictures inside
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Alu-mini-um and gear drive – drool, drool!
Looks good Jerry. What heads are you going with?
With the short block done the heads are now a work in progress and I hope to have them done in the next week or two.
Jerry
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Heads
Jerry:
You probably should mention the dark area is blueing so you can scripe the gasket pattern on the head ( just for the uninformed).
The top fuel blocks start from a 375 pound round bar and than forged in a 8,000 ton press with a three strike die set before the CNC machines cut it down to 175 pounds.
My block is a cast block and it tips the scale at 96 pounds
Jerry
Jerry
Car: '87 IROC
Transmission: TH700R4
Is this going to be a Fuel Injected engine or Carb'd?
Just wondering if the gear drive will affect the knock sensor, I've heard they can play havoc.
tj
tj
Originally posted by Parrydise7
What displacement? How much horsepower are you anticipating?
It's 6.7 liters and the HP will be in the high 500s NA and low 800s with the nitrous.
Jerry
Car: 1986/88 Frankenstein Trans Am
Engine: carbed L98
Jerry
Jerry
carb or FI???
Engine: carbed L98
Originally posted by Kevin91Z
Geez, talk about bringing a post back up from the dead. What possessed you to do that??
It'll be a TPI engine and it will pass CA smog.
New2Chevy
09-28-2015 12:35 AM
