Hi there! New Firebird owner, SMOG questions....
Car: 1989 Firebird KITT Replica
Engine: 305 TBI L03
Hey all!
After being a Firebird fan all my life, I finally have the car of (one of my many) dreams!
I found an excellent '89 Firebird which was modified to look like KITT (yeah, I'm sure you guys are so sick of hearing about KITT replicas), which I found in CT.
I just had it shipped to LA, and I want to start the process of getting it registered here. It's an '89 with the 305, stock except for an Edlebrock air cleaner and KITT nose and scanner, blacked out rear taillights etc.
I just came back from the mechanic to put the OE cat back on, and took it for a SMOG check next door.
Well, it seems that the previous owner removed much of the stock SMOG equipment, and rightfully so, so it did not pass visual.
Can anyone help me with which parts I'd need to get to pass visual? Does anyone have any smog stuff lying around they'd like to get rid of?
I hate this smog stuff!
Re: Hi there! New Firebird owner, SMOG questions....
Post up some pictures of your engine bay and we can start to point you in the right direction. There are a few thirdgens in a couple pick aparts right now in the socal area.
Engine: 305 TBI L03
Looks like the only thing you need is the stock air cleaner set up like this. It has a heat riser on it and the filter for the pcv system. Make sure your timing is set to 0 and pressure test your fuel tank for leaks before you go for smog again. You will have a problem with your tail lights when you go to chp for the vehicle inspection since they are tinted.
Transmission: Pro-built 700R4
It probably wouldn't hurt to change the A.I.R. check valves since the car lived in a non-emissions North-Eastern state for so long. They're cheap and easy to swap out. Does your car have a working charcoal canister w/correct vacuum check valves?
Engine: 305 TBI L03
So I'd basically need this assembly?
Look at this on eBay http://www.ebay.com/itm/112396866913
I see the black canister at the very front drivers side of the engine bay, with hoses attached. Didn't pay too much attention to it but I'll snap a pic tomorrow
Thanks guys!
Thanks guys!
Engine: 305 TBI L03
Cool, thanks! Looks pretty easy to install and remove.
So what mods can we make to these cars, while keeping them legal? Or at least enough to pass smog?
You can do alot to them. There are cali legal hop ups made for them.
Engine: 305 TBI L03
cool, I'll check around. Thanks!
Engine: 305 TBI L03
Engine: 305 TBI L03
Thats the pcv breather. There is a hole in the side of the air intake assembly that the white part goes into.
Engine: 305 TBI L03
Got it...thanks Tealman
So I installed the stock air cleaner housing etc, took the car for a good one hour highway drive to get the CAT nice and hot. Took it in for SMOG today...and it did not pass. In fact, it failed with flying colors!
I'm at DOUBLE whats legally allowed! Ugh! Whats the first thing I should be looking at?
They should give you info on what exactly failed.
Hydrocarbons (HC) are a sign of misfire. Passing is in the 100 or 150 range maybe? 49-state numbers for 87-down is 220gm/ mi or something like that.
Nitrogen oxides get bad if combustion temps are high. Last time I had bad numbers, the intake manifold EGR passage was clogged, so EGR wasn't working (to cool combustion.)
There are others but those are common. So ask CA for the details, and troubleshoot from there.
Post a picture of your failed test paperwork. We can trouble shoot from that.
Engine: 305 TBI L03
Cool...I'll do a scan today. Thanks guys!
Engine: 305 TBI L03
Here it is....
HC and NO measurements are way high! CO seems OK
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
CO is way high, too. Should be .01 or .02 if everything is working OK. Always is on my tests anyways.
What steps did you take to prepare for smog?
You should always do a full inspection of all vacuum related items. Then, on cars I am not familiar with (like a new purchase,) I will do plugs, wires, cap, rotor. Check and reset timing.
The EGR passages do get dirty, especially if the car isn't super maintained on basic tune-up items over the years. I am mainly familiar with the TPI lower manifold so can't give best direction there.
Engine: 305 TBI L03
probably gonna start with swapping out the EGR and the O2 sensor (just from reading a few threads on the subject here).
I'm running a can of Seafoam thru it right now too, might help to clean up some deposits etc
Do a full tune up and oil change.
make sure all your filters are new as well.
