New wheels 17X9.5 91-92 style
Re: New wheels 17X9.5 91-92 style
The wheels are done by turning down a stock wheel to just the center and then fit inside a billet 17 inch wheel. the center is press fit and welded just like the factory GTA and all Billet specialties, Boyd, Budnick and others. The hard part was finding a 17 wheel with the right ID to press the center in. The finished wheel is only 1 pound more then a stock 16X8 wheel, not bad for a 17X9 1/2.
Jerry
Jerry
Car: 2002 GS300 Sport Design
Engine: 3.0L 2JZGE
Transmission: 5-Speed Shiftable Automatic
Wow, how much did it cost you to et this done?
Cause theres a guy on here that had the hole rim redone by boyds or so and he said it wasent cheap on the pockets.
Tony.
Tony.
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
So I take it this method could be done with Crosslace and Formula wheels as well?
Jerry
They look awesome Jerry! Good to see that our boy finally got the lead out of his ***. Can't wait to see them on the car.
1 Post
Car: 1986 Grand Prix TPI
Transmission: 200 4R
Look good.
Some years back I tried to do that but could only get them widened not increased diameter.
Turned out for the best, as these newstolgia wheels I like better.
Engine: 3.0L 2JZGE
So theres a way of getting rimr widend? Like i want to do that to mine if possible?
Tony.
Tony.
Car: 87 GTA
Quoted to me by them "150.00 per wheel if you provide donors. 200.00 if we provide donors. takes 2-*3 working days, 100.00 for the refinishing of the wheel.so you will be looking at 300.00 total per wheel. plus 27.50 shipping, no tax"
Engine: 3.0L 2JZGE
The wheels I have came on the rare 1989 Chevrolet Carralo. But to my understanding I have all the front ones on my car and I been tryong to look for a set for the rears that the rare Carralo came in with heres a pic.
Unless if theres a way for me to pres in my rim in something to get a lip like that?
Thanks. Tony.
Thanks. Tony.
1 Post
Car: '91 Camaro Z28
Engine: 383 Vortec HSR
Transmission: Pro-Built 700-R4;Vig 4000 stall
Axle/Gears: Moser M9 9" / 3.89
Cool! Never seen that done before! A lot cheaper than going the boyd route.
Engine: 3.0L 2JZGE
Hey Stephen,
Hey so how safe is that mod? I mean is there a chance that the weld could brake or leak or so?
Thanks. Tony.
Thanks. Tony.
Car: 83 camaro berlinetta
Engine: 40 over 350
Transmission: 86 T5
Here is who I used:Wheels America
Car: 89 RS
Transmission: M5
Axle/Gears: 3.08 posi
Awesome and the perfect diameter and width. You are definitely the man! I'd be down for a set as well and have a set of donor wheels for the centers ready to go.
Jerry it is a shame you can't be twins. You could easily start a second business with all of the stuff you have fabricated over the years. It is a shame you need to sleep once in a while!
Engine: 3.0L 2JZGE
Thanks. Tony.
Thanks. Tony.
Thanks. Tony.
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Real sharp looking! Now Kevin need to stop being so cheap and get a set like that but in chrome for his car.
1 Post
Car: 92 Z28
Engine: Boosted LSX
now thats sexy.. awesome job once again man. Id deff. buy a set if I was in the market for some rims. Esp. since I have 4 stockers just sitting around collecting dust.
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
i think its a great finish product. its always fun to fabricate and be different with one-off type stuff.
just curious why you chose those wheels?
I think these are a ton nicer than the Boyd set. The fit and finish is second to none. Excellent job. Now my next question.............................wanna build me a set? lol I've even got the wheels to send you to get started on,lol
Car: 87 GTA
What do you mean "100 for refinishing of the wheel"? Do you mean for the outside of the wheel, or like clear coating it or is it something else? I'm wondering if you could get away with only spending 150 or 200 a peace without the refinishing, and then not do it, or just do it yourself.
The refinishing was the powdercoating & lip polishing.
Car: 1991 RS
Engine: 5.0
Can you fit a larger brake rotor behind those? Like a 17" size brake setup or are you still limited to a 16" rim size brake?
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
damn those are nice i bet they look better in person, sets the car apart nicely,
Jerry
#42
Car: 87 GTA
Anyways.....The refinishing was the powdercoating I had done. So without the powdercoating, it coulda been just the $200 per wheel (i let them supply the donor wheels).
#43
Car: 1991 Camaro Z28
Engine: L98 5.7 V8 TPI
These wheels are simply amazing. Do you have any more pics of them on the car?
#44
Car: 1991 RS L99 1992 Z28 L98 Heritage
Engine: L99 L98
Transmission: 6L80E / 700R4
Axle/Gears: 3.23 LSD disc (both)
Jerry, can I get your contact info, I would like to make a set, have my own donors,
#45
Engine: L99 L98
how do they balance out?
#46
Time to make some in 17 X 11 for the rear of my car to cure the lack of traction problem it has, so with the all the equipment setup i can run a set or two at the max for others. The cost is 1,200 to 1,500 a set depending on the size, finish and if i supply the core wheels.
Jerry
Jerry
#47
Engine: L99 L98
Jerry, I asked for your contact info in april and never got a reply, please send it to me @ mikesanto70@yahoo.com I want a set made for my 92' L98 Heritage Please get back with me asap
#48
The wheels are just a chunk of aluminum, so if you machine them true and round it can't be to far out of balance. The last set we mounted a set of Kumho XS tires on and the guy mounting the tires gave me a bad time about my request to have the tires mounted with the orange balance dot on the tire at the valve stem and then he was shocked when he balanced them and one tire needed 3/4 oz and one needed 1/2 oz and last two needed no weights The tire shop said it was just blind luck, i don't think so.
Jerry
Jerry
#49
Engine: L99 L98
those look so kick *** on there, is that car lowered at all or is that the stock ride height?
#50
Jerry
Jerry