Replace the 02 sensor, pcv valve, egr valve and verify your egr solenoid is working by checking for vacuum on the egr vacuum line. Replace the cat. Your numbers will come down significantly with those items replaced. A few hundred bucks but she will pass
The high NO reading is probably because you have a bad catalytic converter. I bet you have a strong smelling exhaust especially when it's cold. I have a friend named Louie with a exhaust shop on La Cienega and Venice. He can hook you up with a Magnaflow ca compliant converter for an amazing price installed.
Suggestion: after you pass, put a BB in the vacuum line going to the EGR valve. That way it will not open. You will most likely get a check engine light going down the highway by doing this, but as long as you know this is the cause and not something else, then the EGR passages in the intake manifold will not clog. Be sure to remove the BB when you have to go to emissions again.
EGR isn't robbing you of power, and it won't hurt to clean the EGR passageways every 50k miles...
Engine: 305 TBI L03
Just ordered a Walker CA compliant cat, new EGR, PCV and O2 sensor from RockAuto (sorry 1992 TA, I read your message too late!, but thanks, I will keep that in mind!)
Should get it next week and put it all together. Air filter is brand new, I'll get the oil/filter changed, maybe new plugs too.
1992 TA, got a good recommendation for a mechanic? I know, its all easy stuff to do...I just have ZERO time these days
Do you want something very local who's decent or do you want someone a bit away from WLA but who's really good?
That's awesome you got all of that stuff ordered. I can probably help you with some of that though if you don't want to take it to a mechanic. For the cat install and o2 sensor install take it to my friend Louie at 3c exhaust on La Cienega and Venice. He does extremely good work and is very reasonable with his prices, especially if you tell him you know me and you pay cash. 310-839-2442
Engine: 305 TBI L03
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Your mechanic is an idiot or a bs'er to even try and smog it with that air cleaner he knew damn well it would fail before he took it there Id call him on that one!
Engine: 305 TBI L03
Engine: 305 TBI L03
Engine: 305 TBI L03
So I changed the EGR valve and pcv (small one on the drivers side) . Got the cat and o2 sensor and will take it to Louie soon to install.
Now a few questions about the stock air cleaner
-the air temp sensor that was installed on my air cleaner looks like this, the one in my hand is the one that came with the car, in a hole drilled in the edelbrock air cleaner. What's the difference?
What's supposed to be connected here? A vacuum line?
At the bottom right side of my TBI, there is a small vacuum hose which is blocked off with a screw. Any idea what that's for?
I can look at my 95 GMC truck 305 TBI tomorrow.
#42
Car: 1. 1992 Camaro Z28 25th Heritage Ed
Engine: 5.0 TPI
Transmission: 5 speed T56
Hello.... I see your having issues getting passed smog. I just did smog on my 92. The most famous issue of failing is the EGR. I have a TPI 305 with a cat back exhaust kit. I did a full tune up and the EGR is always the issue. The EGR was not working with the rest of the vacuum so I replaced it and there was no issue. If you can't pass this time around I can help you. I live in Hollywood and your welcome to come to my friends shop so we can really detect the problem. Just message me if all else fails.
#43
Engine: 5.0 TPI
If I'm right that hose might of connected to the air cleaner. It also looks wrong. They might of replaced the original hose when they added the Edelbrock air cleaner on.
#45
Engine: 305 TBI L03
Thanks everyone! And special thanks to 1992 Trans Am and Tealman for helping me out over the weekend!
So along with the EGR and PCV changed over the weekend, I ordered the following:
AC Delco RapidFire platinum spark plugs, AC Delco wire set, AC delco coil, MSD dist cap + rotor, plus the new Walker CA compliant cat, and new Denso O2 sensor.
Hopefully after all that, it'll pass smog!
#47
Engine: 305 TBI L03
I think I figured it out....just supposed to be a vaccum line from the closed port on my TBI unit, up to the empty vacuum port on the air cleaner housing. Thanks!
#48
Engine: 305 TBI L03
Woohoo! Finally! After changing the distributor cap, rotor, ignition coil, plugs, wires oil and filer, egr, CA compliant cat and new o2 sensor, she finally passed smog!
#49
Congrats buddy! Glad you got her to pass and by good numbers. Go check out the socal board there is a bbq coming up next month.
